Question about GE 27GT616 27" TV
Vidio tapes are chewing up
Video is chewing up tapes
  • 579 Answers
This is the number one failure mode for a tape machine.
One drive is used to pull the tape out and run it across the heads very accurately, and another drive is used to pull the tape back into the cassette. This one uses a clutch to allow it to slip so that the takeup reel in the cassette can vary in speed depending on how much tape is on it. After a few years, it slips too much and can't pull the tape in fast enough. (older units use rubber idler wheels to do the same thing)
Either tighten up the clutch, or replace the rubber wheel.
Hope Ya Fix It!
Posted on Feb 08, 2008
How do I stop the vcr chewing tapes?
Probably bad drive belt need replacing.
Sep 18, 2014 | Televison & Video
Camera chewing tape when in " REV " mode, then E03 on display
the capstain of the mechanism needs to be change and it can also be the pinch roller.the fastest solution is to change the mechanism ofthecamera
May 27, 2013 | JVC GR-DVL160EG Mini DV Digital Camcorder
When tape is loaded into camcorder the tape gets chewed up - there seems to be damage to the casing
This can be due to a faulty PINCH ROLLER as it can chew if the bearing are worn out . If so this must be replaced, Also a faulty mechanism, links , alignment can make the tape to move out of the track and get chewed.
finally the tensioner of the tape which is tension band can be faulty and so it will allow the tape to be loose to get chewed down.
Jul 27, 2011 | Panasonic 5 PANASONIC MINI DV 60 DVM60...
Why is my vcr chewing up tapes
The answer is easy take the top off the unit, and with an old video tape try it and watch what the video does. This is the only way really as the causes of tape damage are many, including objects that have got into the works. The only tape chew fault that can be put down to a single thing, is the crinkle bottom or top edge. Which is caused by the pinch roller being worn.
Once you see what it does you can post again and describe it, we are FixYa should be able to pin it down.
Feb 03, 2010 | Philips VR750 VHS VCR
Camcorder chews up tape
clean the heads and rollers with cotton swab dipped in rubbing alcohol
Jan 06, 2010 | Canon MV30i Mini DV Digital Camcorder
Trouble shooting my GR- DF550 vidio camera
mine is in safe mode 3 too and it won't go away. It's over a year old and not worth $$$ to fix. It's time to move up to a HD hard drive video. I suggest you too.
Jan 20, 2009 | JVC GR-DF550 Mini DV Digital Camcorder
Canon XM2 Chewing tapes
This seams to be the problem, all the time, plus the sound goes off on most of theses camcorders, and the only way they will work is with an boom, mic.
Could I use an tape clearer when it says eject?
Aug 02, 2008 | Canon DM-XM2 Mini DV Digital Camcorder
Philips video
time to have its belts replaced
Oct 11, 2007 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Chewing up mini-dv tapes
These type of problems usually result from damage to the tape transport mechanism, Unfortunately they are impossible to fully diagnose without a physical examination of the mechanism.
There is not a magic tweak for this i'm afraid.
Wish i could be more help
Jan 11, 2007 | Panasonic Palmcorder PV-DV102 Mini DV...
Televison & Video Logo
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
