Question about Samsung DLP HL-P5663W 56" TV
Hlr5667 w I getting screen and white lines when I turn it and delayed images but backgroung is clear, it doesnt turn on when it freezes. I replaced lamp. some timeswhen i turn it on its like it trips into play in it works fine but most of the time it i have the lines and delayed picture ect. What could be wrong? could it be color wheel, power cord, somthing overheating, or is it the expensive main board? The fans are working and I dont have any abnormal blinking lights that are supposed to tell ou whats wrong. Rusty
  • Rusty D Feb 08, 2008
    thanks for the info but i meant the lines are only green could it be the color wheel i why does it shut off? Lastly why does it work 1 out of 10 times after unpluging it from the back and replugging it? It then will work all day until i shut it off again.
I had black vertical Lines. Sometimes across the entire image, sometimes partial. Came and went. Seems a dead-ringer for cold solder joints on the BGA of the DLP IC.
So i threw down $15 and bought the service manual online, pulled out the entire light engine assembly, and blew everything out, vacuumed etc.
I then tightened the heat sink on the DMD (supporting the DLP chip). Made the problem consistent (black lines) always. So then I slightly loosened the spring clamp screws - black lines went away.. Obviously this varies from each device, where the cold solder joint(s) are etc, But this will keep the Mrs happy until I work up the courage to reflow oven the DMD board, or get a new one. Anyone reflow oven their DMD boards yet?
Posted on Jun 21, 2008
  • gregwjacobs Jun 21, 2008
    I should add some info here to save ppl asking.
    Manual from - http://www.servicemanuals.net
    It cost me $15 for a PDF download. Worth it.
    I've attached an image which shows the screws i tweaked. Don't loosen to much or you'll compromise the heat sink and fry your DLP chip (heat bake). You've been warned.
    You don't have to do anything other than remove the back cover and you will get access to the screws. Ensure you UNPLUG your set - do not attempt if you are useless ;)
  • 113 Answers
Your tv has a failing DMD board. White vertical lines is the first symptom of this it is bad solder connections on the Control Ic this is what we call a BGA ic and is not serviceable in the field if you are good with electronics you can replace the dmd board it is a task in itself you are looking at about 450 or so for the part. The part number for the DMD is Bp96-00678A. The light engine comes with a new DMD board and it is easier to change only takes me about 20 minutes or so this would be part number Bp96-00822G and could run as low as 500 dollars after you return the core depends on where you get it.
Posted on Feb 08, 2008
Why is there two black spots in image on screen. Two round black circles. Not sure what it means and where they came from
1st make sure screen is clean. inspect when off. use only cloth slightly damp with water.
2nd make sure it is not the image by looking at another image or a blank white screen. Some test images will display each color.
if it is there on any image the pixels are dead. But being circles sounds more line screen cleaning
Sep 14, 2014 | Vtech InnoTab 2 - VTECH
White lines on image however when capturing on dark areas and on video mode, it produce a perfect image
Not clear when you have white lines. While looking on the screen or really on a image.
Lots of camera's produce lines on the LCD, when using the LCD to frame the picture. Special when there are small and sharp lights in the image. But the sensor is not capturing that while making the picture. It is a sort of smear on the screen.
Also, when you try to make a picture in bright lights, you can get flares, but those you can see on the screen and in the picture. To fight flares, most camera's and lenses come with sun hoods. Your camera does not have a hood, so try to avoid shining bright lights on the front of the lens.
Nov 05, 2013 | GE 14MP Digital Camera with 5X Optical...
Dark picture good sound, backgroung image on screem
There may be different reasons for that.
Here's an example:
http://www.coppelltvrepair.com/p/428/sanyo-dp42848-p42848-00-backlight-inverters-replacement-for-dark-screen-no-image-problem
Find out the model / chassis and give a better description for the problem in order to get better help.
Aug 21, 2013 | Sanyo 42 in. LCD TV
My Toshiba 46XV540U LCD TV. Has ghost image plus many white vertical and horizontal line when it is turned on. These lines and the ghost image stay for 20 to 30 minutes and than the picture becomes clear....
Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish board that call T-CON board to do a replacement.This T-CON board sit in the middle at the bottom of the tv LCD screen panel.This T-CON board control all the picture pixels going throught to the tv LCD screen panel.
Jun 11, 2011 | Toshiba 46XV540U 46 in. LCD HDTV
I have a HTC Touch GSM, after an error pop up it´s been resetted and now it shows only the first image (the black backgroung saying Smart Mobility in white) and stay freezed there.
Oct 08, 2009 | HTC Touch P3450 Smartphone
Screen shows no image for picture taking or playback
Is this Sony DSC-T1 camera or some other model? let me know to help you out.
Jun 15, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
LCD Screen and view finder are distorted
Sorry about delayed reply as I just saw it.
Its known problem of ccd imager in Canon ZR85 camcorder and ccd imager needs to be replaced.
Canon will repair your camcorder free of cost as per announced scheme for ccd imager issue.
Click Canon CCD Advisory for details, how to get free repair.
Good luck.
Nov 23, 2008 | Canon ZR85 Mini DV Digital Camcorder
Frozen Camera and white screen/distorted image
im sorry i can thelp and i belive your phone company wont help either because your not really suppose to play with it. it voids your contract.
my solution - buy a new phone off ebay and active it online
Nov 27, 2007 | LG KG800 Cellular Phone
Samsung DLP HL-P5663W 56" TV Logo
746 people viewed this question
Jerry Greenberg
Jerry Greenberg
