Question about Sony KDSR50XBR1 50" Projection HDTV
Color issue there seems to be a great deal of green & yellow. Not all the time, but sometimes when you know the water should be blue its green and sometimes things that you know should be white are yellow,
  • ronf001 Feb 08, 2008
    this was helpful
  • Anonymous Apr 22, 2008
    I have the exact same problem. When I'm watching a baseball game, the baseball hats look greenish when they should be blue. The entire backround has a green tint to it.
  • 113 Answers
Good news for you this is a on going problem with this television and you are in luck. The Tv has a defective optical engine and as long as you are the orig owner of the tv sony will pay parts and labor to have this fixed even though the warrant has ran out. Go to this website to read all about it http://esupport.sony.com/US/perl/news-item.pl?mdl=KDSR60XBR1&news_id=185
Please remember to rank this response thanks
Josh
Posted on Feb 08, 2008
  • Joshua Dobbins Feb 08, 2008
    Helpful this should have been a fixya ....I told you how you get your tv repaired...a 1000 dollar repair for free this is the exact problem you have and how to fix it. Couldnt have given you a better answer.
JVC HD-56FN97 all blue colored objects are green; blue water, clothes etc. what is the problem?
Check with JVC as at least on one of these sets had these issues: wrong color, any color missing, picture upside down or backwards lettering etc and this one required the use of the computer with a jig from JVC to download to the unit itself two files.
It sounds like a firmware/software issue and if so JVC should have it on record.
I remember as we were authorized and were at first informed they would charge us three hundred for even using the jig---our owner simply said fine, we will tell the customer we will have nothing to do with this repair(nearest other service center was 150 miles, they had to give us the unit for free or end up replacing the set. My point is they are not the easiest people to deal with unless you have the upper hand with them.
Dec 11, 2012 | JVC HD-56FN97 56" Television
My Officejet 6000 E609n printer doesn't print the correct colors. The red is printing yellow and the blue and green are a lighter version of what is on the screen. I have cleaned the printer head
This is not a cartridge issue. IT is Printhead issue. Since you have done the manual cleaning, it is now time to replace the Printhead.
Regards,
Suhail
May 14, 2012 | HP Officejet 6000 All-In-One InkJet...
Wall Plate teminals have the colors of Green, Red, Black, Yellow, White, Blue, Brown and Tan. Cable has the Colors White/Blue, Blue/White, White/Orange, Orange/White, White/Green, Green/White,...
see the table on this link:
http://www.server-servers.com/ge-cat5-network-wall-plate-straight-through-cable-setup/
GE Network Wall Plate Cat5 Ethernet Cable 1 Blue 2 Orange 3 Black 4 Red 5 Green 6 Yellow 7 Brown 8 White White / Orange Orange White / Green Blue White / Blue Green White / Brown Brown
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Apr 15, 2011 | Computers & Internet
How to wire a therostat
You should have 4 wires, Red, Green, White, Yellow
On your thermostat just match up the Red to R, Green to G, White to W, Yellow to Y. sometimes the Yellow is blue instead. so Blue to Y.
If you have these four you are set.
Now some t-stats have Rc and Rh, If yours does put the Red to either one and add a small wire to connect the Rc to the Rh (jumper wire) this just tells the t-stat to use one power source for the A/C and Heat. No big deal. But if you don't jumper it you will only have A/C on Rc and Heat on the Rh depending where you put the Red wire.
If you have other colors just look in your furnace and see what colors are hooked to R,G,W,Y and do the same at the Thermostat. Good luck
Feb 15, 2011 | Honeywell Heating & Cooling
Colour codes for 83 corona, wiring stereo the colours are grey/black grey/red Brown Purple/green Grey Blue/yellow blue white/black any help would be great thanks!
Hello! I'm having a hard time reading your colors...So, I'll give you the 1983 Corona wiring...
