Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Defrost side by side fridge
I left fridge door open over night. fridge is warm, freezer is fine. can i defrost the fridge only if there are seperate controls for both freezer and fridge?
  • Anonymous Mar 12, 2014
    how to defrost the thermastat between the freezer and fridge
  • 958 Answers
No you can not. there are no separate defrost control for freezer and fridge. the evaporator is located in the freezer section and it is supposed to defrost automatically. what is the problem in the first place?
Posted on Feb 12, 2008
Freezer is frosting and refrigerator is warm.
As far as your freezer frosting up, sounds like a door seal problem, run your fingers along the seam of the door seal, there should be no splits/holes in the seal.
As far as the refrigerator either there is a secondary fan motor, or there is a obstruction blocking the air movement, if the freezer has a bad seal, its suspect ice is still building up.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
Jul 08, 2013 | KitchenAid KSRV22FV Side by Side...
The Refrigerator side is warm, and the freezer side is not making enough ice,and the ice is not solid
Possibly the defrost heater could be faulty or the defrost thermostat or defrost thermistor (sometimes called D-Sensors I believe). If you turn off the fridge and let it defrost itself for 12 hours and then start it again, it may work fine for a week or two (or may even be totally fine in case you left the fridge or freezer door open by accident).
Oct 05, 2012 | Nor-Lake Norlake Refrigeration 4' x 6'...
Refrigerator starts cooling mainly when I open the door
Put a thermometer in both the freezer and the fridge. Fridge should be around 40F if not a little lower, but should stay above 30F.
Freezer should be just below 30.
Feb 09, 2012 | Refrigerators
I have a Whirlpool ED5FHGXNQ00 side by side.for a while it started to show signs of warming up in the fridge side.i noticed the dust built up underneath on the coils and cleaned it.i left it of*** night to...
I have a Whirlpool ED5FHGXNQ00 side by side.for a while it started to show signs of warming up in the fridge side.i noticed the dust built up underneath on the coils and cleaned it.i left it of*** night to defrost.have not plugged it back in yet.but in the freezer behind the panel there was ice build up to the right of the evaporator fan on the plastic scroll.i cleaned that upturned it on and noticed that there was very little air coming through the top air scoop vent in the fridge side.when I open the freezer door it allows more air though(probably to compensate).anyway I read alot on this issue and some say it's the defrost timer boardsome thermostat.the compressor stays pretty hotbut the freezer works fine.please help.
Jul 07, 2010 | Refrigerators
Samsung RL36SBMS top Fridge. The problem is that the fridge has stopped cooling altogether. The electricity is getting to the appliance, the light is on and a low humming noise (fan maybe motor?) can be...
if your freezer is fine, try a total defrost in the freezer and fridge over night and retry,sound like ice is blocking the air duct from the freezer to the fridge caused by the freezer door being left open at some tage of its not going into defrost,if it comes right after defrost but returns in a few weeks then you need a technicn to replace the defrost element
Mar 04, 2018 | Refrigerators
My son got into my fridge lastnight-left open, now won't cool
evaporator coils is probably frosted from condinsation.shut door set at normal setting and give some time.
Jul 26, 2009 | Frigidaire Freezer Refrigeration White...
Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Nov 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
JENN-AIR BLOWS WARM AIR
hi thanks for the question the freezer is more than likely frosted up now with the door left open the drain hose from freezer is clogged shut down let thaw remove panel at the back of fridge allow 24 hrs to thaw clean out the drain tube re level the fridge so that if the door is left open the door will close by its self raise the front legs to achieve this thanks the appliance doc
Aug 12, 2008 | Jenn-Air JCD2389G Side by Side...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
272 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
