Question about D-Link DIR-625 (790069292637) Wireless Router
DLink DIR 625 Wireless Router
I have configured the router and have 2 PCs connected via cables to the router and 1 PC connected wirelessly to the router. They all seem to have a connection. The 2 wired PCs can talk to each other, but neither can talk to the wirelessly connected PC. And the wirelessly connected PC cannot talk to either of the wired PCs. How can I get the wired PCs to talk to the wireless PC??
    Problem Solver:
  • 16 Answers
It is the wireless computer setup with the same network name?
Posted on Apr 11, 2008
I Need Installer For My D-Link DIR-600 Wireless Router
There are ways to configure router:
1. Is by using Installer using a CD came with it or
2. Access routers Graphical User Interface (GUI) through Internet browser. Just type in on the address bar the IP address of your router. For dlink it has a default IP of 192.168.1.0.
Note:
Before accessing router configuration make sure that the yellow cord (ethernet cable) is connected directly from the router to your computer.
Sep 14, 2013 | D-Link Dlink Dir-600 Wireless Router...
I have a Westell DSL modem & a D-Link DIR-625 wireless router. Everything has worked fine for years but a few days ago the Internet connection went down. I contacted AT&T for support. During the...
you need to configure the dsl modem to be on bridge mode after you did it successfully. that is the time you configure your d-link for you to connect to the internet.
call first your ISP to configure the modem to Bridge mode after that call your manufacturer of the dlink for them to configure your connection
Jun 11, 2010 | D-Link DIR-625 (790069292637) Wireless...
How to reset the security for a Dlink DIR-625 wireless router
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Apr 01, 2010 | D-Link DIR-625 (790069292637) Wireless...
I hooked up our wii to the internet via our dlink wireless now all the computers are locked out, my account says inactive and when i try to access the internet it goes into a loop...whats up?
The Wii could have triggered your connection settings inside your router firmware to lock up. Router settings may need to be configured to work with your Wii and the other PCs OK
Mar 06, 2010 | D-Link DIR-625 (790069292637) Wireless...
Dlink DIR-625 permanently stopped working. Connected directly to internet with dsl cable through sympatico and internet works fine but doesn't work at all when connected through Dlink DIR-625
you may need to reset the router and reconfigure the settings. please follow the steps below if you have a username and pw from sympatico.
1. Press the reset button for 30 seconds
2. Plug the modem to the internet port of the router. Check the internight light if lit; otherwise, use another known working cable.
3. Plug the PCs to the numbered port at the back of the router. Check the lights on the port number if lit; otherwise, use another known working cable.
4. Open a web browser and enter http://192.168.0.1 and press Enter. When the login window appears, set the user name to Admin and leave the password box empty. Click Log In to continue.
5. Click on manual configuration when prompted.
6. Select PPPoE on My Internet Connection and enter the username and password provided by Sympatico. Select Dynamic IP and Always ON options. Click Save Settings.
7. Click on Status tab and verify WAN status if connected. You should see WAN IP address when connected.
8. Try to open a browser and verify your connection.
Hope this helps!
Jun 25, 2009 | D-Link DIR-625 (790069292637) Wireless...
D-Link DIR-625 - wireless problem
with your situation you can see the wireless network but cannot connect you have to change your DNS.
*that will depend on your operating system.
Jun 17, 2009 | D-Link DIR-625 (790069292637) Wireless...
Hi i hav purchased a Dlink dir 300 router. is this router capable of letting multiple pcs n cell phones connect to it for internet wirelessly with out the need of keeping 1 pc switched on all the time? i...
Yes if you consult the manual that came with the router it will show you how to connect the modem to it and setup the DSL (PPPOE)settings. Some Modems though already have the PPPOE settings within the unit and then the router would just need to be set to automatic. You will need to configure from the PC but afterwards you can shut down all your PC's on the network at anytime.
Jun 04, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Dir 615
1) Check all the conections
2)Restart the router.
3) try 192.168.1.1 admin admin
4) Try connecting via LAN Cable
Hope it helps....keep the hope :)
May 19, 2009 | D-Link DIR-625 (790069292637) Wireless...
I have an issue with my Dlink DIR-625 wireless and cable modem
it isn't syncing up with your modem, try a hard reboot, disconect everything, even the cable, after 5 minutes , first screw the coax cable back to the modem, that will re establish the cable connection, plug everything back in, and if that pc light still is still doesn't work, the router may be bad, look on the Dlink site and download the latest firmware, as a last resort, but also reset the router first before trying anything, there is a reset button on the router. Sometimes certain routers don't work with certain modems, if you try the reset, then the hard reboot, and the firmware, you have covered all the bases
Mar 30, 2009 | D-Link DIR-625 (790069292637) Wireless...
Wifi problem of DIR-300 dlink
just open the dlink ip homepage and configure the wireless settings
sagar
Jan 27, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
D-Link DIR-625 (790069292637) Wireless Router Logo
212 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
