Question about Cooktops
Jgp326 the iginitor is not working
  • Anonymous Jun 25, 2008
    All four burners fail to "click" ignite
  • 46 Answers
Replace the battery as per user manual. usually AA or AAA type
Posted on Feb 09, 2008
Access cooktop underside
Just lift it up. At the seems on each corner, pull up and it will lift.
Apr 15, 2014 | GE 30 in. JGP326 Gas Cooktop
How do I remove the spark igniter when replacing a burner bowl on GE JGP 636 gas cooktop
The spark ignitor is attached to the burner bowl by a retaining clip under the bowl. Simply remove the two screws on the top of the bowl, then you can slide the clip off from the underside
Jan 23, 2010 | GE 30 in. JGP326 Gas Cooktop
Burner control will not depress or turn. This is a fairly new GE gas cooktop and this burner has been used only a couple of times.
constantly cleaning with spray cleaner or too much water may have leaked down into the steam of the valve and rusted it. replace the valve and lycon switch
Nov 22, 2009 | GE 30 in. JGP326 Gas Cooktop
Ge model jgp326 ignitor is giving
you either have a bad licon switch on one of the burner valves or you got water or cleaner in one of the switches.. Unplug it and let it dry for a few days, if it does not work you need a new switch.
Nov 11, 2009 | GE Profile JGP636 Gas Cooktop
Does not ignite
Check to make sure that the gas is getting to the igniter. If you can ignite with a lighter or match, than the igniter itself needs to be replaced.
Apr 01, 2009 | GE 30 in. JGP326 Gas Cooktop
GE Countertop (JGP 3336) control knob does not turn
ouch, sounds as ifthe valve has frozen up, replacing hte valve would be the solution
Mar 17, 2009 | GE 30 in. JGP326 Gas Cooktop
No ingiition
take a small needle to the inside, and clean the orafice, see if it helps
Jan 14, 2008 | GE 30 in. JGP326 Gas Cooktop
Not igniting
Probably broken switch. or perhaps broken ignitor circuit. If only one burner is broken is then it is switch. if they all don't work check the ignigitor circuit.
Dec 16, 2007 | GE 30 in. JGP326 Gas Cooktop
Cooktops Logo
121 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
