Question about Canon PowerShot SD500 / IXUS 700 Digital Camera
Power stitch My sony powershotSD70 IS has a problem with the power switch. It will turn off while in use, not turn off when button is pressed and will turn on after the switch is off .
  • Canon Master
  • 4,738 Answers
Here's someone else that had a similar problem. It ended up being a bad ribbon cable connection to its connector. If you're lucky, simply reseating some of the obvious ribbon cables into their connectors may help, in particular any ribbon cable leading from the power switch. Note that if you've never seen one, most ribbon cable connectors have little hinge points that you lift with your fingernail to unseat the cable:
http://www.fixya.com/support/t378189-a95_powershot_turns_off_until_batteries
Remember if you decide to proceed, it's ultimately your responsibility. Also note that there is a risk of electrical shock:
http://camerarepair.blogspot.com/2007/11/important-warning-camera-flash.html
And finally, not sure what an SD70 is? Did you instead mean SD700 IS? If so, maybe one of the following disassembly guides may be of help. Recommend not proceeding any further than to simply gain access to the ribbon cable connectors:
http://exploded.awcr.org/DigitalCameraDisplay
http://cannonlcdrepair.blogspot.com/
Posted on Feb 10, 2008
SONY DSC-W220/B My camera is displaying a message E:91:01 and will not flash. What do I do?
1. Turn OFF cam
2. Remove the battery or the power supply
3. Turn the switch to CAMERA for about 30 sec
4. Turn the switch to OFF
5. Install the battery or power supply
6. Turn the switch to MEMORY
7. Open the LCD cover and press the RESET button ( small inner button )
8. You will be prompt to adjust date/time. Do it
9. Take some pictures
If this does not work do this:
THE MASTER RESET
(1) remove the battery pack
(2) press and hold the power button for 30 sec
(3) after put the battery back do not turn it on for 1 min
(4) turn on
May 27, 2011 | Sony Cyber-Shot DSC-W220/B Digital Camera
E:9101 shwos on the screen on DSC-T70 sony cybershot
Follow these steps:
1. Turn OFF cam
May 12, 2011 | Sony Cyber-shot DSC-T70 Digital Camera
My button for turn it on is broken
You may want to call Sony and inquire about the issue. If your button is broken, and the console won't turn on, you may either have it plugged in a power socket that doesn't have any power, the switch on the back may be turned off, or your console may be defective. Ensure that there's power, and the switch is on (the I should be pressed in, and the O should be facing outwards) before contacting Sony.
May 04, 2011 | Sony PlayStation 2 Slimline Console
I have a sony va10 F series notebook model VPCF115FM, it was working fine at first but when i shut it down and then later turne it on again, it does nothing...nothing appears on the screen, all i get is a...
It appears that teh computer has entered the sleep mode and not waking.
Press and Hold the power switch for 7-10 secs to turn OFF the computer and again press the power to turn it back ON.
If issue is still not resolved then perform a few more steps for computer booting to black screen.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C270032
You can also perform the steps from the below link for computer that does not wake from sleep mode:
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C1002369
After this, change what happens when the physical power button is pressed or when the notebook lid is closed settings. Follow the steps from the below link.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C1002901
Select the option of shutdown for power button and do nothing for the close lid option.
Performing the steps provided can resolve the issue successfully.
Dec 08, 2010 | Sony VAIO Notebook
Play station three will not turn on on then off when power button is pushed.
First, old PS3 or new slim PS3?
The old models have a power switch on the back that must be on. You'll know its on if you have a red light on the front of your console.
To turn the PS3 on, press the power button. A light should turn green, and you're good to go.
To turn off the older PS3's, you must hold the power switch down for several seconds. For the new slim model, just press the button quickly.
May 02, 2010 | Sony Playstation 3 (PS3) Console
Sony ICD-P320 Handheld Digital Voice Recorder switch on and off
This voice recorder have auto power off function so does not have particular power on-off button, press play/ record to turn on and leave it for some time to turn off automatically.
Nov 11, 2009 | Sony ICD-P320 Digital Voice Recorder
Sony DSC T10 shows error E: 91: 01. Also flash
1. Turn OFF camera
9. Your problem should be solved
Oct 31, 2009 | Sony Cameras
Sony dsr-25 switches on, goes into stand-by, then won't start up
There is a "Key INH" button on the front. You want to turn it to "off".
Sep 08, 2009 | Sony DSR-25 Mini DV VCR
Sony FD Trinitron WEGA Tv KV32FQ86E two flashing led
The high voltage power supply is going bad on both units.. Pretty soon, it won't power up at all. For a fact.
Don't try to replace the power supplies, TV's are too cheap.
Feb 01, 2009 | Home Security
My less than 2 year old sony dsc-w100 keeps powering off and on
my only idea would be that the power button is glitching out...anything in the manual about this?
Jan 22, 2008 | Sony Cyber-shot DSC-W100 Digital Camera
Canon PowerShot SD500 / IXUS 700 Digital Camera Logo
55 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
