Question about Frigidaire FGFB75D Gas Kitchen Range
F31 code for kenmore oven? - Frigidaire FGFB75D Gas Kitchen Range
Hi Jim,
I have the exact same problem on my Kenmore oven. Did you get any help as to what it is? My email is orenj10@yahoo.com
Thanks,
Oren
Posted on Mar 03, 2008
5 Suggested Answers
  • 537 Answers
SOURCE: oven does not start and gives code 31
Check this link:
http://www.applianceblog.com/mainforums/showthread.php?t=11880
It sounds like your oven probe is failing or has failed. The control board could possiblly be bad too
Posted on Apr 18, 2009
aborcass
  • 2651 Answers
SOURCE: oven not turning on f31 code kenmore
may be a real simple , lets try this. unplugh the unit, and uscrew rear panel of the unit, there is a thermostat that may have tripped, very small maybe the size of a quarter, with 2 wires on it, easy to sppot because it will have a small red button atop of it, its resettable, so if it did "trip" melrey reset and your on your way,there are actuallly 2 of theese thermostats on your unit, and actually a more common one to trip would be the one in the control panal, so id prblaby check this one first, to acces it remov eht knobs, then wehere the knobs were are "large plastic lock washers" holding down the control panel, one around earch knob opening, after ermoving htem the control panel will lift up and lean over. i belive there are 4 screws to remove the clock(plenty of slack in wiring no worry)after thats out of the way, if you look down under behind the switch to right is the same resetable thermo(lok for the the red button) and with a small long screw dricer youll be able to reset it, this should cure you issue. sounds like a ton of directions but should take no maore than 20 min, to check em both
Posted on Dec 30, 2008
  • 1417 Answers
SOURCE: Kenmore model 790.7851 gives an F31 error code
hello,
The F31 is an error code indicating that water temperature sensor error. There is a chance that there is a loose wire connection on the water temperature
what you have to do to fix up this is to unscrew (open)ranger then trace the wire down to the reader sensor/panel clean all form of water and dirt around them after all this make sure that all wire are in there position mostly on the panel then couple it back as it was with this the problem of F31 is solve please do this with care
thank you.
Posted on Jun 13, 2010
  • 5 Answers
SOURCE: code f31 shows when try to turn on oven
F31 means there is a short in the oven cavity probe circuit. The probe is the one of easiest things to replace. But this could be a control as well. To start, remove power from the range, unplug it. Remove bottom backguard panel, look for two purple wires leading down to a small white connector, which will lead you to a rectangle piece of metal (approx 1 X 3/4in) with one corner tucked in the body and a screw on the other end. This will be located on the right hand side of the back about half way up. Once you remove the screw, twist from the corner, slide out gently. http://b2b.frigidaire.com/support/manuals.asp?user=&NewSearch=New+Search will provide documentation for a part number for the "probe" or may be called "RTD."
I would be glad to provide more detail if you like, I would need more details in return...
Posted on Aug 30, 2011
Turn on over and get F31.
Hello, Janice -
There are many ovens in use today. It will help to know the make and model of your oven. You can add that information by choosing Comment and typing in the make and model of your oven
If yours is a Kenmore brand oven, the F31 error code means that the oven temperature probe has shorted out or there is a shorted sensor probe harness connection.
Sources of information + repair instructions:
https://www.shopyourway.com/questions/1068107
and
https://www.shopyourway.com/questions/1036659
If your oven is a Frigidaire gas oven, then the F31 error code also means there is shorted oven temperature sensor probe or a shorted sensor circuit.
Source of information:
https://www.shopyourway.com/m/questions/1018474
I hope you have the owner's manual for your oven. The F31 error code will probably be described in the manual.
Best wishes.
Apr 01, 2018 | Kitchen Ranges
/lfgf3014lbcwhat does f31 mean
Hello Jim, thanks for your post!
From my understanding your Frigidaire range, LFGF3014LBC, is displaying an error code of "F31". The "F31" error code stands for a shorted probe connection which could be an issue with your EOC (Electronic Oven Control), wiring harness, or RTD (Resistance Temperature Detector). I would suggest performing a reset on your range to help clear out any false error codes. You can reset your range by flipping off the household circuit breaker for ten minutes. I hope this information is helpful to some degree. -Matt
Mar 30, 2015 | Frigidaire Gallery 30" Self-Cleaning...
F31
If the cooling fan is constantly running then means thermal overload probably faulty, it has failed in closed position.
Best to get an engineer to help
warmest regards
Richard the Repairman
Mar 30, 2014 | Bosch HBL 455 Stainless Steel Electric...
Kenmore elte oasis electric dryer error code f31
f31 code is a thermistor problem ,if you need help go to www.appliancerepairservice.com
May 22, 2012 | Kenmore Dryers
F30 error on kenmore elite electric stove
F30 - Open Probe connections
F31 - Shorted Probe connections
Suggested Corrective Action
1. (F30 or F31) Check resistance at room temperature & compare to *RTD Sensor resistance chart. If resistance does not match the RTD chart replace RTD Sensor Probe. Check Sensor wiring harness between EOC & Sensor Probe connector.
2. (F30 or F31) Check resistance at room temperature, if less than 500 ohms, replace *RTD Sensor Probe. Check for shorted Sensor Probe harness between EOC & Probe connector.
Hope this helps (remember to rate this free answer).
Jun 04, 2011 | Ovens
Kenmore model 790.7851 gives an F31 error code this is
hello,
thank you.
Jun 13, 2010 | Electrolux Kenmore 30 in. Gas Freestanding...
Error code f31 flashing
The F30 error code indicates that the electronic oven control board detects an "open" oven temperature sensor probe circuit.
This is usually caused by a failed oven temperature sensor probe.
Replacing this component will likely fix your problem.
You can order this part from www.searspartsdirect.com website.
If you replace this part yourself, be sure that you unplug the range to disconnect electrical power before accessing this component.
On some models, you can replace the probe by removing the screws that mount this component to the inside back wall of the oven.
Carefully pull the probe inside the oven cavity until you encounter the wire harness disconnect plug.
Unplug the sensor and replace it with the new one. Mount the new probe on the back wall of the oven.
On some models, you have to remove the lower back oven panel to access the sensor probe.
If you replace the probe and still have this problem, you will need to unplug the range and measure the resistance through the violet wires that plug into the control board (this is where the sensor probe circuit is connected to the control board).
If the resistance through the oven temperature sensor probe circuit is normal (about 1100 ohms at room temperature) then the electronic oven control board will need to be replaced.
http://media.fotki.com/1_p,wbwdqtgkkqdrrfgxgtqsskgwtqkq,vi/ktrrwffdrxkddstsrtq/1/1303472/5961857/image45310img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 03, 2009 | Kenmore 96422 / 96424 / 96429 Electric...
Oven does not start and gives code 31
Check this link:
Apr 18, 2009 | Kitchen Ranges
F31 error
it is a shorted oven probe sensor
Apr 09, 2008 | Ovens
Frigidaire FGFB75D Gas Kitchen Range Logo
630 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Justin Duby
Justin Duby
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
