Question about RCA TruFlat 27F520T 27" TV
Only get about 4 channels
I only get about 4 channels.
  • whoever Feb 12, 2008
    Great, it worked. We tried the solution last night and it worked. We had to put it thru our VCR but at least we have cable, thru the box with all the channels....We thank you very much.
    New Friend:
    Problem Solver:
  • 15 Answers
Tuners are a big source of problems on this model, i may suggest using your cable or sat box as the tuner by going from the video out of the cable or sat box to the video input on the tv, select video on tv and let the cable box or the sat box act as the tuner, if you are using outside ant then use a vcr as your tuner to the set. this is a easy and cheep way to fix your problem.
hope this helps ya.
Posted on Feb 08, 2008
  • 579 Answers
Make sure in the on screen menu that the tuner is set for CABLE or AIR depending on whether you have cable or an antenna. The channel frequencies are the same for ch 2 thru ch 13 but everthing above that is different depending on your source.
Hope Ya Fix It!
How do I add or remove channels on my Roku device?do i need to follow some activation process?
Tips and Trick to Add or Remove Roku Channels
Roku is a streaming device which offers you to choose from 1000's of channels. These channels are available on Roku Channel Store. The channels offer entertaining content for you all day long. Here are a few steps using which you could easily add or delete channels on your Roku. Channels are basically of two categories on Roku:
    ·Installed Channels
    ·Private Channels
    First let us see how we can add a channel in Roku device.
    Adding Roku channels is very easy in Roku all you need to do is to perform the Roku Account Setup for your device and then do the following
      ·Click the "add channel" option.
      ·Enter the credentials and log in to your Roku account.
      ·Activate your interest of channels.
      ·You could now exit the store.
      Removing an installed channel.
      To remove an installed channel the easiest way is to do it from the home screen by the following steps:
        ·Select the channels by pressing the Star (*) button of your remote.
        ·Then select the "Remove Channel" and press "OK" on your remote.
        ·Your unwanted channels are now deleted.
        The channels which are in the subscription can only be removed after the subscription is over.
        There is one more method of removing these channels i.e. through the Channel Store. For this you need to follow the following steps:
          ·Select "Streaming Channels" on the home screen menu.
          ·Select the channels to be uninstalled and press OK.
          ·Select installed channel option on the right side.
          ·Select Remove Channel.
          ·Your channels are now removed.
          Adding private channels with the help of Roku Account Setup.
          You could also add up some private channels to your Roku in the following way:
            ·Log in to your Roku online Account.
            ·Configure the Roku Account Setup.
            ·Select the "Add Channels" option.
            ·Enter the code within 24 hours and watch the channels.
            If you are still facing any technical issues regarding the setting up of your Roku account you could give a call @ 1-844-965-4357.
Sep 12, 2017 | Roku Televison & Video
How can I access the channel store and add more channels ?
It's easy to add a channel or remove channels on Roku. After a while, the extra channels can make it hard to find the ones you want to use. That's when it's time to remove a channel from your Roku.
1. Select a channel from the Channel Store to install.
2. Select the option "Add channel" and confirm the selection when prompted.
·If you have a PIN to setup, you will be prompted to enter the setup PIN number.
·Repeat this procedure for adding more channels to your Roku, or press the Home button.
1.Go to home page, choose My Channels option.
2.Navigate to the channels you want to remove from your Roku.
3.Click the option (* symbol) on your Roku remote.
4.Select the option "Remove Channel" and then click OK. For the confirmation to remove the channel again you need to select the option "Remove Channel".
You can also delete channels from your Roku with the android mobile app or iOS.
1.In your mobile app, select the My Channels tab and click the arrow to the right of the screen.
2.Touch the Remove Button and confirm that you want to remove channels from your Roku.
If you are facing any issues while activating the Roku for adding or removing channels you can contact to their technical support team @ 1-844-965-4357
Jan 03, 2016 | Roku Streaming Stick
Channel numbers missing
local channels are usually below a channel 1000. they are always on same assigned channel. If your cable box or tv has it, it has option to not display channels with no service on them. you can't reassign the channel numbers. they are channels but not being displayed.
Apr 10, 2014 | Televison & Video
How do I unlock my scanner?
Channel Lockout You can lock out a channel so it is not scanned. Channel Lockout does not erase the frequency from the channel. You can lock out up to 50 channels, including the Priority channel.
Lockout information is retained in the memory when the scanner is turned off.To Lock out a Channel
Example: Suppose you want to lock out Channel 2 because it stops on transmissions you don't want to hear.Press LOCKOUT when the scanner stops on Channel 2.The scanner locks out Channel 2, Then it immediately advances to the next channel that is not locked out, and resumes scanning.In the Manual mode, press LOCKOUT to lock out the displayed channel. Pressing LOCKOUT does not advance to the next channel in Manual mode.L/O appears in the display to indicate the displayed channel is locked out.Whenever you want to search for channels that are locked out, press MANUAL repeatedly to go through all 50 channels. If a channel is locked out, L/O
appears in the display.Restore a Locked Out Channel To unlock a channel so that it can be monitored during scanning:1. Press MANUAL repeatedly to find the locked out channel.2. Press LOCKOUT again to unlock the displayed channel. L/O no longer appears in the display.Restore All Locked Out Channel To unlock all channels, you must be in the Manual Mode.1. Press MANUAL.
2. Press and hold LOCKOUT to unlock all channels. The L/O indicator goes out on any channel previously locked out.
Sep 18, 2011 | Uniden BC248CLT Base Scanner
Toshiba 42 lcd cannot delete channels I use the manual channel set and select Not Viewable for channels I don't want to see. Then as I click through the channels, the deleted channels show up again.
Also have a 42" Toshiba and had the same problem, then had issues moving the channel order while some channels were set to skip.
What I ended up doing was retuning the tv. Then went through the channel list (Menu -> Setup -> DTV Setting -> Channels) and changed the number of the channels I didn't want to 1000+ (using the red button, ie 1001, 1002, 1003...). This in itself does not change the channel order, but when I then move these channels to the end of the channel list and because they are numbered numerically I can be sure I don't miss any.
Next I went to the channel options (Menu -> Setup -> DTV Setting -> Channel Options) and marked all the channels I'd moved to the end of the list as channels to skip and locked. This does not remove the channels from the EPG but it does move them to the end of the list and when scrolling with the channel +/- buttons these channels will not be selected.
Ideally I would also like to delete channels such as QVC etc altogether and would love to know if anyone has a more effective solution to this issue.
Aug 15, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
What is the frequency for UFR650?
these are FRS radios, and use only the 14 FRS channels within the GMRS band. they will not operate on the other GMRS channels in the GMRS band. FRS Channel Frequency Assignments: Channel 1: 462.5625mhz Channel 2: 462.5875mhz Channel 3: 462.6125mhz Channel 4: 462.6375mhz Channel 5: 462.6625mhz Channel 6: 462.6875mhz Channel 7: 462.7125mhz Channel 8: 467.5625mhz Channel 9: 467.5875mhz Channel 10: 467.6125mhz Channel 11: 467.6375mhz Channel 12: 467.6625mhz Channel 13: 467.6875mhz Channel 14: 467.7125mhz
May 23, 2006 | Unwired UFR650 (14 Channels) 2-Way Radio
RCA TruFlat  27F520T 27" TV Logo
56 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
