DVD has came right out of the case of the laptop and the ribbon has become detached.
    Master:
    Sergeant:
  • 440 Answers
U can take it aprt screw it back in or take it sumware u may wann upgrade to dvd rw if u dont have one all ready as u do all that ok thx nick
Posted on Feb 08, 2008
This color strip is intermittent. It's a 50' Samsung led tv
it looks like the ribbon that is bonded to the panel is damaged. there are a couple of possibilities with that. its either burned or has become partially detached from its seating which can be countered by pressing on it. this happens over time due to warmth of the panel heating the tiny solder pins on the ribbon (this does require taking the tv apart, including the panel). if its burned, there is nothing you can do
Oct 26, 2012 | Televison & Video
How to replace cmos battery on satellite p105-s6217 laptop
Turn the laptop over and remove the battery pack.
From the bottom of the laptop, unscrew the plastic shells securing the slots for memory,
Bluetooth, hard drive and modem.
You may have to remove more than one screw for each shell. Keep all screws in a small container, away from the work area.
Remove the memory (RAM) modules, the hard drive and any optical drives (CD-ROM or DVD-ROM).
Press the clips on either end of the memory slot to raise the RAM module and detach by pulling it out. Work slowly and carefully, to prevent damage to RAM modules or the memory slot.
Do the same for all modules, if you have more than one.
Slide out the hard drive and optical drive. If the drives seem to be stuck, look for any screws you may have missed.
Turn the laptop over and insert a pointy tool under the thin strip at the top of the keyboard. Use the tool as a lever to pry the securing strip loose, while working with your finger to release latches along the length of the strip.
Remove the keyboard by undoing two screws securing it.
Raise the keyboard and disconnect its cables.
Close the laptop lid and turn it around, so that you are facing ports on the back.
Remove two screws from the metal plate around the ports.
Open the lid and remove a single screw securing the wireless card cover; the screw is under the keyboard, which you already removed.
Disconnect cables from the motherboard.
Access the board through the space created by removing the keyboard. Unplug the speaker cable from the motherboard by carefully pulling at its head.
Unscrew and remove Wi-Fi antennas, and detach the wireless card from the motherboard. Unplug thin, ribbon-like cables from the video card.
Detach the display assembly from the base of the laptop.
Loosen any attachments, and pull the casing toward you to detach the display assembly, including the LCD panel, from the base.
With the motherboard completely exposed, unscrew and remove the video card.
Undo two screws from either side of the hard drive housing and detach the drive.
Dismount the CPU heat sink and detach the fan cable from the motherboard by removing five screws.
You can now access the battery board with the CMOS battery attached to it.
Undo two screws to detach the battery board from the motherboard.
Disconnect two cables running from the battery board, and carefully raise the board to detach it.
Replace the CMOS battery by prying it open with a pointy tool. Insert a new battery and reassemble the laptop.
hope this helps
Oct 04, 2012 | Toshiba Satellite P105S6217
My sony laptop computer is dos not turn on
Remove the main battery and try again, next make sure the power supply charger is at the correct voltage, if okay! swap out the ram one at a time, if still no response! the DC jack in the laptop becomes detached from the motherboard in some cases, I recommend a professional to assess it further.
Mar 13, 2012 | Computers & Internet
How to remove the keyboard
Keyboards become worn out over time. Individual keys can become damaged, become less sensitive to key strokes, or disengage from the keyboard. Keyboards can also become corroded from spills. Many keyboards on HP laptops can be replaced. Hewlett-Packard has made hundreds of different laptop models. Each model may require slightly different steps for replacing the keyboard. To locate a replacement keyboard, you can contact HP directly or another online or offline source that sells computer parts.
1.Power off the laptop. Flip the laptop over to access the device's underside.
2.Remove the battery cover and take out the battery.
3.Remove a screw to the left of the memory bay. This screw will be one of two resting in the middle of the underside of the device. You want to remove the right screw, the left screw is attached to the CD/DVD-ROM drive, not the keyboard. (This screw may be red in color.)
4.Flip the laptop back over and raise the laptop screen so you have access to the keyboard area. Insert the tip of a Flathead screwdriver along the bezel and detach it. Carefully pull the bezel up and set it aside. The bezel is connected to the device with a ribbon cable. Do not remove this ribbon cable. (The bezel is the above the laptop and is the cover that houses the power button.) Once the bezel is up, notice the three screws that are beneath it.
5.Unscrew the three screws holding down the keyboard.
6.Lift the keyboard forward toward the mouse area. Be careful, it is still connected to the motherboard by a keyboard cable.
