I have a problem in that my microphone doesn't work even though I have a working mic, and with the other hard drive booted it works. Is there a software troubleshooter I can download to check to see what the problem is?
-   Mine is plugged in and not working. The wire has slack and cannot have been pulled apart. I think these microphones just ****... probally wont buy from trust unless i get the answer
-   Guest
Feb 10, 2008
-   my microphone is not working idid try every thing i ch
some of the wires have come loose inside the mic,would you have the diagram for this type of...
(More)
some of the wires have come loose inside the mic,would you have the diagram for this type of mic,thanx
when my mic is plugged into the usb my comuter's speakers headphones and everything gives no...
(More)
WHEN MY MIC IS PLUGGED INTO THE USB MY COMUTER'S SPEAKERS HEADPHONES AND EVERYTHING GIVES NO OUTPUT,WHAT AM I DOING WRONG???
i have problem with c-1 cause it produce high noise... i have mic800 behringer processor... can you...
(More)
i have problem with c-1 cause it produce high noise... i have mic800 behringer processor... can you help me with functions of this processor ... what do i have to do to connect c-1 with mic800 so i could record normally
My tascam dp 02cf won't power up it says: Sreset err. Please power off. It does have the correct...
(More)
My tascam dp 02cf won't power up it says: Sreset err. Please power off. It does have the correct power supply 12 volt 2500 ma this is what came with it so it is not that. Thanks
