Question about HP Scanjet 6300c Flatbed Scanner
SCANJET 6300C The scanner works but has 2 brown stripes on each side of the scanned image. One stripe is close to the edge. The other stripe is slightly off the other edge. The glass is clean inside and out.
  • 1 more comment
  • libratoi Feb 08, 2008
    I had found this information before but the following link is missing : (nps05345) (in English) for more information on Scanned images have a colored tint or have vertical streaks when using the ADF.
    Also, the lamp looks good and strong to the full length of it. I have removed the glass cover and wiped clean what I could. I dont know where the image reader is so that I could clean it. Do I have to remove the lamp ? I am not sure how to remove the lamp.
    Thanks
    Libratoi
    This is the result of the scanned image.
    http://www.geocities.com/libratoi/SCAN_I...
    Can anyone guess what that this is ?
  • libratoi Mar 13, 2009
    Cleaning all the mirrors inside did fix the brown stripes. Thanks a lot :)
These brown stripes on the right and left hand edge of the scan window are caused by smoking near the scanner. The front side mirrors located on the moving scan head need to be cleaned. You can accomplish this by removing the top of the scanner which includes the glass. Remove the clip that tensions the small but long cogged belt. Don't worry about repositioning the assembly correctly, the scanner will reset its position information when it initializes. Once the mirrors are removed, do not handle the mirrored surfaces excessively. Clean very carefully with some liquid soap and set on a clean towel. Dry with clean cotton balls and alcohol if required. Reinstall in their proper locations, making sure the clips hold the mirrors in the correct position. Replace the belt and tensioning clip. Replace the top of the scanner.
Start up the scanner and let it initialize. You should be off an running.
Posted on Jun 30, 2008
    President:
  • 2,351 Answers
No quick fix here. Scanjet 6300c
Look here at Hp's link.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&dlc=en&product=60104&lang=en&docname=bps05270
I have read it myself & this should help fix your problem of stripes on each side of scanned image. ( the color will vary ).
Post back if you haven't found this to help!
Posted on Feb 08, 2008
  • Mike Peluso
    Mike Peluso Feb 08, 2008
    That I didn't check the link to nps05345 & your correct the link was missing. Suggest you change the size of the scanned images. Hp's software allows you to preview the image after scanning. You have the option to resize the image by left clicking & hold on a corner of a prescanned image & moving it to it's max size. Even if this image is 81/2 x 11". Notice if the stripes are still there. If so, reduce the size of image & check. I did call Hp but they would not talk with me because the 6300c is too old. I have a HP 5510 all in one & have had this problem. After checking Hp's site I found it lacking proper information. In my case I removed all software & cleaned my system & my registry. Than reinstsalled my software. Haven't had that problem since. That was back in late 06. I didn't suggest that for you but it is an option. Rather than using the CD that came with your scanner you might be better off downloading what is dated newer. Sorry it did not work out.
Scanner not found
There is problem with Scanner Driver . You Reinstall driver. HP Scanner Drivers
Mar 14, 2010 | HP Scanjet 6300c Flatbed Scanner
Cat 5 cabling
Straight Cabling :
Side 1 Side 2
White Orange White Orange
Orange Orange
White green White Green
Blue Blue
White Blue White Blue
Green Green
White Brown White Brown
Brown Brown
Cross Cabling :
Side 1 Side 2
White Orange White Green
Orange Green
White Green White Orange
Blue Blue
Green Orange
Brown Brown
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 11, 2010 | Computers & Internet
Cannot find a download for a widows vista for hp scanjet 6300c
your operating system is not listed above, HP does not have software or driver downloads available for this product in that operating system. Your product pic00777.gif » HP Scanjet 6300c Scanner (Not your product?) icon_alert_sm.gif s.gif Alerts for this productNo alerts at this time That's pretty clear. HP doesn't support Vista on the 6300c Carl
Feb 12, 2010 | HP Scanjet 6300c Flatbed Scanner
Free driver for HP ScanJet 6300C
ftp://ftp.hp.com/pub/softlib/software3/sj675/sj-22000-1/sj675en.exe
Download the file above > unplug your scanner > install the file above > reboot your computer (if needed) > login into your account > plug the scanner into your usb port > it should automatically detect your scanner > goto device manager > imaging device > right click HP Scan Jet .... > Click on Driver Tab > Click on Roll Back Driver > choose to run the driver on windows xp compatibility mode.
Or use the compatibility wizard to set scanjet pro to run on windows xp compatibility mode
Jun 21, 2009 | HP Scanjet 6300c Flatbed Scanner
Green and yellow verticle stripes on preview and scanned images
You need to check the specifications of the old scanner. Was it designed to work with Windows 98? If it wasn't then there's little you can do to get it to work with 98. What you could do is look around for the nearest HP scanner that was the next model up after the 3200. A search of E-Bay for old scanners should come up with a cheap second hand model that still works with Windows 98.
Mar 27, 2017 | HP Scanjet 4470c Flatbed Scanner
HP Vista Driver for HP 6300 c
My need Scan Jet 6300C Hewlett Packard Free Drive
Jul 02, 2008 | HP Scanjet 6300c Flatbed Scanner
Scanjet 6300c
Check HP's website to see if there is a driver. Otherwise you may be out of luck.
Feb 15, 2008 | HP Scanjet 6300c Flatbed Scanner
Problem in scanned work
The Reflective Mirror Set in the scanner were subjected to dust. Clean the Mirrors (wipe the Dust with a soft hair 1 inch Brush. Do it under an Expert's Supervision
Dec 02, 2007 | HP ScanJet 3200C Flatbed Scanner
No picture image when scanning
This looks like a CCD failure. Can the image be corrected in the PC software Which image editor are you using?
Jun 14, 2007 | HP Scanjet 5500c Flatbed Scanner
HP Scanjet 6300c Flatbed Scanner Logo
710 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