7.Release the cable from the keyboard. Push both ZIF connectors on the side of the cable upwards, toward the laptop screen. Pull the cable from the connector and the keyboard is now released.
8.Insert the keyboard cable of the new keyboard into the ZIF connector. A pair of tweezers may be required to put the cable in place. Lay the keyboard flat down and rescrew in the screws. Replace the bezel cover. Flip the keyboard over and replace the screw on the underside near the memory bay. Insert the battery and battery cover.
Sep 19, 2011 | HP ProBook 4710s Notebook
I have a DVD stuck in a Toshiba model MW24FN1. I can't even get the DVD door to slide out more than 1/2 inch. Any good ideas? Thank you.
Had same problem. Unscrew the back of the TV. Unscrew 2 screws connecting VCR/DVD from TV Base. Unscrew DVD housing on all sides (approx 6 screws). At this point you can see the detached DVD unit. Facing the DVD drawer. Look under it for a white plastic piece that you can slide to the right that should disengage the DVD's circular rotator from the dvd and slide the door open.
If that does not work disconnect the DVD from the 2 connectors at the TV motherboard. Slide slack into the ribbon cable to free up the case. When the DVD unit is out, dissassemble the black plastic DVD unit. Flip it over and manipulate the white plastic gear which will disengage the center rotator.
Let me know if that works for you.
Nov 29, 2010 | Toshiba MW24FN1 24 in. TV/VCR/DVD Combo
Screen went blank. Touch still works but nothing g is displayed on the screen
Sounds like the ribbon cable inside the unit to the screen has become detached or loosened. May have to pull unit apart carefully to re-attach it. If you go down this path be very gentle as they have a habit of ripping...
Jun 25, 2010 | Jensen's VM9312 Car DVD Player
My JVC Everio GZ-MG135aa fell off of it's tripod stand and now the lcd is white on the right half and has bright lines on the other half (this is all it will show) If I hit record it still records and...
LCD panel needs replacing - this is the classic case of detached screen ribbon, which unfortunately is not repairable without silicon printing equipment which costs thousands. Also check playback on another device (ie streamed through your PC) to make sure the heads haven't become misaligned.
Jul 17, 2009 | JVC Everio GZ-MG155 Camcorder
How do you open DVD Player? DRC630N-M
I've successfully opened the case and re-attached the ribbon cable and now have a working dvd player (DRC630-N).
Once the screws are removed, you will want focus on separating the case at two clip locations on the bottom of the player, centered approximately 1 1/4 inches to either side of the brass threaded insert on the bottom.
You can see one of them broke for me when I was trying to get it open. If you apply some pressure under those clips you may have more success avoiding any clip breaking. I'm not worried about it since with all the screws it is plenty secure. What I did to get it open at these clips was insert a small flat screwdriver head in the small gap (seam) at the clip locations and twist. It did gouge the plastic a bit, but worked well enough. Once this side opens up you should be careful about separating the unit along the side with all the plugs. It took a bit of easing around the volume wheel and a couple plugs to get it fully apart. The opposite end of the player from the clips will come apart once the clips have been released as it is on a separable hinge.
Here is the ribbon cable detached from the circuit board.
The ribbon cable (blue part) slides into the black and white connector. Make sure the black part is pulled slightly away from the white part when you are sliding in the cable. Once the cable is in as far as it will go then slide the black part of the connector until it is flush against the white part. This secures the ribbon cable in place.
Here is a picture with the ribbon cable slid all the way into the connector and but still unsecured:
Now here is a picture with the black part pushed tight with the white part of the connector:
Here is how it looked when I closed the case back up:
Good luck. Hopefully this helps.
May 18, 2009 | RCA DRC629N Portable DVD Player
Touchpad/left button not selecting
Reinstall Touchpad drivers and then check.If you still got the same issue then call customer care.
Mar 06, 2009 | Computers & Internet
PRINTER ERROR COMES UP - SAYS SEE DOCUMENTATION & CALL SERVICE IF
This is a "General Error" issue, not a service required one.
It's likely that either a sensor in the printer is damaged (possibly a ribbon cable has come detached)... or more likely there is some foreign body or printer part that's come loose and is blocking the printhead carriage path.
A common one I've seen with the C86 and similar is for the head cleaning part become detached from the parking pad (all based far right)... When it does this it springs up into the printheads path and stops it from reaching the parking position.
It requires patience to fix (and some rubber gloves to avoid ink mess) but if notice a part doing an impression of a jack in the box then you can usually gently push the part down and then careful maneuver it over to the right into a connection with the parking pad part.
It's hard to describe without pictures but it gives you an idea of what to look for.
Jan 14, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
