Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Lights flashing but machine not working
Hi my machine is only one year old and rarely used but machine not working. power light wash entrance and rinse hold lights flashing.water starts to fill but stops after a minute or so. any help or advice please.
  • 1 more comment
  • Anonymous Jun 01, 2008
    very similar. Flashing lock button (red) and green rinse button. Not the connectors it appears. machine does make a noise but fails to work. A kind of churning sound.
  • jacb Jun 12, 2008
    i keep getting the pre wash light flashing which according to the manual means that there is not enough water pressure but the machine will take in water only from the pre wash side of the drawer not the main side, i have checked in and out water supply no problem emptied the filter
  • Anonymous Mar 18, 2014
    30 and 40 temp lights flashing and washing machine stops working
  • 75 Answers
Hi there i would check the connections to the heater and ntc both can be found behind the lower inspection cover at the rear, UNPLUG FROM MAINS FIRST AS LIVE PARTS EXPOSSED BEHIND!!!
Posted on Feb 09, 2008
My 1 year old washing machine is not working apart from from a couple of lights flashing abd beeping
Hi just read your posting.Now when your machine is beeping a series of lights will light up.They will be in a row of 8 lights.Starting from left to right which lights are lit,Is it the 2nd and 4th or the 1st and 7th ---etc---?Also please supply the model number which is on a sticker which is located on the back of the machine ,top left.Looking forward to your reply.
Sep 09, 2010 | Fisher and Paykel Washing Machines
Indesit Widl 102 Flashing lights, wont turn on
Hi
Thanks for using FixYa. It seems to be the issue with the Thermal Fuse going bad and/or its panel that is going bad. To start with check the Thermal fuse which is mounted to the exhaust duct inside the back cover panel. Please do accept the solution if the issue is resolved or post a comment with a more detailed question including the manufacturers name and model no# for your dryer so that I can further assist you.
Thanks
Rylee
Jun 14, 2010 | Indesit Dryers
All lights flash and error E90 shows on my Zanussi ZWF1631 washer
e90 is a cable problem linking main board to user board on the front
Jan 12, 2010 | Washing Machines
Control panel lights ALL flashing on hotpoint aquarius washing ma
my lights are all flashing on my control panel, its takes water in then pumps out straighaway doesnt wash or spin i have changed the brushes so i know it isnt that please help it only about 3 years old
Dec 06, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Bosch wfl 2000 problem
it is not doing what it's supposed to do.
power is not routed properly - replace the board
Jun 13, 2008 | Washing Machines
WF540 - Won't work and rinse hold and wash enhance lights flash?
Hi ya, just a quick suggestion, have you cleaned the filter on the front of your machine?? My machine did this and it was only when i cleaned the fluff and the 5 pence pieces from this filter it stopped, Hope it helps
Dobby
May 11, 2008 | Hotpoint Aquarius WF000 Front Load Washer
I have a beko WMA 1715s washing machine, it will not work, the pre wash light is just flashing on and off, it will let you select a programme but when you press start it wont work, please can you help, i...
Either the child lock is on - press and hold quick-wash and anti-crease, at the same time for three seconds.
Or your machine need re-seting
Turn power button off (not at wall)
Select 90 degree wash
Press Start and Cancel button down at same time for 3 seconds and turn power button on whilst still holding buttons down - Start light will flash.
Leave power on.
Select any Spin position.
Press Start and Cancel button at same time again for 3 seconds - other buttons may start to flash - if they do, press Start and Cancel button together again for 3 seconds.
Machine should be re-set ready for use.
Apr 26, 2008 | Washing Machines
Aeg 76669 oko lavamat machine not starting all six lights [pre wash, main wash, rinse, rinse , spin, and end] flashing machine three years old just successfully completed wash cycle, loaded up for next...
I have had the same problem. If you switch the machine to off and then to cotton/linen 95, then press at the same time prewash, soaking, qick wash and stain buttons for 10 seconds switch it off. When I switched it on it worked.
Jan 10, 2008 | AEG Washing Machines
Hotpoint Aquarius WF530 LEDs flashing
I cannot tell from your description what the error may be but here is a list of reasons;
https://www.whitegoodshelp.co.uk/hotpoint-aquarius-lights-flashing
Jun 13, 2017 | Hotpoint Washing Machines
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
148 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
