Question about Radio Communications
Motorola CDM1250 UHF Radio
My son just bought the above reference product. He proceeded to power it up by connecting to a bench inverter that he uses forhis other radios/scanners. Nothing happened. He checked the in-line fuse and it was blown. After replacing the fuse he decided to try another power source. The unit was connected to a car battery. Again, nothing happened except a small puff of smoke from the rear of the unit and another blown fuse. At this point he decided he needed some help. I understand there is an internal fuse on the circuit board. Is that easily accessible/repairable?
Renard Sanders
  • 204 Answers
Renard, just offhand without see'ing the unit, I'd say that something got sparked wrong in the hookup process. The taletell "puff of smoke" tells me the protection circuit or protector diode got "smoked" in the process. It's more than a fuse now, the protection circuit is blowing the fuse, to stop further damage. I'd say that, at least the protector diode needs changed and to check out for any other damage. Probably need a good tech to visually "check" the unit thruout. Definately needs to have it put on the meters and guages to fix all the damage at one time, something that cannot be done by talking you thru it,,, Mechanic
Posted on Feb 09, 2008
Not talking far
Check your antenna set up and connections. Make certain all connections are tight. Have you changed anything about the antenna recently, such as location, or stinger length?
Feb 13, 2014 | Motorola CDM1250 Two Way Radio
External speaker no function
You have the correct external speaker connected, or a generic?
Some radios require certain external speakers to work properly, and generic speakers aren't always the solution.
Motorola 2-way radios of the model you have, may well come under this bracket.
Other than that, all I can suggest is: join yahoo group specific to your radio Make/Model, and the team there will advise you what's best for your radio, plus you can download manuals, schematics and other goodies for your radio and it's all free.
I hope That this has been of use to you.
Best regards,
Peter
Aug 10, 2012 | Motorola CDM1250 Two Way Radio
I have a motrola cdm 1250 y put the watt meter and tr4ansmit only two atts
Hello Miguel,
My advice is to join yahoo group SPECIFIC to your radio Brand & Model No., the people there will be very helpful, and you can dowload manuals, diagrams and other good gear for your radio(IF AVAILABLE), all this is free.
I hope I have helped you to find your diagrams.
Cheers,
Peter
Jul 21, 2012 | Motorola Cdm1250 Uhf 403-470mhz 40 Watt W/...
How do you set the radio back to default settings. AXU4100
  • HI, I can help.
  • You will have to contact an authorized Motorola dealer such as http://www.buytwowayradios.com/products/motorola/motorola-ax-axu4100.aspx or any reputable two way radio store in your area. Those radios are still very programmable. I wish there was some way around this but there is not and Motorola gets very grumpy when unauthorized people end up with their interface because it is in fact quite the money making racket.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Sep 22, 2011 | Motorola AXU4100 (10 Channels) 2-Way Radio
Cdm1250 ignition on wire radio stays on
I dont understand your question, but ignition wire wich is conected at pin 10 in the accesory connector must be conected to the ignition, fuse is recomended for security reasons but you can use a 1 amp fuse, this line is just a sense to get the radio on or off folowing the ignition
Jan 07, 2010 | Motorola Radio Communications
I have a GP328 4channel hand held can it be reconfigured to be used as an ordinary uhf two way
It should be capable of being programmed to a "simplex" frequency where you can use the radio simply radio-to-radio. This is a dealer programmable style radio. You would need to visit your local Motorola dealer to have it programmed. As for whether it will do "ordinary UHF", the radio would have to be UHF. This style radio was produced in both VHF and UHF. Your dealer would be able to advise you on which one you have.
Best regards.
Dec 18, 2009 | Motorola Walkie Talkie 2-Way Radio
Uhf or Vhf that is the question
UHF. To receive calls in your car, the radio would need to be programmed to a frequency matching other radio you are wanting to receive transmissions from.
Mar 10, 2009 | Motorola HT1000, MTS2000, MTX8000/9000...
Motorola VHF radio GM339
Your radio is equivalent to the US version named the CDM1250 or CDM1550. The instruction manual for these radios is available on CD from most Motorola dealers.
Apr 03, 2008 | Radio Communications
Radio Communications Logo
380 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Marvin
Marvin
Are you a Radio Communication Expert? Answer questions, earn points and help others
