Question about Onkyo TX-SR605 Receiver
Onkyo TX-SR605 video problems
Am on my second onkyo SR605 receiver as well. I have hdmi cable from my direct tv cable box to the reciever and hdmi cable from the receiver to a sony 32 inch 720p television. What happins is the tv will get a little snowy then horizontal lines appear then the picture turns a pink purple color then maybe greenish then no picture for about 5 to 10 seconds then the picture will come back to normal. This could happen after an hour of watching a great picture. When bypassing the SR605 no problems appear. I have even swapped out hdmi cables. Any help is appreciated.
Bypass most reviews say video area is still alittle shaky
Posted on Feb 08, 2008
I am trying to get the amp working through my tv using HDMI leads. I have no HDMI out on my tv so I used the lead from HDMI 1 on my tv to HDMI out on the amp. The set up menu appears on my tv but no...
Contrary to the instructions included with most AVR's...
You don't need to take video out from the TV to the receiver. Once it gets to the TV it has found its ultimate destination.
And you don't NEEDS to GET audio FROM a TV either, unless it tunes stations from its own antenna.
Otherwise the SAT/Cable box can provide analog audio to the TV for watching lo-fi programming like news with the Onkyo OFF; and you can run digital multichannel directly to the Onkyo for its special treatment.
Running either hi-end audio or high-end video to a device that doesn't absolutely need it wastes expensive cabling and introduces a couple more connections to worry about.
http://www.retrevo.com/support/Onkyo-TX-SR605-Receivers-manual/id/2526bh742/t/2/
Feb 14, 2011 | Onkyo TX-SR605 Receiver
HDMI signal cuts out for a few seconds constantly from receiver to television. It does it when switched to cable box and the roku box. Onkyo TX-SR606 Scientific Atlanta Cable box thru HDMI Roku Box...
Mine did the same thing where the screen would go black for a few seconds and then the picture and sound came back. I would try (1) switch HDMI cables, (2) try a different HDMI input in the back of the receiver, (3) try different input in the back of the TV. None of these seemed to work with mine. I finally ended up running the cable box direct to the TV and only run the audio through the reciever via coax or digital. No more problems. I think the HDMI inputs in the back of the reciever have a problem continuously carrying the signal if it is the leaset bit weak.
Sep 08, 2010 | Onkyo TX-SR606 Receiver
Sound won't play through Onkyo TX-SR605 when using HDMI
The chances are that you have selected an incorrect sound setting or not switched it on, for the HDMI you are using. With Onkyo receivers each connection will have it own settings for video and sound. You just need to look in the manual as to how to select the settings.
May 08, 2017 | Onkyo TX-SR605 Receiver
I have an Onkyo TX-SR605 AV receiver that just stopped outputing video to my Panasonic projector. I have connected other devices directly to the projector and video is fine, so the problem is not the...
Goof information. Have you eliminated or proven the Onkyo as a cause by going direct to the projector? Try another Input and/or Output. It's best to know which component is broken and if it's limited to a specific subset of its function.
Settings are also indicated. Run through the video setup again. If it just stopped, what preceded it?
Nov 27, 2009 | Onkyo TX-SR605 Receiver
Simular Problem
HDMI must be hooked directly to the TV and optical or digital coaxial to the receiver. Your receiver has 1.1, 1.2 or 1.2a HDMI firmware and hardware. There is no fix for this issue w/out a new receiver that has 1.3b firmware. All receivers on the market have this issue, not just Onkyo. HDMI comes directly from HDMI. And there customer support !@#$%^&*()!!! Sorry for the bad news! but that's the fix. Hope this helps.
Aug 12, 2009 | Onkyo TX-SR605 Receiver
Onkyo TX-SR604 provides audio thru receiver but no video on Bravia LCD when satellite receiver signal is sent thru any of the Onkyo HDMI connections to tv, however if I connect up my Samsung DVD recorder...
easiest fix is to take all hdmi straight to tv. then come out of tv with optical cable to your receiver. that way what ever your watching will automatically be sent to the receiver thru optical. you even will get dolby dig. also you can have audio from your tv when you dont want to use your surround. keeps receiver on one input also.
Jul 02, 2009 | Onkyo TX-SR605 Receiver
Onkyo TX-SR606 Reciever - 20 sec after power on, screen is green
The HDMI version in your receiver is 1.1 or 1.2 which will not pass video as it should. It's not Onkyo's firmware at issue, it's HDMI and in all receivers up to 2008 model year this is a very heated problem! The only fix is to run FIOS directly to the TV via HDMI and run it's audio to your receiver with Digital Coaxial or Optical. Hope this helps
Jun 11, 2009 | Onkyo TX-SR605 Receiver
Onkyo TX-SR605 Receiver HDMI Issue
How good are the hdmi cables that you are using???
Nov 26, 2007 | Onkyo TX-SR605 Receiver
New home theater setup- no signal at tv using onkyo tx=sr605
Could well be the quality of your cables. if you have high end cables the consult a service agent. if you have the cables that came with the products, go and get some better ones.
Nov 04, 2007 | Onkyo TX-SR605 Receiver
Onkyo TX-SR605 Receiver Logo
518 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