POWER
Constant +12= Blue/Yellow Switched +12= Gray
Ground= Brown Antenna= Black/Red
Illumination= Green
SPEAKERS
FR+ Light Green
FR- Blue
FL+ Pink
FL- Purple
RR+ Red
RR- White
RL+ Black
RL- Yellow
Guru...........Saailer
May 30, 2010 | Pioneer AVH-P5700DVD Car DVD Player
Not able to get red tones on TV
the problem is at the crt base .there r three red,blue n green o/put.verify if there is dry in the soldering n check the red cathode voltage it must b around 150 .if not then check the resistor that feeds the red o/put.it could b 12 to 15k. all crt have 3 driver color red blue n green,whenever one driver not working the color changes.that wat happened to ur tv now i do not know wat model u have.the drivers may b transistors or now its ic that r being used like tda 6103q.best of luck
Jan 03, 2010 | Toshiba 27AF45 27" TV
When printing a photo has a yellow/green tint. All other functions work it prints and scans great. Just have a problem with printing photos.
Possibly it is running low on Blue ink - because colors are usually a mixture of inks - for example green is made from blue and yellow - if an ink runs low it will print the available colors or substitute the next available color.Probably if it prints green yellow - then it has no blue available to make the right shade.
Oct 26, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Akai LCT2701TD
Unplug your TV for a while and see fi you are getting the same issues after you plug it in. If it works after, then you have an overheating issue with the power supply or main board.
Let me know if you need further assistance.
Oct 30, 2008 | Akai LCT2701TD Television
Ink issues Samsung CLP-510
Some paper tints can cause problems with color images, so make sure that you're using plain white paper, not another color such as beige, yellow, or blue. Even an off-white shade can affect your colors.
In addition, paper type can slightly influence your ink color. Highly absorbent papers can draw in the ink so quickly that the printed image may seem dull or a little washed out. If this is the case, try a coated paper that is specifically intended for color printing. If you're printing those important family vacation photos, use a good-quality glossy paper.
If your colors are way off, you may be running out of one or more ink colors. For example, blue and yellow are mixed to make green, so if your grass seems blue rather than green, you may be running out of yellow. Check your ink cartridges and replace any that are low or exhausted.
Thank you, & post back if you still need assistance.
May 07, 2008 | Samsung CLP-510 Laser Printer
Yellow hue
1)Please verify your model # from back of set......
2)Reduce the color to minimum or tune in a black & white chan.
you should see gray, not yellow hue
3)Remove lower front grill cover & access panel.....locate the
focus / screen control block...turn blue screen control slightly
CW......red,green and blue must mix to equal gray
4) reset color to normal level.......reassemble
Dec 22, 2007 | Toshiba 57H82 57" Rear Projection...
Open Questions:
Sony KDSR50XBR1 50 black screen, no faults! Lamp working, fans OK Sony KDSR50XBR1 50" HDTV: The light engine was working fine before the fan quit starting on it's own. After disassembly, cleaning and lubrication of the fan, I have no errors but the input display or menu options will not post on the screen. The lamp is on but seems to either be projecting a solid black picture, or not be at full brightness and there are no faults. I have a solid greed LED on top, but can get no picture. Sound is fine. What should the lamp voltage be at operating mode? I have tried reseating connectors and pushing on the wires to make sure the connectors seat. This is baffelling because the lamp fired fine for 1 second before the stuck fan issue was corrected and I have no faults now after lubricating the fan. I'm going to check connectors again today as a triple check; as I did remove the power supply. The TV has been reset per instructions in the book. Any advice would be much appreciated but I cannot believe it's the OB as it worked fine before the fan quit and it's about 14 months old. I'm thinking something may not be assembeled correctly, but everthing seems to be pretty idiot proof for re-assembly. Also the menu or input banners will not post. I have 2 new lamps, so it's not that.It seems to be stuck in somne black screen mode. The large fan does start by itself now after cleaning and lubrication, therefore no fault blinks. Please help!!!
Mar 01, 2017 | Sony KDSR50XBR1 50" Projection HDTV
Sony KDSR50XBR1 50" Projection HDTV Logo
126 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
