Question about La Pavoni Lusso PL-16 Espresso Machine
La Pavoni Losso Espresso machine not working.
When I turn it on it make sound like it is working but no water comes out. Maybe few drips. The light indicating that the water is ready will turn on.
  • pavel009 Feb 11, 2008
    I did not try to implement the solution yet.
    Thanks for advice.
    Pavel
  • 46 Answers
Fill the tank with a strong De scale soulition , sounds like its blocked with limescale. REMEMBER to rinse thru clean water several times after the process...
Posted on Feb 09, 2008
Why water drop before lever raised until top position?
\\this might be caused by a worn piston seal. see here how to replace seals.
dr pavoni
May 15, 2014 | La Pavoni Europiccola EPC-8 Espresso...
What causes my la pavoni europicola to make a whistling sound when it;s turned on?
Contact Authorized Service. Before their approval, don't use it or it maybe hazardous.
Apr 26, 2014 | La Pavoni Coffee Makers & Espresso...
I need to pull up very ******* the lever for water to come out.
Again sounds like the seals are damaged and or need some lubrication and a service link below to a good site
dr pavoni
Apr 04, 2014 | La Pavoni Europiccola EPBB-8 Espresso...
La pavoni stops boiling water
Run some WHITE vinegar through it, followed by plain water a few times. The heating system gets a buildup in it and requires cleaning from time to time.
Feb 06, 2012 | La Pavoni Coffee Makers & Espresso...
Espresso comes out of comes out of spout before handle is raised
Hi there, i am Mr La Pavoni and am based in Glasgow, Scotland. I service and repair these machines all day every day and basically it could be a couple of different things. If it is pre 2000 then it could either be the piston gaskets or the piston shaft has come slightly unscrewed from the piston head. If it is post 2000 then it could be any of the above but also in these models there is an additional sleeve inside the group head which may be cracked or the seal on this part may need replacing. It could even just be a tiny bit of debris on one of the piston gaskets. If you have removed the shower plate and gasket and then taken out the piston assembley then you should really replace these gaskets anyway. You can purchase the parts on my website www.theespressoshop.co.uk which are all individually priced and every part is available for the lever machines. If you require any further assistance then please do not hesitate to get in touch at domesticespresso@live.com
All the best
Mr La Pavoni
May 14, 2010 | La Pavoni Europiccola EPC-8 Espresso...
My La Pavoni Europiccola "exploded" this morning - I think it is the heating element. Is that a common problem - how expensive and easy is it to fix the machine?
Hi there, i am a domestic espresso machine engineer based in Glasgow and i specialise in La Pavoni machines. If you could get in touch with me at my e-mail address (coffeeservice@live.com) i will be able to help you but i will require some info from you about what happened. It sounds like a pressure problem or the thermostat has gone allowing the water to over boil and build up too much pressure. Pressurestat is most probable i reckon. If you give me an idea of what happened i will be able to help you. I work alongside the UK's lead supplier of La Pavoni spairs so have all bits in stock. E-mail me or give me a buzz on 0141 425 1083 and i can sort you out.
David Martin
The Domestic Coffee Service
Jul 14, 2009 | La Pavoni Pisa PA-35 Espresso Machine
La Pavoni Napolitana: the grinder works however
Yes. Inside on the top after you loosen 2 scres the coffee warmer plate comes off there is a reset switch.
Apr 27, 2009 | La Pavoni Napolitana PA-1200 Espresso...
First Cup Is Cold From La Pavoni Europiccola
If the machine works great after the first cup then it is possible that the heat for your first espresso went to heating the portafilter or the cup used to brew into, try warming the portafilter first by running some hot water through it first.
Apr 09, 2009 | La Pavoni Europiccola EPC-8 Espresso...
Our La Pavoni Lusso machine has not been used for a couple of months. We put water in to prime the pump, and nothing comes out. We can hear the pump going, and the heater indicator light is working. Any...
Try opening the steam nozzle while trying to pump the water through as this will get rid of any air locks. Otherwise it may be a build up of scale in the boiler or the pump itself. Try that and descale if you can.
All the best
LaPavoniBoy
Mar 07, 2009 | La Pavoni Lusso PL-16 Espresso Machine
La Pavoni Lusso PL-16 Espresso Machine Logo
319 people viewed this question
Top La Pavoni Coffee Makers & Espresso Machines Experts
billconfused
Pieter Vleeshouwers
Pieter Vleeshouwers
NOEL
NOEL
Are you a La Pavoni Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
