Question about Philips 37PF7320A 37 in. HD-Ready LCD Television
Philips 37pf9631d/37 hi, we are not able to turn on our tv. the stand by light is flashing and we can not turn it on . could you please help us in this matter.
  • 3 more comments
  • fashtanghi Feb 08, 2008
    6 times at the time
    hi dobbins,
    it is flashing 6 at the time.
    thanks josh,
    then i have to call for a technician first and i will tell you about rating!!!
  • Anonymous Feb 08, 2008
    flashing red light the remote will not work and the power button on tv will turn it on and the green light comes on a couple of seconds then goes off and the flashing red light apears again
  • Joshua Dobbins May 11, 2010
    How many times is the light flashing?
  • 113 Answers
Alright,
6 flashes is viper not starting up the failure will be in one of two places. You could have a bad power supply all of the voltages would need to be tested on this board to rule it out. Especially checking the 5 volt lines coming off of it. If the power supply checks out you would be looking a a defective viper on you small signal board. Power supply will cost about 200 dollars SSB on the other hand is about 1000 dollars.
Hope this doesn't ruin your weekend.
Josh
Posted on Feb 08, 2008
I have a Philips 37PF9631D/37 which has 6 times blinking red light syndrome. After opening up it appears there are two 250V 820 uF capacitors that may be faulty. Are these safe to...
Look for bad capacitors on power supply board they will be vented or swollen on top.
1000uf 16v 3300uf 10v 330uf 10v. Look for boards on shopjimmy.com
Also check the fuse on the inverter board it maybe bad.
Oct 15, 2011 | Philips 37PF9631D 37 in. LCD HDTV
Where can i find a service manual for the philips 37 pf9631d tv i need a schematic for troubleshooting thecomponents on the boards
What type of defect? most of these are board level repair.
you can purchase the manual from encompass electronics if you need it.
Feb 18, 2011 | Philips 37PF9631D 37 in. LCD HDTV
I went to turn on my tv tonight and it started to come on - then did not.. a blinking red ligh is where the green light usually is - I tried to unplug it and re plug it in.. no help
When you turn the TV on, does it attempt to come on and then off? Does the light go green when you attempt to power up and then goes red?
Jan 31, 2011 | Philips 37PF9631D 37 in. LCD HDTV
Looking for a replacement stand for Philips 37PF9631D/37.
part number - 313912877741 you can find them probably on ebay or some other internet site
Jan 06, 2011 | Philips Televison & Video
Philips 37PF9631D 37 red light blinks 6 times
Code 6 is a I had a similar problem with my 42 in Philips LCD HDTV. Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired ofcourse) and found four bulged capacitors on the PSB. Many major electronics companiesPhilips/Magnavox, Sony, Panasonic, and others were sold capacitors that failedin 2-5 years instead of 10-20. Thecapacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in allsorts of devices and cause a wide range of failure problems. Here are some options for you. 1. Have it fixed by a professional $$$$$$$??????? (Is itunder warranty?) Remember, TVs CONTAINHIGH VOLTAGE AND CAN KILL YOU! Do this at your own risk. 2. Open your TV and find PSB. (The board that the power cordplugs into) Check for faulty caps. If you find some (bulged or leaking) bad capsreplace the entire board. The entireboard costs around $250 right now because they are in high demand right now.They can be found online. I would definitely shop around though. 3. Remove and then replace individual faulty caps. This takes some soldering skill. Caps are inexpensive and if you can take care of it yourselfit will save you hundreds. This may be your problem. If you determine that it might be. I have a Tip/How TO tutorialon this site that may also help. Itgives step by step instructions for replacing caps on PSB #715t2432-2. If this isyour board you are in luck. Here is theLink: Fixingthe Philips Turns/shuts off on its own problem. I'm working on uploading pictures to helpguide people though the process as well. Let me know if I can do anything to help. Hope this helps and if it does please rate itaccordingly. Good luck.Kaufman605
Dec 16, 2010 | Philips 37PF9631D 37 in. LCD HDTV
Phillips 37 LCD Service Manual
http://www.eserviceinfo.com/most_popular/list_5800.html
https://www.manualsparadise.com/Sho...model=M31429247
https://www.completeservicemanuals.com/panasonic/digital-camera/lumix-dmc-fz5-service-manual/prod_86.html
http://www.user-service-manuals.com/Sony/UP.shtml
http://www.schematicsforfree.com/
Mar 09, 2008 | Philips 37PF9631D 37 in. LCD HDTV
The TV is in some kind of protection mode, the blinking LED show you an error code.
Try pressing 062596 and then press menu button (do these in quick motion, don't let them to time out while keying)...see what happens
Well I think that if you would have a service manual for this set that would help a lot, I can send it to anyone who wants it via email/gmail. Let me know if anyone want one.
I also heard that this problem appeared with some people because the of the burnt fuse in the TV. To fix that it has to be taken to the tech shop. mecry.gif
And yes I also heard about this issue many times, seems like this TV set is very popular with this kind of problem.
Dec 05, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips 37PF7320A 37 in. HD-Ready LCD Television Logo
144 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
