Question about HP PSC 2175 All-In-One InkJet Printer
Psc 2175 carriage jam
My printer was working fine till we had a power surge. do you thing that has anything to do with my problem? the carriage moves to the left then stays there. there is a clicking sound and it seems to try to pull the paper in then pushes it back out. when i open the lid the carriage stays on the left. i followed all the instructions on carriage jams but nothing worked. i would greatly appreciate any help offered.
    Novelist:
  • 57 Answers
I understand that you are receiving Carriage jam error.
Please follow the below given instructions to get the issue resolved.
Here is the web document:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00309142&cc=us&lc=en&dlc=en&product=90809&dlc=en&lang=en
Just copy and paste the entire link into the Internet browser's address bar and press enter.
Please remove the All-in-One Printer from the Power Surge Protector and plug it directly into a wall Power outlet, as the surge protector may not provide enough power to printer.
Let us power cycle your All-in-one to remove any static electricity in your All-in-one.
Please perform the step given below to power cycle the unit after removing the print cartridges from the printer:
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the USB cable from the computer.
2. Wait 30 seconds.
3. Plug in the power only
4. Repeat steps 2-3 two more times.
5. On the third time after plugging the unit into power, reconnect the USB cable from the all-in-one to your computer.
Please try installing the below patch and check for the result:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-14037-3&lc=en&cc=us&dlc=en&product=90809&os=228&lang=en
If the issue persists, try resetting the All-in-one to factory defaults by following the below given instructions:
Note:
A semi-full reset will do the following:
The user settings to the factory defaults, Language and country settings on some models, Fax logs, Fax headers, Fax speed dial information.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold Cancel and the Right Arrow while plugging in the power cord.
Continue holding until it displays S Full Reset message in the front panel of the All-in-One.
This should resolve the issue.
Regards,
Lawrence
Posted on Feb 08, 2008
HP 2175 all in one. I have a carriage jam that will not clear. There is no paper jammed anywhere. I have been through all that and I have tried all the reset options but nothing works. But I notice a...
Not sure about your model. But that ribbon is very likely the cord that send information to your print cartridge. It is supposed to be slack so that the print cartridges can move left and right. If you are able to reconnect it and make it stay you should be good. Likely when it is in the furthest position it is getting too tight and coming loose again. Hopes this helps.
Mar 11, 2017 | HP PSC 2175 All-In-One InkJet Printer
I have a HP psc 2175v printer and it says i have a carriage jam. There is no paper in the printer all at this point and the ink carriage moves back and forth fine, the ink was removed adn replaced but...
The cartridges might not be moving back to there rest stop correctly, check the sponge to the far right Also The clear plastic strip running behind the carriage could be damaged or dirty. this strip tells the printer where the carriage is and if it can not read it, it will cause that message.
Hope this helps
Regards GM
Apr 09, 2011 | HP PSC 2175 All-In-One InkJet Printer
Encoder strip for HP 2175 xi
Here's the solution for fixing a carriage jam on your PSC 2315xi printer. http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00042632&cc=us&lc=en&dlc=en&product=90812 But, you said the encoder strip came off. I always understood that if the encoder strip came off, the printer was dead. I've never tried to take the encoder strip off and put it back on again to see what happens. The encoder strip is what tells the carriage where it is. Without the encoder strip, the carriage doesn't know where to go.
Jun 09, 2009 | HP Office Equipment & Supplies
Keep on getting the message to clear carriage jam. Is the printer wearing out or what?
Take out the cart. all the way check if there is any broken plastic then put it back in resetting the printer, check for obstruction of the print head make sure its free of drebris or dust useing a can of compressed air, thanks for using Fixya
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 22, 2009 | HP PSC 2175 All-In-One InkJet Printer
How to Clear carriage jam on HP PSC 1610 Printer? No obvious paper jam visible.
Dear it's the carriage jam error. so it mean that your carriage is jam not paper. so open the printer where you insert the cartridge. check whether it is jam or what . cartridge carrier is jam kindly turn off the printer and try to move the cartridge head by hand very gently and if seems to be stuck than check for anything which abort him to move freely so than might be anything like dust or else. when you get success in moving the head put some machine lubricant on the rod on which head moves and check it ok.
Dec 04, 2008 | HP Office Equipment & Supplies
HP PSC 2210 keeps complaining about paper jam. There is no paper jam!
For carriage jam try these steps
Remove both the ink cartridges from the All-In-One. also all the papars in the tray
Unplug the power cord from the All-In-One as well as the power outlet.
Now move the carriage (carriage is the one which holds the cartridge) Too and Fro till you feel the carriage is moving smoothly.
Then insert the cartridges close the access door.
Plug the power cord directly to a wall outlet without surg protector.
Before connecting the power cord to the All-In-One press and hold the # and no 6 button and then insert the power cord, do not release the keys
until you see a message a reset (if the screen goes blank then release the keys and turn the power on)
Now try printing a test page or make a copy
Good Luck
Sep 21, 2008 | HP PSC 2210 All-In-One InkJet Printer
Carriage jam
Hi Roodi, if it's stuck (left side)? Power off printer.
Grab the carriage it & move it to the right about 2 inches.
Turn on the printer & let it do it's thing. Than print a test page.
Everything look ok?
Have more questions, feel free to ask.
Good Luck!
Mike
Apr 22, 2008 | HP PSC 2210 All-In-One InkJet Printer
"Clear carriage jam" persistent error...
2. Wait 30 seconds.
Note:
Regards,
Lawrence
Feb 08, 2008 | HP PSC 2175 All-In-One InkJet Printer
HP PSC 2175 All-In-One InkJet Printer Logo
1,379 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
