Question about Creative Labs Zen Touch MP3 Player
Light comes on and its frozen how do i reset?
Whenever i turn on my zen it will freeze and none of the buttons work but the only thing that happens is that the blue light only shows up.
  • 51 Answers
Has the player been dropped recently? or had a serious shock? It sounds like the hard drive is not starting correctly, which would prevent the zen from accessing the start files on the drive.
If this is so, check the warranty, if it is still in warranty, send it off. otherwise you may need to look into buying a new player.
Check out: www.geekzone.co.nz/forums.asp?ForumId=38&TopicId=6862
Quoted from 'retardinator':
I have had this before, what you need to do is
1. Connect the player to the mains via the power cable.
2. Straighten out a paper clip.
3. Hold down the Play/Pause button, and poke the paperclip through the reset hole (still holding down the play/pause button)
4. This will acces the recovery mode. Scroll down and go to reboot. Press the OK button.
I can't remember if this resets the data though?
But once you have control of the zen head on over to their website and update the firmware (this certainly wipes all songs but is soooo worth it) I have updated mine twice and now haven't had a problem since.
End quote
hope this helps,
Sincerely,
mister_apocalypse, aka <<CKS>>DRpyro
and
Maxicube aka 'monsieur'
Tech support team No.1
Posted on Feb 08, 2008
As above but you do not need to hold down the play button
Posted on Feb 12, 2008
My creative zen 4gb will freeze when playing any media
It is possible a virus has infected your device. If there is no virus in it, then it require re-programming. Visit http://www.s1mp3.org and find the appropriate firmware and tool. Try to reprogram it.
Jul 06, 2009 | Creative Labs ZEN Vision:M Digital Media...
Creative zen v problems-frozen
If a reset does not work using the reset hole, then try this: First, back up all of your music and do this: Turn off the player and disconnect it from the computer. Then press and hold the play/puse button and turn it on simultaneously. The player should be in recovery mode. Scroll down and select format (all) and let it format. Then reload all of music back onto your player and it should work like new. Hope this helps!
Aug 25, 2008 | Creative Labs ZEN V Plus MP3 Player
Creative Zen Micro (6gb) is frozen
Take your battery out of the back, turn it back on and let it reboot.
Jul 28, 2008 | Creative Labs Zen Micro MP3 Player
I Recently bought a Zen, and it works great. The only problem I found was that it freezes itself from time to time, and the best solution to this problem is on the bottom of your Zen, there is a very small Reset hole. With a needle or a toothpick, gently stick it in, and push lightly. This will allow the Zen to unfreeze, and return back into it's regular mode. All your files will be saved, and kept on to the Zen, so you don't need to worry about losing any of your files.
Any additional help, I'll be glad to answer!
-bananaboy101
Dec 04, 2007 | Creative Labs Zen V MP3 Player
Creative Zen frozen and Reset has not worked
try this if your Zen will not turn on
hold the pause/play button down
while holding the pause/play, first use a paperclip to press the reset button and then slide the power thing down for a few seconds like you are turning it on.
release the pause/play button.
you may need to connect it to usb for it to turn on. worked like a charm for me when everything else failed. hope it helps!!!
May 12, 2007 | Creative Labs ZEN SLEEK MP3 Player
Freezing, clicking and beeping
Have you tried updating the firmware of your Zen V Plus? I've had mine for almost an year and haven't had these issues -- I updated the firmware as soon as I unpacked it.
try downloading the
MP3 player recovery tool from Creative's website (the tool contains the latest firmware update available -- 1.15.03). Plug your ZV+ into your PC, run the program and let it update the firmware. Then format, reload your music and try it.
By the way, before updating the firmware, let the battery have a full charge, ok?
I hope it won't keep freezing on you after the update.
Apr 08, 2007 | Creative Labs Zen Touch MP3 Player
Frozen, any help would appreciated
On the bottom left side there is a pin hole. Get a paper clip straighten the end and stick it in the hole. This is the reset button.
Feb 13, 2007 | Creative Labs Zen Touch MP3 Player
Zen sleek frozen after trying to delete songs
Why does technology make you work for what you already paid good money for? Have you tried going into Recovery Mode? You do this by holding down the Play/Pause button while triggering the Reset button. Once there, you have four options. Try selecting Disk Cleanup and then Reboot. You might need to re-Sync a few things but it's worth a shot. Good luck.
Dec 16, 2006 | Creative Labs ZEN SLEEK MP3 Player
Creative Labs Zen Touch MP3 Player Logo
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
