Question about Philips GOGEAR SA6045 MP3 Player
Go Gear Not Responding
The go gear has stopped dead just like that. It was working yesterday night and I switched it off before sleeping. In the morning it has stopped responding, it will not switch on. I thought chrage was drained so tried to charge via USB but it was not detected by PC also. Its just dead. I had bought it about 20 days ago and since then till yesterday night it was flawless and smooth....I am really confused, Plz Help!
  • mickjn Mar 25, 2008
    i only got mine yesterday and it is in the rubbish tonight never had nothing like it,terrible
Open up the device manager program.
Push the reset button on the device with a pin.
Press and hold the Vol + button whilst plugging into the PC.
Device Manager should go into repair mode.
Follow the on-screen prompts.
When finished, disconnect usb and reconnect quickly. Player should say loading, and then go into transfer mode.
Disconnect and reconnect player again. Screen should say
Updating.
Repair is now complete.
* If player flashes "Initializing" & "GoGear" alternately, then resatart the process again. If it still doesn't work then there's not much else you can do.
Posted on Feb 08, 2008
John Deer 175 hydro garden tractor, Kawasaki FC420V engine wont crank when key is turned. Stopped cranking yesterday. Previously on occasion had to turn key on and off a few times to crank.
bad starter or bad ignition switch. try putting it in gear and rock it back and forth, if it starts then you have a dead spot in the starter.
Jun 11, 2017 | kawasaki Garden
How do I fix the transmission problem? The car is moving forward at neutral, drive and low gear, and switching to parking mode at reverse and parking. The car is not backing up at all.
Transmission may now be toast since you continued to drive it when maybe low on fluid or torque converter had failed. How long since last fluid and filter change? Ever?
Jul 19, 2015 | 1992 Lincoln Town Car
Engine won t shut off
I would check your wires in the dashboard the wire that sends a signal to shut off the engine may be sparking or cut if you do not know which wire maybe hire a mechanic or look it up.
Thanks,
Landon
Mar 18, 2017 | Dodge Grand Caravan Cars & Trucks
Trasmission sleeps somtimes the gear works other times it doesnt
there are many gears.
are all gears dead, forward and reverse
even at 3000 engine RPM?
is the transmission slipping
if RPM gets stuck at say 1500 to 2000 that means the brakes are frozen in ICE.
Jul 30, 2013 | 1990 Honda Accord
My Royal Enfield Electra 2009 Classic, Engine Doesn't Stop Even After Turning the Switch/Ignition Off. If I try to stop using the gear then also it keeps going (Ignition Turned Off). After it stop
have a bike electrician check it out
I suspect that there is problem relay/regulator in the charging circuit that is allowing the alternator/generator to keep supplying power to the ignition outside the ignition switch circuit
could be a shorted wire
The dead batteries indicates this by discharging through the same fault.
Dec 31, 2012 | 2010 Enfield Electra Twinspark
1897 Yamaha Fzx 750 runs but stalls when put in first gear. Was working yesterday...
Saftey circuit issue! check clutch switch, side stand switch and wiring these are connect to the neutral light switch and the 3 are part of the saftey circuit,
circuit is designed to cut the bike out if the stand is down and you kick it in gear also to stop the bike turning over & jumping forward when you hit the starter and its in gear and the clutch isnt pulled in.
weak stand spring my not be pulling stand onto the stand switch correctly there fore no making the curcuit, switches just make and break the curcuit.
Aug 30, 2011 | 1989 Yamaha FZX 750
Shifting gear(Acura Integra 95) gets stuck on P.
The switch should lock the shifter in park . And you should need a key to release it. It is a child safe safety that has been installed since the 70's on all US sold auto's.
Jan 17, 2009 | 1995 Acura Integra Coupe
Gear Selecting
it might be your gears which are worn out and causing gear slips.. but there is high probability of your clutch plates getting spoilt.. the clutch plated work as disengaging the gears shaft to the main engine shaft.. sometimes when the clutch plates are very much use enough..,they stop working and cant retain to disengage the gears.. so first of all get your clutch checked well and then preoceed if it doesn't fix your problem.. heyii there is a shaft coming ut of the engine crank that connects to your transmission shaft which drives your gears and hence wheels.. so your 2nd gear must have worn out and for that reason the gear isn't working well.. get your gear box opened and check the gear.. Belated Merry X-mas and Happy New Year [:)]
Dec 27, 2008 | 2003 Suzuki GZ 125 Marauder
Go Gear MP3 player won't come on
mine too, i charged it all night and in the morning it wont turn on, stops on philips logo, anybody help us plz!
Apr 12, 2008 | Audio Players & Recorders
Philips GOGEAR SA6045 MP3 Player Logo
250 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
