Question about Polaroid CAA-03040S Camcorder
Card Protected When I try to delete a video from the camera, Card Protected shows on the screen. How do I "unprotect" it? toangela@verizon.net
  • 2 more comments
  • MudNMow Feb 09, 2008
    Oops, responded too soon. I "unlocked" the card and it still says card protected.
  • MudNMow Feb 11, 2008
    it is in the camera
  • MudNMow Feb 16, 2008
    I already tried the unlock option... it still doesn't unprotect the card.
  • MudNMow Mar 10, 2008
    The card is in the camera. I took it out and switched the position of the lock. Didn't work. Tried again. Didn't work. It's now in the and still says "card protected."
I have the same camera and I have trouble getting SD memory cards to work. I have the same problem as the person above ( locked ) and it is not due to the physical switch on the card itself. I have read the web . googled it and found that the card reader in my laptop does not read larger size sd cards and can format them if they are not in fat16 format an show them as locked. Someone on another board recd a format through a win2000 and xp machine with the same card reader.
I tried it with a card reader that failed in vista (my laptop) and it worked on win2k and barffed on xp. This is far from a simple answer but I felt it might help.
I have tried the format through the poloroid rohs ( caa-03040s )
through win vista laptop cardreader that works and reads other (properly formatted ) sd cards
and I tried it with Vista sp1 newly installed (what a cumbersome pig) and with a rec'd patch from microsoft. both failed.
then there is a Panasonic sd card format utility that never worked for me on a vista but on xp . much love !
If I had to do it again and save 4 hours of worktime .. get an xp machine and then get the flash memory makers to put out a good freeware utility
Posted on Apr 25, 2008
I already tried that - no avail.
Posted on Feb 11, 2008
  • 82 Answers
Take the card out it will have a switch on the side of it that locks and unlocks
Posted on Feb 08, 2008
  • James wood
    James wood Feb 09, 2008
    do you have it in a card reader or in the camera
How do I unprotect pics on a 0lympus c-765
As it was the camera that put the protection on ..You need to put the card into the camera..And ..UN-TICK each one to unprotect them...The idea of the protected photos is so you cant erase them when you format the card.
Sep 28, 2014 | Olympus Camedia C-765 Digital Camera
How can I delete" write protected" and protected photos from sd card individually?
Unprotect them first, then you can delete them normally. See page 129 of the manual at http://gdlp01.c-wss.com/gds/3/0300001393/01/eosrebelxs-1000d-im-en.pdf
If the memory card is protected, unprotect the card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 07, 2013 | Canon EOS Digital Rebel XS / 1000D IS...
How to unlock a photo in camara
The protect function allows a user to protect a picture from accidental deletion. To unprotect a picture on your camera, scroll to the protected picture that you want to delete, then press the Menu button (the button to the right of the Play button.) Scroll down the menu and you should come to an option that allows you to Protect/Unprotect the picture. Since your picture is currently protected, deselect that option. You should then be able to delete the picture normally.
Alternatively, you could also format the memory card, however this deletes ALL photos and data you have on the memory card. If you are trying to completely clear the memory, this is the best way. After turning on your camera, simply press the Menu button, scroll to Setup, then scroll down to Format. Select Format, it will ask you if you want to format the memory card, or the camera's built-in memory. Format whichever one you want to clear, if you are using a memory card then your pictures are stored on the memory card. It will take a few seconds to format.
Hope this helps.
Dec 05, 2012 | Kodak EasyShare M1033 Digital Camera
How to delete protected images
If you want to delete everything on the card, the easiest way is to format the card. This will wipe out all images (and any other data as well) on the card, whether protected or not. The Format command is in the Setup menu. Details on page 32 of the manual.
To delete individual protected pictures, unprotect them first. From the Playback menu select Protect/Unprotect (the key icon). Details on page 84.
Mar 16, 2012 | Canon PowerShot SD600 Digital Camera
I have over 100 pictures on my camera but when I try to upload them it only says there is one
Could be bad card. I've had it happen many times. Sometimes a photo recovery program can get images off card for you.
Feb 01, 2018 | Kodak EasyShare C743 Digital Camera
My 7 year old daughter has used her camera, and some photos and viseos have a green key on the screen. Is it possible to remove the "lock" so the photos and videos can be deleted? I have loaded...
What make and model camera? On most cameras you unprotect a picture the same way you protected it, possibly by pushing a "protect" button. No matter what, you can clear everything off the card by formatting it. Cards should be formatted each time after you download pictures to a computer instead of deleting individual pictures. FixYa is full of people asking how to salvage pictures from cards they didn't format.
Mar 19, 2011 | Cameras
I want to delete a video but it got "protected" and I'm unable to delete it. How do I unprotect the video in order to delete it?
View video then go into options on the screen you should have a choice to protect and unprotect here.
.If not try protecting it in this screen again and the function maybe double function and will release the protected field .
Steve B
Feb 01, 2011 | Cell Phones
I put my memory card into my Kodak EasyShare C143 digital camera. I press the review button, but all that comes up is that the file is 'Unrecognised'. One out of the three pictures is unprotected, but the...
It sounds as if the card was not formatted for the camera before it was put to use. My suggestion is that you attempt to download the images that you do have to the computer, then format the memory card. Always format a new card and after each time you download pictures from the card to the computer.
Dec 28, 2010 | Cameras
How to delete protected video.
It is only protected because someone set it to be protected in the camera options. You need to set it to be unprotected or unlocked before trying to delete it.
Oct 21, 2010 | Kodak EasyShare V1073 Digital Camera
Need to delete protected pictures
Try to remove first the memory card of your camera. After you remove the card you can see a small button at the side of the memory card. Just slide the small button to unprotected. Insert your memory card back to your camera and try to delete pictures.
Apr 25, 2010 | Kodak Easyshare M753 Slim Digital Camera
Polaroid CAA-03040S Camcorder Logo
115 people viewed this question
Top Polaroid Video Cameras Experts
Eric Sutherland
Rochell Cruz
Tony Parsons
Tony Parsons
Are you a Polaroid Video Camera Expert? Answer questions, earn points and help others
