Question about Sony KV-27V66 27" TV
Black Bar Through Centre of Screen
Plays DVD perfectly
  • Talorcreek Feb 08, 2008
    when TV is turned on, white lines, scrambling, small white lines flashing.Piture rolls, stops rather quickly, & then flashing white lines. Shadowy Ghosts from other channels. (slivery in color)
  • Talorcreek Feb 09, 2008
    Thank you for your help! I Decided to replace the TV. Bryant.
    Genius:
  • 1,665 Answers
1. Adjust the antenna for better reception.
2. Some electronic euuipment can create electrical noise, which can interfere with TV reception. So move TV away from other electronic equipment.
Posted on Feb 08, 2008
  • 113 Answers
The black bar you had mentioned in your title points to a pulse on the jungle Ic. The black bar is prob intermittent and does not happen all the time. You can replace the Jungle Ic and it will most likely clear up a lot of your prob this is IC301 on the A board and the part number is 8-752-095-96 personally I would replace the A board to make sure the whole prob is taken care of this is part number A-1298-841-A it would be more apt to fix all of your problems the A board will run you about 175 dollars so it might not be worth it. The Jungle Ic on the other hand is about 25 dollars so its worth a shot.
Josh
    Brigadier General:
  • 6,966 Answers
It may not be the TV but rather interference, have you checked your cable connection?
One way to verify if it is the TV or your cable is to install an old VCR using its RF OUT connected to the ANT/Cable IN of your TV. Play a known good video tape and set TV to either Ch. 3 or 4. If problems persist, it is the TV (possibly tuner) if not, it is your cable connection.
Hope this be of initial help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
    Genius:
  • 3,422 Answers
If you observe horizontal lines then the problem is with Vertical amplifier unit and needs to be replaced.And you also said that the picture is Ghost then the problem is with STK IC'S even that needs replacement and you have to call a technician to get it done.
However you can try this method once, Do the reset test Disconnect the power cord for 4 hours. Then when you power it back up the internal soft codes will automatically reset to factory defaults.
Goodluck,
Please don't forget to rate me as fixya..
  • Priya darshan Feb 08, 2008
    So finally i just want o say that since you don't have a problem with dvd then It is a malfunction of the vertical blanking circutry which is
    supposed to blank out while retracing to keep the horizontal retrace
    from showing during that period. It is a function of the 'jungle chip',
    one of the main processors in the tv. It requires a tech to take
    measurements to identify the correct malfunction as there are many
    parts associated with this process.
    I just found out that the problem is not with your STK IC"s..
    It is malfunction of vertical blanking circutry..
Freeway indash DVD
u need to switch function screen to dvd screen. Button is on front of unit to scroll through screens.
Dec 14, 2008 | Kenwood KVT-817DVD DVD/CD/MP3/WMA 7"...
DVD-RP56 DVD Player Problem:
You might have changed the video setting to something else like "progressive" mode so try changing it back otherwise make sure it's not a s-video cable connection causing it.
Oct 05, 2008 | Panasonic DVD-RP56 DVD Player
Dvd plays red for unknown reason. tdpjones@hotmail.com.
i have a similar problem with mine it works perfectly for about 3 min when pluging it in then the dvd half of it tuns black and white and the settup menu dosent set anything help someone
May 02, 2008 | Sansui VRDVD4005 DVD Player/VCR
Change screen on portable dvd
you should have received a warranty with it take it back to the store you received it from and work things out
Jan 24, 2008 | TruTech PVS12701 Portable DVD Player
Loss oF color
Bad chroma processor...accordianman
Nov 03, 2007 | LG V181 DVD Player/VCR
Jvc xv-s302 only plays black and white
Look at the back of the DVD player it should have a NTSC & PAL switch ,but remember to switch off the dvd player after you change it over to NTSC or PAL
i hope this will help you
craig:)
Jul 01, 2007 | JVC XV-S302 DVD Player
LCD Screen Blank
hi, this usually happens with the ribon cable which is giving power and signal to LCD is becoming loose or damaged due to folding..since the LCD wiring replacemet is a skill needed task i recommend you to give it to the nearest service centre so that your cam will be ready for future shots all the best my friend sreejith
Jun 26, 2007 | JVC GR-DVL9000 DV Digital Camcorder
Televison & Video Logo
49 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
