Question about Cobra 148 GTL 120-Channels Base CB Radio
Keys up and everything dims and does not transmit.
On occasion, my 148 Gtl will suddenly dim the meter light and the led light while I am keying up the mic. When this happens, I cannot transmit and the meter barely moves. To solve this, I turn the volume knob to almost turning off the radio and then everything brightens back up and I am able to kick out a strong signal. The mic seems to work fine, but I am planning on trying a different mic as soon as I can find a 5 pin mic. The Mis is an echo and talkback mic, and I think that it might be related to the mic, if not something internal lot the split shaft pot on the volume/squelch knob.
Any ideas?
  • creole Mar 19, 2008
    My handler is creole from Trinidad. I am also experiencing similiar problem with my 148gtldx, when i turn on my radio the meter light is dim and i have to turn it on an off couple of times to get the full brightness. So now i just leave the rig on and disconnect the power cord if needed. There's is also a problem when transmiting on the AM, i've been told there's a scratching squeal sound coming with my transmission. The technician said he change the final ic' and fixed some cold solder, but no improvement. Can someone give help/advice?
  • SHARCNET-USA
    SHARCNET-USA May 11, 2010
    Moving the volume/on/off knob to make the radio work again is interesting and a good clue. On most CB's, the pot is probably soldered directly to the printed ciruit board.
    It's possible that there is a bad solder joint to the power connections on the pot that turn the radio on & off. If the solder joint is bad, it can still make a connection but the connection will have added resistance in line. The on/off switch can be bad too.
    Switches arc each time they are used and over time, the contacts become pitted and make poor connection.
    I had a stereo receiver where the tuner lights flickered and there was electrical noise in the receiver. It turned out to be a bad on/off switch.
    This resistance may be low enough not to affect the radio when in the receive mode but when you transmit and draw more current that resistance will be noticable during transmit.
    The fact that you rotate or move the volume/on/off knob and the radio starts working again, tells me that there may be a bad connection in the radio.
    A cheap thing you can try is spraying some electrical contact cleaner into the pot and rotate the pot back & forth several times and turn the switch on & off several times to clean it.
    Please let me know if I can be of further assistance to you.
    - Jim
  • 2,130 Answers
- Jim
Posted on Feb 08, 2008
I have an cobra 148 gtl no transmit
If theres no carrier its either the finals or driver. If theres no audio its the white wire in the plug that screws into the radio..its either broke or most likely come unsoldered. It keys but no audio.
Mar 05, 2015 | Cobra Radio Communications
Cobra 148 gtl d has problem transmiting with covers off. trying to tune radio up. was thinking I need to ground the chasis
I would say a bad or cold solder joint on board somewhere. Bad quality control. Might flex radio chassis slightly while keying? A tooth pick and hours of probing around switching area on board and the pa section till problem found.
Oct 25, 2012 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 148 gtl-st wont transmit but receives great
Check first your microphone
• check if TX is engaging when PTT is pushed.
• check for continuity ( mic and cable )
If you have not done these steps,
try it first, or borrow other compatible mic for Cobra 148GTL
from your friends on air.
Jul 28, 2012 | Cobra 148 GTL 120-Channels Base CB Radio
No transmit on 148gtl
First is check to see if SSB transmits or not==if it does the AM regulator on side wall of radio is bad.
Second with a meter and no power on--test the driver and final for shorts or open.
If one is bad replace both.
let me know what you find.
Apr 29, 2012 | Cobra 148 GTL 120-Channels Base CB Radio
148 gtl receive issues
The problem is in the audio output chip usually bolted to the inner chassis. Sometimes the chip developes a hairline crack, replacement recommended.
Mar 14, 2012 | Cobra 148 GTL 120-Channels Base CB Radio
Indicator light doesnt work and the meter doesnt work.
If your TX (Transmit) meter does not work at all, it might or might not be a faulty press-to-talk switch, or faulty wiring. More often, it's the final amplifier stage that's defective if you don't have a carrier (signal) when you key the mike. That will require a qualified Tech to make those repairs. I'm basing this on my experience as a Communications Technician since my Navy days and CB Dealer since the mid 1970s. Thanks
Aug 25, 2010 | Cobra 148 GTL 120-Channels Base CB Radio
Lose tansmit
u have a cold soder joint or a crack in the board get a sordergun and just resoder ares all aroun the mic input
Apr 03, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra gtl 148 seems to have no power til i push on mic connecter.
cobra 148 shows no wattage output on external meter but does show good modulation.
Dec 08, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 148 GTL 120-Channels Base CB Radio Logo
182 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
