NEED A PART
I am looking for the main circuit board for a phillips 61" projection tv, model 9P6040C104, built in 2000. ThE part number i need is APD028C003. Thanks for any help you can provide.
  • kelleyshaw Feb 08, 2008
    Thank you very very much, I will contact them.
  • 113 Answers
The part number actually is 00APD028C003 and you can get it from Pts electronics. They had it available when i just checked. They can also rebuild the one you have this is another option.
Posted on Feb 08, 2008
Philips Magnavox 9P6040C104 Image Issues
If glycol issue screen will not be black and white but yellow etc.
(I can tell you simple way to know if glycol is bad)
This is toxic stuff so not likely a do it yourself repair.
If convergence issue-it will look 3d etc--
Kits are sold by model number on the internet for this--need to be able to get at the parts and be able to do good soldering etc.
Apr 15, 2012 | Televison & Video
Just curious as to how much a philips magnavox motherboard would cost for a 32 inch tv.. installation included
Need the model number of the set to even begin to answer your question since there are so many different Phillips 32 inch models and they all have different components and circuit board designs.
Jun 18, 2011 | Philips Magnavox 51MP392H Rear Projection...
My 61" Hitachi UltraVision has
hello my name is rico, you have bad convergence problem. you need to replace the stks inside the tv, and look for colder on the boards. you gonna need a gun solder, solder, chawick, 2 stks(look in the tv for the number loooks like stk392-120 o something like it) look for bad fuses. that should fix your problem. if you need more help let me know at 602-810-7149.
Jan 07, 2011 | Hitachi 61SDX01B 61" Rear Projection...
I'm getting an overlapping of two colors on the screen.
It is common problem with rear projection tv and 3D type picture problem occurs due to failure of convergence output ICs, replacement of convergence output ICs will fix the issue and tv will again show correct converge picture as before.
Let me know tv model number written on back of tv if you want to fix tv by yourself as it needs soldering parts in circuit board expertise and if you feel uncomfortable working in tv circuit boards than local tv repairman will do this job for you.
Thanks.
Jun 30, 2010 | Hitachi 61SWX01W 61" Rear Projection...
Need part no. for cr14710 tv model no. D61130yx1
Part is marked as no longer available--you may be able to find it on the Internet-----------
RCA part number is 243846 (suggested list is $4.95)
If you cannot find it I would suggest you contact PTS electronics--they repair/rebuild all kinds of circuit boards and may be able to help you.
SD TECH
Oct 03, 2009 | RCA D61130 61" Rear Projection Television
IC Chip?
Its a common problem with this model. Goto www.TvRepairKits.com to get the parts and instructions to fix the TV.
Sep 06, 2009 | Philips Magnavox 9P6034C 60" Rear...
Projection tv
the blue gun is not working properly which explains the dominance of green and yellow colors. you need to look after dry-joints on the blue gun circuit board, sometimes oil leakage from the lens may also affect the board
Mar 26, 2009 | Philips Televison & Video
I have a 52" projection tv it is a phillips. one day i came home and i went to turn it on. now what do i do it wont turn on?
In the absence of any warnings of impending failure, the main power supply has probably failed.
This is likely to be a separate assembly (board) that you could replace on your own. If you remove the back lower panel, follow the AC cord to locate the supply, get the part number from the assembly (there may be two different numbers). The bare circuit board may have a number that was printed in the same manner as the component identifiers and then another number on a label which might contain a 'revision' number too. This board is probably not terribly tought to repair with the necessary instruments but you would be better off buying a new board and then looking for someone to repair the other since it will probably be needed when the replacement fails.
Feb 22, 2009 | Philips Magnavox 51MP392H Rear Projection...
TV keeps powering off and
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board..
Jun 03, 2017 | InFocus Televison & Video
Televison & Video Logo
130 people viewed this question
Top Televison & Video Experts
