Question about Radio Communications
97 ford escort lx
I am trying to fix the horn. I have already bought a new one and connected it the same way the old one was connected and it still doesn't work. I can hear clicking under the dash when I push on the wheel in the car but still no sound out of the horn. The old one only had one wire connedted to it. That wire is orange and blue. Help me please.
    Master:
    Sergeant:
  • 440 Answers
Cheak all fuses ok
Posted on Feb 08, 2008
Horn stays on. 97 escort how do you put insulators in steering wheel?
replace the horn button the contacts are in continous contact.this could also be a bad horn relay that the contacts won`t separate and will need to be replaced.
Oct 27, 2011 | 1997 Ford Escort
The horn does not work at all on 1999 escort
I am assuming you have checked the Fuse Box under the hood for the Horn Fuse and / or the Horn Relay and made sure both are good?
You can always try the steps outlined in this video to replace the horn pad. to see if this is your issue if you have exhausted all of your other resources.
Or You can try these steps to further diagnose your issues:
The horn relay on ZX2's is located underneath the dashboard on the drivers side. There are several relays located there - identify the horn relay by the "clicking" sound it makes when the horn is pressed. The likelyhood that you have a bad relay is minimal. Start by checking the horn fuse (the fuse box is located under the dash on the driver side). Next, check the relay. If the relay is making a clicking noise, it is probably OK. The next thing to check is the horn itself. it is located on the passenger side of the vehicle, up underneath the front bumber. Most instructions say to remove the bumber cover to get to the horn, but this is not neccesary. In my experience with Escort horn problems, the problem has been with the horn "switch", a wafer thin piece of plastic that lies between the steering wheel cover and the airbag assembly. Below are instructions for replacement of this switch - don't be intimidted by the procedure - it is not difficult.
You cannot buy a horn switch at a dealer - they tell you that the horn switch is part of the airbag assembly, which cost $450 plus. Understandably, Ford doesn't want people "messing around" with airbags. Go to a junk yard - you can eazily find and remove the horn switch from an Escort who's airbags have already deployed. I bought two of them for $5. Identify and remove the junkyard horn switch by reading step 7 below. This is an eazy fix if you follow these instructions. Should take about 10 minutes. I replaced my "stuck" 97 Escort horn switch as follows...
1) Disconnect negative battery cable, wait for at least 1/2 hour for residual power discharge before proceeding to net step (IMPORTANT!). This will disable the airbag. Neglecting this step could cause serious injury or death!
2) Remove two 10mm bolts directly behind the steering wheel - one on left, one on right. These secure the airbag unit.
3) carefully lift the airbag unit out of the steering wheel.
4) remove two small star-screws at bottom of airbag unit using star end screw driver - the horn wires enter the airbag unit next to these screws
5) pry the airbag cover (this is the front part of the steering wheel cover with the horn picture on it) off of the plastic tabs of the airbag unit, on the left & right sides - should come off very eazily.
6) now you can lift the airbag cover up (there are three rivets that continue to hold the top portion of the cover in place)
7) the horn switch, which is covered by a thin layer of dark foam, is a very thin plastic pad with two wires coming out (same wires as step 4). You can see wafer thin copper strips inside the plastic. The switch is held in place by three small plastic tabs. Remove the switch and disconnect the wires at the red connector inside the steering wheel.
8) replace horn switch with junkyard switch
9) re-assembly is the reverse of the removal.
This procedure should apply to 97 through 2002 Escorts, including the ZX2. Hope this helps someone save some money.
May 25, 2011 | 1999 Ford Escort
I have an 1994 ford escourt wagon LX...i have replaced the thermostat and housing and back flushed the whole system..the air still doesnt blow hot enough air to warm the car up inside..this needs to be...
Even though you already flushed it I will bet the heater core has build up in it. My escort did that and i had to hook a garden hose direct to the heater core and flush it with dawn dish soap both directions several times untill all the slimy old antifreeze inside it finally broke loose and came out. Then it worked great
Feb 09, 2011 | 1994 Ford Escort
Replaced engine & battery, security system locked us out
sounds like the immobiliser, like you did,nt connect the immobiliser block,a cable with 3 wires,look carefully you may not have noticed & plugged it in. all the leads connected to the battery may not be correct. car thinks it,s being stolen.with fords you need to use the original key(red dot on it)to activate security settings,good luck leave key out of ignition,that may work
Jul 27, 2009 | Ford Escort Cars & Trucks
My sons 97 ford Escort has no parkers or horn. I was looking for a wiring diagram ??
Are you sure there is not a blown fuse in the car?
i would check that first.
Jul 12, 2009 | 1997 Ford Escort
1998 ford escort 2.0 lx sedan power steering
Most likely the problem is the steering rack, it is a very easy repair, but you will need to have the front end aligned after you are done installing the rack assembly, make sure all the old fluid is flushed from the system or the new rack will fail from debris left over from the old failed rack
Nov 06, 2008 | 1998 Ford Escort
Radio Communications Logo
133 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
