Camcorders
Problem for Camcorders
Generic problem for all Camcorders
Kyocera Mita KM 1500
By Minelle on Feb 08, 2008
I had my heatroller fix and C6 code appear and they detected that the thermistor has to be replace after everything has been repaired still the C6 code appear. Need to reset the unit. what should i do I dont know the reset method. Need help please
Solution #1
posted on Feb 08, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Still sounds like there is a problem with the fuser unit. The technician that replaced the parts should be able to troubleshoot the problem.
C6 = Fuser error. The unit is not heating up due to a bad Fuser lamp, fuse, or thermostat, or bad thermistor.
The circuit is open, and the machine won't work til the problem is repaired. Once open circuit is repaired/closed, the machine should reset on it's own after you power the machine down and back up.
Does the machine flash the C6 right away as soon as you turn it on OR, does the C6 show up after about 3-5 minutes?
If you get the C6 right away, then the circuit is open, and that needs to be fixed.
If you get a c6 after 3-5 minutes, then there is a good chance the lamp is bad.
Hope this helps.
Good luck
(sorry for the repeat, but for some reason, this site signed me out.)
Solution #2
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Hope this helps.
Good luck
Popular Solutions for Camcorders
Questions and Unsolved Problems for Camcorders
Answer
is JVC model# gz-ms130bus a good choice and will it take good still pictures, what is the resolution... (More)
Answer
I had a Sony DCR-TRV460 Digital8 Camera stolen and I need to replace it to be able to play my many 8... (More)
Answer
cant bring up recorded movies on DVD-R
Answer
I have a 1 year sakar warranty on this product and then the walmart warranty kicks in on 11/26/2010... (More)
Answer
colour shifting and and the picture is distorted like red and blue
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Camcorders Experts
Top Camera & Camcorder Repair
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
