TV i got a philibs iTV and when i turn it on the screen is blurry and then green bars cover the screen then the TV shuts it self off
  • Angel79 Jun 10, 2008
    We plug in the tv, all 3 lights come on then green gets real bright then the tv shuts itself off.
    WE think the picture tube wire plastic part is cracked. It was apparentley put on wrong and burned a whole through the p[lastic.
  • 5,138 Answers
Your set has a open resistor & video ic on CRT board.this is why it shows drive lines and shuts off.So unless you do TV repair take it to a repair shop. ThankYou for using FixYa. Have a Nice Day.
Posted on Feb 08, 2008
My Mitsubishi TV is flashing a green light and gos to the blue welcome screen,does anyone kno what wrong with my tv?????????
I have an old Mitsubishi Tv , your instruction manual is good and thorough and if you don't find it there check online with http://www.mitsubishi-tv.com/ use the support section there.
Jul 14, 2012 | Mitsubishi WD-73C9 73" DLP TV
Blurry picture with green and red halos around
Ur convergence is dead.Must replaced 2 Convergence ICS,and some or all the resistors.Know how to solders?Buy a convergence kit Tv repair World.com,Tvrepairkits.com to repair it ur self.The shop will cost u $300 for parts and labors.
Feb 16, 2010 | Samsung HC-P4752W 47" Rear Projection...
Our Mitsubishi WD 52525 goes to blue screen and shuts off.
It sounds like you TV is overheating and the video is suffering and the lamp is overheating as well. Also, if your TV is over 2-3 years old, the mirrors (behind and below the big front screen) desperately need to be cleaned. Clean all filters and fans as well. (Look on side and behind the unit). Is the TV in a "hot" environment and/or dirty environment? DLP TV's are NOT sealed units. They need to be cleaned every few years to work well to have a good, clear, bright picture.
Jun 24, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Samsung Rear Projection Problem (not convergence)
The tv has 2 focus adjustments for each tube, mechanical and electrical.
1. Mechanical focus is set by looking at screen from back (through inspection plate on back of most samsungs) and rotating the lens assembly on CRT. loosen wing nut and turn lens assembly to go through focus and back to best position.
Put convergence pattern on screen and manually misadjust bottom red and green lines convergence so they can be seen through inspection hole.
With back cover of TV off you can usually reach your hand up beside the lens assembly to loosen the wing nut then rotate to adjust. Green is in the middle. The focus will be obvious when you rotate and look
When you are finished make sure the foam dust protector is not over any of the lens assemblies and the wing nut is tight.
2. Electrical focus - located at front of unit. the front grille/speaker cover is removed and maybe a cover over the front crt inspection hole.
In the inspection hole there is a black plastic "Focus/screen adjust Assembly" with 2 rows of 3 controls.
One row is focus and the other is screen. The middle controls are for green with R/B on either side. Usually the controls are labelled as "focus" and "screen". You want to adjust the focus controls, one for each color. Look for the focus or screen label imprinted in the plastic. Don't play with the screen settings.
With the same misadjusted convergence pattern you can see a red, blue and green line. Adjust green focus and watch green line for best focus. Do same for other 2.
Screen adjustments are very exact and delicate. The easiest way to deal with them is to turn color off in Customer adjust menu. Put any color tone adjustments in the middle (low, med, high, put at med).
You should have a b/w picture if there are no crt or other color related faults. If it is close to B/W leave screens alone.
If the pix is too green, then the green screen setting must be reduced a small amount. Do not play with these adjustments as most TV repairrers have a difficult time adjusting them.
If focus adjustments don't help then focus control or CRT may be defective. Needs expert to determine.
easyab
http://calgaryconvergencerepair.weebly.com/convergence-ics.html
Jun 24, 2008 | Samsung HCM4216W 42" Rear Projection...
Green translucient vertical bar on left side of screen
Cover green CRT lens with towel and see if red/blue video is normal......= bad CRT ?.............................T.
May 09, 2008 | Toshiba 57H82 57" Rear Projection...
Sudden color/picture distortion
you have a shorted green CRT that is affecting the other crts the short is internat to the crt that leaves what is called retrace lines. if the set is more than three years old then replace all three guns.
Feb 25, 2008 | Samsung TX-R3080WH 30" TV
Blurry on one side of screen. Green and purple shadows
Convergence IC's should be replaced before any alignment is
attempted ....part # STK392-560....You need two......mount
to large heatsink...............T.
Oct 31, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Blurry Images
Hello paulaspec,
You have a problem with the three factors, and they are screen voltage, focus voltage, and control (focus 2) voltage. Basically these voltages have to be adjusted since the components in this section have aged some. These controls are usually located in the television on the IHVT (Integrated High Voltage Transformer) or as it is also called the flyback transformer. these controls must be adjusted together, along with the color controls. Here is how the adjustment is done (You will need a schematic diagram, a DC volt meter, and a color bar generator to do these measurments):
1) turn color and tint fully counter clockwise until you have a black and white picture.
2) connect the color bar generator to the TV (ch 3) and turn it on, you should see bars in various shades of gray
3) adjust as best as possible the color and tint controls to obtain the color bars on the screen Red Green Blue.
4) measure the voltages on the focus, screen and control grids of the CRT and match them to the schematic digram measurements.
5) adjust the focus screen and control grids to match the ones on the schematic diagram
6) once this is done then you adjust the color controls once again to obtain the red green and blue bars on the TV screen.
This should help if the CRT (picture tube) electron guns are still good and if the flyback transformer voltage supply is working.
However if you do not have a background in electronics please take the TV to a shop for repairs.
I hope this helps,
Thank you,
Shuttle83
Oct 16, 2007 | Sony KV-20M20 20" TV
Screen
What you may have needed to do was adjust the green & blue crt screens to match the red. Go into your picture menu adjust, turn color all the way down to a black & white px. Now adjust each crt screen so that you end up with a true black & white px. Then adjust each focus control to get a sharp px, have your tv on a channel like the home shopping network so you can adjust each crt focus one at a time for clarity by cover the other 2 up. Then go back into picure adjust & turn color ahlf way up, you should see a better px.
Jul 01, 2007 | Philips 60P8341 60" Rear Projection...
KP-53s65 multipule problems, hoping for single solution?
sounds like 2 different problems here. first problem sounds tuner related. second sounds convergence related. third issue (cost effective to repair ?) at this point i would replace the set. i hope this helps
Mar 12, 2007 | Sony KP-53S65 53" Rear Projection...
Televison & Video Logo
81 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
