Suspension pads? where are they do you have a good diagram?
The drum shakes violently during the spin cycle. It is on a concrete floor. It has been in its location for 18 years and have never had this problem. It is a direct drive washer (a solid back panel) The springs are fine. I just can't figure out these pads I am supposed to check. And I don't know how to remove or replace them. I don't know how to check the spring brackets. I am looking for a good diagram of these parts. Then I would know what I am doing.
  • mitosrule Feb 12, 2008
    Thank you for the help. It wasn't exactly where I needed the help I can't tell what is what. I need a good chart or diagram of what each thing is
  • Kurt Ness Apr 12, 2008
    took my frigidaire front loading washer appart to see if neckace was in the boot infront of the pump. it was not. put everything back and now when the washer spins dry is shakes violently. What do I do?
  • 46 Answers
Most suspensions on machines use 2 springs on top of the drum and 2 suspension legs on the bottom. ( similar to a car shock absorber) just make sure the bottom concrete counter weight is not loose , this will cause violent a shake
Posted on Feb 08, 2008
The drum shakes violently and is very loud during spin cycle
There are 2 shock absorbers/springs attached to the drum. If one of them breaks it will cause a loud banging noise when you wash heavy loads. This is an easy fix. The part is about $22.00 and it is accessed throught the front bottom panel.
Dec 01, 2009 | Frigidaire GLTF1670A Front Load Washer
My washer shakes violently during the spin cycle
Make sure its level on floor, Check also suspension legs and securing springs...
Nov 10, 2009 | Washing Machines
My kenmore he2t is very noisy due to the spin cycle. It shakes the whole upstairs
My HE2T was making a horrendous sound during the spin cycle. It was making a loud clacking sound and the machine was moving all over the place.
There are two things to check. The first is that the feet are on the floor and the machine is level. The second is a bit more complex. Remove the three screws that hold the lower panel. Underneath the drum on each of the four corners are suspension rods. One side is attached to the drum and the other side is bolted to the bottom of the washer. My bolts loosened up which allowed the suspension rods to clack back up and down as the drum spun. You'll need to tighten those bolts very tight and then give it another try.
Attached on the inside of that cover is the troubleshooting guide. There is a manual diagnostic mode and you can step it to the spin cycle so that you can test the spin balance without having to run through a full cycle. Make sure you have some clothes in there during the test.
Oct 25, 2009 | Kenmore Washing Machines
Washer shakes as if unbalanced during spin cycle I think that part of the suspension has failed, the result is the washer shakes violently during the spin cycle but otherwise seems to perform reasonably...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Whirlpool / Kenmore top load, direct drive washers use a number of springs between the main suspension plate and base assembly as well as friction pads that are designed to minimize shaking.
See the Whirlpool / Kenmore service manual for top load washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It's likely that one of the springs or pads has broken or come off.
See the following for how to remove the cabinet to get at these.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Oct 24, 2009 | Washing Machines
Front load washer shakes violently during spin cycle
On something like this you will need to remove the washer wrap to inspect the suspension springs & base assembly. Please see the link provided for accessing the inside of the washer. Be sure the shipping pins have been removed. The tub should float freely.
Apr 03, 2009 | Washing Machines
I had this problem as well. I called dealer and Maytag. They made an appointment and stood me up several times.
I finally went to place that sells refrigeration equipment and bought an anti-vibration pad. It's a 12" square waffle pad used under large equipment to prevent them from vibrating loose on connected piping. I cut it into 4 pieces and put one under each corner of the dryer. Problem solved, in fact it worked so well that I stacked dryer over washer, placed pads between units and have not had a problem since. I also gained a lot of space in my laundry room as well.
Mar 04, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washing machine shaking on spin cycle
what is the brand of the washer along with the model nunber
Apr 12, 2008 | Washing Machines
Whirlpool LHW0050PQ Front Loading Washer VERY NOISY during spin cycle
remove the top access panel 3 screws in top rear.
now look around and push on the drum from top
it has suspension shocks and springs like your car they should resist any movements.
look/wiggle the concrete balance blocks , no cracks or loose.
inside the tub are the arm solid /not loose.
run it with the top open what do you see/hear and where
look under the rubber flap in front did anything get under the tub
Dec 29, 2007 | Whirlpool LHW0050PQ Front Load Washer
Kenmore washer shakes violently during spin cycle
syrny,
Not sure what you did, exactly. First, does the machine shake when spun empty...and then with water only? If so, you have probably failed to tighten something or misaligned something. Go over your work.
No shakes? Rearrange your load. You may have a pair of heavy wet jeans which is throwing the whole thing out of kilter. It only takes about a half pound of sodden clothing to do this.
Nov 26, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
383 people viewed this question
Top Washing Machines Experts
