Question about Kenwood KRF-V5060D Receiver
KRF-5030D i stand by mode
   I have a problem with my kenwood amplifier when the system was running in tuner mode suddenly the system went into standby mode with the power indicator blinking in RED I have ckecked the Power Amp IC's and they are ok could someone please give me an idea sa to what the problem could be and if there is any site where I can get the service manual I have tried the local Kenwood service center's but have not got any help
Thanks
Chris
  • Anonymous Nov 28, 2008
    my **** is broke fix it
  • Seggs1 Dec 02, 2008
    Help!! I have the same problem as above. I have the same model as above and it is always cutting out. Thetrouble shooting guide within th mannual says that this symptom is caused by speaking wires short circuiting yet I have replaced mine and that does not do a thing.
    My amp cutts out and blinks red while on any mode (video1, tune, tape etc).
    Does anyone know the reason for this problem or a solution?
Resetting the Microcomputer
Posted on Apr 20, 2010
  • addylo Apr 20, 2010
    Resetting the Microcomputer !
    If the microcomputer may malfunction (unit cannot be operated,
    or shows an erroneous display) if the power cord is unplugged
    while the power is ON, or due to some other external factor. If this
    happens, execute the following procedure to reset the microcomputer
    and return the unit to its normal operating condition.
    With the power cord plugged in, turn the POWER key
    OFF. Then, while holding down the ON/STANDBY key,
    press POWER.
    • Please note that resetting the microcomputer will clear the contents
    of the memory and returns the unit to the state it was in when it left the
    factory.
    Genius:
  • 1,175 Answers
Does it go into standby when it's in another mode like : Cd or Video 1 or tape?
When you state that you checked the power amp IC's , how so did you do this?
Thanks n' let me know.
Posted on Mar 17, 2008
Sounds ok but not dialogue...
It sounds to me like you are using the receiver in surround sound mode and the click you hear is the center channel turning off. If you have another center channel speaker, try swapping that for the one you are currently using. If that doesn't fix the issue, then try replacing the speaker wire. If that still doesn't fix it, then the issue is probably inside the receiver and may be either an output transistor that is failing when hot or an electrolytic capacitor that allows too much DC offset when hot.
Oct 10, 2016 | Kenwood KRF-V5060D Receiver
How do I hook up a pioneer dynamic expander ex9000 to a kenwood KRF-V7030D receiver?
• Pioneer EX9000 out to Kenwood V7030D play In
• Pioneer EX9000 in to Kenwood V7030D rec Out
• instruction on page 8 of the manual
PDF] KRF-V7030D KRF-V6030D KRF-V5030D KRF-V4530D
Jul 31, 2012 | Audio Players & Recorders
Hi, my speakers are starting to sound a bit weird and i think its cause of pplaying around with the equalizers and settings on the Kenwood Amplifier, am just wondering if there is a reset button to restore...
Why guess? Get the manual out and actually look at the settings to see if they're out in space somewhere. If you don't try to understand what went wrong you will repeat it.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Kenwood-KRF-V5060D-Receivers-manual/id/480bh229/t/2/
Page 33 if you want the shortcut to factory settings.
Mar 24, 2011 | Kenwood KRF-V5060D Receiver
I have been using my Kenwood KRF-V7030D amplifier up until now without any problems... But now It simply wont turn on... There is power going to the unit as the red led lights up when the power cord is...
since the light is on there is the power going in but still you are not able to make it on so it have got the problem of internal mechanical problem, if atall it were the software problem then you could simply rebooted and could have got it in normal mode.
best thing to do is call some hardware expert and get it repaired and it will be cheap and relible too.
good luck
surya
Jan 21, 2011 | Kenwood Audio Players & Recorders
Audio and picture from blu ray player passing through amp to tv via hdmi cables ok but no audio from amp speakers?
Have you assigned the digital audio input being used to the BD?
I can't find the manual to point it out to you.
Dec 25, 2010 | Kenwood KRF-V6080 audio/video/tuner/amp...
I have a Kenwood DDX 616, I have sound from the Tuner, and DVD, but when I hook up my IPod via the USB...I get no sound
It seems the system is working fine. If you have the manual, please do read it througly. Check the cables for the usb, it might be damaged. Also reset the whole unit by pressing reset button, it should work. Thanks
May 15, 2010 | Car Audio & Video
Service manual and schematic circuit diagram required for kenwood amplifier KRF-V6050D
This manual is only available on paper as far as I know. What is the problem that you are trying to solve?
Thanks,
Dan
Sep 24, 2009 | Kenwood Audio Players & Recorders
Operating Manual
Hi - You can download the manual from the link underlined in blue below:
KRF-V5060D
Please update the question & let us know if the information given was useful to you - Good Luck!
Jul 26, 2008 | Kenwood KRF-V5060D Receiver
No Sound - boat stereo
Assuming that the four speakers are connected to the amplifier, then the amp is the most likely problem component. Does the amplifier show a power light when the system is turned on? Note that there is probably another fuse in the amplifier power wire, near the battery.
Mar 16, 2007 | iLO XM-MP3-CD Car Stereo
Kenwood KRF-V5060D Receiver Logo
1,969 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
