Question about Toshiba Satellite L25-S119 Notebook
Overheats and cuts off
Why does my laptop overheats and then cuts off?
  • hambow Jul 26, 2008
    playing itunes for music in my bar, about 6 times in five hours, laptop cuts out and takes about 5 mins to re-boot. have had the laptop checked for virus's...nothing found. have set a fan up today next to it but still happening? Please help! am in a little village in Spain, not many english computer experts here!!
    Many thanks
    Alison
    Problem Solver:
  • 17 Answers
Try to clean the fans inside. No need to open case. Use an air blower to blow away dirt from the fans and heatsinks.
If that don't solve your problem, the cpu heat-sing or heat-pipe may be not seated properly. You may need professional assistance.
Posted on Feb 08, 2008
Where is coolant temp sensor on1989 isuzu 2.6 efi engine
engine coolant
guage sensor
a/C CUT OUT OVERHEAT SENSOR.
There can be 3 sensor.
not posting what doent work makes this impossible.
engine ECT reads wrong
gauge only reads wrong
or A/C cuts out when engine overheats (normal for overheat)
Mar 14, 2015 | Isuzu Cars & Trucks
Cutting out windows
When the CPUoverheats it goes into thermal shutdown and will not boot up again until theCPU has cooled down.
The heat sink may be clogged with dust, which causes the CPU to overheat byreducing air circulation through the heat sink.If you are notusing your laptop on a flat surface, it may be obstructing the cooling vents onthe bottom of the laptop. Your laptop fanmay be faulty and not spinning freely, in this case replace the fan.
Check the fan and heat sink assembly and remove the dust, loosen the dust anduse a can of compressed air to clear away the dust.A laptop fanassisted cooling pad may solve your problem
Mar 18, 2012 | Computers & Internet
Upper left keyboard area overheats and then it cuts out
Sounds like you have a laptop with a clogged fan or non working cooling fan. You'll need to open the machine up and clean and or replace that fan.
May 14, 2011 | Computers & Internet
Fan runs constantly, then appears to overheat then switches off, only turns back on when cooled down?
Possible that the ventilation fan is blocked ,the filters are clogged. You will need to remove the covers to the ventilation fan, remove off all dirt-- do not place on the bed to cut off flow.
If the fan does not cool due to this clogging then the processor will heat up and cut off.
Apr 23, 2011 | HP Compaq 6735s Notebook
I have a compaq presario x6000. every time i place the laptop on my bed and turn it on it cuts off within 5 minutes. but when I place it on a desk and turn it on it does not cut off. do not understand why...
The reason is because when the laptop is placed on the bed the cooling vents are blocked and the CPU overheats and shuts down. When the laptop os placed on a flat surface there is sufficient clearance between the bottom of the laptop and the flat surface of the desk to provide sufficient air circulation.
If you wish to use the laptop in bed then place the laptop on a flat surface and not let the bed clothes cover the laptop's cooling vents.
Aug 12, 2010 | Compaq Presario X6000 Notebook
Overheat
Yes you could try a laptop "Cooler Pad" that may help, either that or go into the BIOS and set the temperature "Cut Off" point higher by say 10 - 20 degrees. Ensure the laptop has an air flow all around it at all times. Clean out your exhaust port, of dust etc.
Apr 23, 2010 | Compaq Presario Notebook
Green light cuts off when plugging into laptop
Replace the charger, it probably overheat and died.
Try with a voltmeter to measure the output power (usually aroud 19 V DC)
Then the tricky part, try to power something else with the charger , something who might work with the output power (a car light bulb for exemple).
If it does work then you have a short cut on the motherboard of your laptop if it's the case replace the laptop, it's the hell of a job to repair the motherboard...
good luck
Dec 12, 2009 | Dell Inspiron 1501 Laptop
Laptop keep on cutting out
if it's not loosing power, random dropouts are usually due to an overheat. check to make sure that the fans are running and replace if necessary.
Aug 14, 2009 | Computers & Internet
Toshiba Satellite L25-S119 Notebook Logo
351 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
