Question about Amana ALE643RB Electric Dryer
Accessing the heating element
I have a ALE643RB Amana dryer and believe the heating element has went out because the dryer will not heat anymore. I have taken the control panel off the top and all the screws out on the back and the bottom edge, but am still not able to get the shell off the dryer. How do you get to the heating element?
  • yggee7430 Mar 12, 2009
    I have a Amana LE8407W dryer and can not get to the Heating element by removeing the screws from the bottom and the top is removed and front door is removed. What else must I do?????
    Thank you if you can help?????
Posted on Oct 18, 2008
Amana dryer not advancing on auto
Make sure the vent from the dryer to the outside is clean.
Reduced air flow can cause your symptom.
You can remove the vent hose from the dryer and operate the dryer in the automatic cycle.'
If the timer advances you know the vent needs cleaning.
Clean the lint filter housing also.
A flashlight helps to see all the way down the housing.
Jan 20, 2010 | Amana ALE643RB Electric Dryer
Replace electric heat element in Amana dryer
You can find an exploded view of the dryer on searspartsdirect.com. Looks like you access from the rear service panel.
Dec 11, 2009 | Amana ALE643RB Electric Dryer
CANT FIND WHERE THE FLAME IS
Well , sounds dumb, but you said its a electric dryer! there is no flame, you have no gas. If its electric it has a heater element that glows red for heat. You need 220v to run heat.
Dec 01, 2009 | Amana ALE643RB Electric Dryer
Where is the fuse link located on a amana eletric dryer? my nephew hooked up the electrical plug wrong every thing els works now but the heat
it is right next to the heating element in the lower rear of the unit part# AP4048636, you will need to remove the heater duct on the rear to access it
Nov 14, 2009 | Amana ALE643RB Electric Dryer
Dryer takes 2 to 3 cycles to dry clothes
check temp coming from vent back of dryer should be 160
Aug 09, 2009 | Amana ALE643RB Electric Dryer
Amana Dryer model # LEA60AW. Dryer runs but no heat.
check the heating element and the high limit fuse
Jul 10, 2009 | Amana ALE643RB Electric Dryer
AMANA LEA60AW ELECTRIC DRYER, DOES NOT DRY CLOTHES FULLY
Your heating element is dying. A new element runs 'bout $40. It'san easy fix. Couple screws .
Mar 05, 2009 | Amana ALE643RB Electric Dryer
Amana electric dryer will not heat/ LEA60AW Everything works fine but no heat...have cleaned all lint from inside the dryer by taking front panel off. What else should I check.... I noticed it wouild come...
Check for 220 Volt at the heater entrance to the heater box (accessible from picking up the top on most models). If you have 220v there the heater element is out. If you don't have 220v on the terminals of the heater the problem is in the controls. The fuse link, the timer contacts, the centrifugal switch on the motor, and the heater safety thermostat and operating (s), are all suspect and have to be eliminated 1 by 1. Hope this helps. With any luck all you need is a new element. Clean the duct out while replacing the heater if so because the main thing that causes heater element burn out is low air flow a kinked Dryer vent hose, lint, and plugged up fan on the motor are the 3 main causes of low air flow. If yours has little holes in the inside cabinet these can get clogged with lint also and cause a problem. Hope this helps and please rate me accordingly Thank you and good luck.
Feb 23, 2009 | Amana ALE643RB Electric Dryer
Amana ALE643RB Electric Dryer Logo
334 people viewed this question
Top Amana Dryers Experts
Tim Whalen
Sal De
Marvin
Marvin
Are you an Amana Dryer Expert? Answer questions, earn points and help others
