Question about Toshiba e310 Pocket PC
Pocketmac toshiba e310
Hello tech expert,
Could you please assist me on my Toshiba e310. My pc is apple Macintosh and I need a software to run it. Does your link from previous question here regarding Toshiba e310 will work also? I can't work on my E310 without this software. please help. Thank you in advance
  • 600 Answers
Check out mark-space software, it worked well for me
Posted on Aug 13, 2009
SOURCE:
Problem synchronizing
You got one of the newer devices that were released AFTER PocketMac was posted. There is a solution for this. First, visit the download page: http://na.blackberry.com/eng/services/desktop/mac.jsp
and start the download process again. As you move to the download screen, select PocketMac V4.0.20b for BlackBerry. Then, on the next screen, you have two program choices to download.
You have probably already downloaded the first one, under the heading "PocketMac v4.0.20b for BlackBerry." If you have erased it, go ahead and download it again.
Since you have one of the newest devices (like the 8110, 8120, 8130, 8310 or 8330), you may also need to download the patch that allows you to connect to those as well. That patch is on the same page, under the heading, "PocketMac Driver update -- DriverUpdate.dmg."
TO INSTALL:
1. IMPORTANT: Disconnect your BlackBerry from your Macintosh.
2. If you uninstalled PocketMac for BlackBerry, reinstall the main program now.
3. When the installer is finished, you will be prompted to restart. DO NOT click the restart button.
4. Install the Driver Update file please, this installer will complete very quickly.
5. Finally, restart the Macintosh now that the software application and driver updater installers have been completed.
After the restart is complete, please launch PocketMac for Blackberry, then plug-in your BlackBerry handheld. Click the Sync button to begin the synchronization session.
If you still can't connect, here are some steps you can perform to make sure the new patch is installed correctly:
1. Please unplug your BlackBerry and count to 60 seconds. This allows the
driver to completely release. (Likely, the driver wasn't released last time you tried installing the patch, so the new one didn't install correctly.)
2. Please open Finder, and locate the following folder: MacintoshHD/System/Library/Extensions/.
3. Within the "Extensions" folder, you will see a list of .kext files. scroll down the very long list, and locate the two files that start with "BlackBerry" files.
4. Please remove both of these files from your Mac: "BlackBerry.kext" and "BlackBerryUSBDev.kext". You will need your Apple Administrator user account password to remove these files from the Extensions folder. After you do so, empty your trash, please.
6. Install the driver again. After you've finished the installer/driver package, please restart your Macintosh.
7. Finally, plug-in your BlackBerry handheld, then launch PocketMac for BlackBerry. The PocketMac Sync Manager should now be able to find your BlackBerry.
Apr 22, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Toshiba pda e310
you may proceed to http://pcrepair.toshiba.com
Locate the most convenient service center in your location. Call the service center to confirm the issue.
Good Luck
Feb 02, 2008 | Toshiba e310 Pocket PC
Toshiba e310
Yes indeed you need driver first of all download the simple device driver from Toshiba as linked below;
http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_dtlViewDL.jsp?soid=210707&moid=429792&rpn=PD350U&BV_SessionID=@@@@0428634131.1202426047@@@@&BV_EngineID=cccjadedfdfdldgcgfkceghdgngdgnn.0&ct=DL&all_docs=false
After that download and install Microsoft Active Sync from microsoft as linked below;
http://www.microsoft.com/windowsmobile/activesync/default.mspx
Good Luck
Dec 06, 2007 | Toshiba e310 Pocket PC
Need old drivers and software for Toshiba Pdr-2 digital camera..
Hello , I am in need of software for my toshiba digital camera PDR 3330. I need to instal the pictures to my pc. can't find any software , please help......... where can I get
Apr 19, 2007 | Toshiba PDR-2 Digital Camera
My Toshiba e310 turns on by itself
It could be a piece of software that you have recently installed "activating" your PDA. I had this problem after installing a program that, amongst other things, monitored battery life. Once i uninstalled it it was fine so whether that was just a big coincidence i dont know.
Sep 15, 2005 | Toshiba e310 Pocket PC
PDA e310, e330 or e740 together with Windows NT 4.0
The Toshiba Pocket PC's e310, e330 and e740 are designed to work together with Microsoft Windows 98, Windows 98SE, Millennium, Windows 2000 and Windows XP. Microsoft Windows NT4.0 is an older operating system, which does not work together with the Toshiba Pocket PC's e310,e330 and e740. Technical background: The Toshiba Pocket PC's have a USB and a Infrared interface to communicate with a Computer. Unfortunately, Microsoft Windows NT4.0 does not support USB nor Infrared. Windows NT supports a serial connection, but the serial interface is not available for the Pocket PC's e310,e330 and e740. Note: There is the possibility to synchronize a PDA over Network or Modem but the ActiveSync Software, which is responsible for the synchronization, will need a "first sync" to establish a "partnership" with the PDA. This "first sync" can only be done via USB.
Sep 07, 2005 | Toshiba e330 Pocket PC
Sep 07, 2005 | Toshiba e310 Pocket PC
Sep 07, 2005 | Toshiba e740 Pocket PC
Open Questions:
See all Toshiba e310 Pocket PC Questions
Toshiba e310 Pocket PC Logo
52 people viewed this question
Top Toshiba Computers & Internet Experts
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
