Question about Car Audio & Video
Used power stering pump asembley for 1987 cheverlet s10 pickup 2.5 four cylender
  • i nee a power stering pump asembley for 1987 2.5 four cylender used pump!
  • 2,039 Answers
Call our local scrap yard they gonna have what you whant thanks for using fitya pierre235
Posted on Feb 08, 2008
Does a 1985 chevy s10 have fuse for fuel pump or throttle body and were are they
Yes it does, and also a fuel pump relay controlled by the ECM or PCM.
Can be either problem.
Mar 05, 2013 | 1987 Chevrolet S-10 Pickup
Have chevy s10 4 cyl. 2.5 pickup. For some reason it is using gas. I get 4 miles to a gallon. Can smell raw gas when standing behind it.
well you leaking gas either from your fuel pump tank float assembly inside the tankand gasket is bad that seals the fuel in or possibly a bad fuel neck aka filler tube also check your fuel lines and make sure all clamps are tight
May 05, 2011 | 1987 Chevrolet S-10 Pickup
1987 chevy s10 fuel pump relay clicks, is there a fuse to the pump in fuse compartment if so which one.
The fuse feeds the relay, if the relay is clicking it has power, try replacing the relay before you do anythuing else. [ check the numbers on the relays in the box there may be another what's the same.
Jan 12, 2011 | 1997 Chevrolet S-10 Pickup
I would like to know where and what does the fuel pump test connector look like on a 1987 S10 pickup??
Will be a single wire, under the hood, on driver side, by fire wall, could be green or red, will have a female connector at the end, that's where you add voltage to test fuel pump.
Jul 09, 2010 | 1987 Chevrolet S-10 Pickup
I HAVE 1987 CHEVY S10 2.5 4CYCLINDER PICKUP TRUCK LOOSING POWER AN MANIFOLD RUNNING HOT
If it runs ok cold and worsens as the engine warms up or when you accellerate hard the catylitic converter is stopped up.
Mar 29, 2010 | 1987 Chevrolet S-10 Pickup
1987 chevy S10 engine idle problem
relace the throtle air idle valve.The temp switch will allso cause this problem.
Jul 19, 2009 | 1987 Chevrolet S-10 Pickup
Can a 1988 chevy S10 2.5l ecm be used in a 1987 chevy S10 2.5l
the numbers on the ecm must be the same . you have 2 sets of numbers and the bottom set should be the same.
Jul 15, 2009 | 1987 Chevrolet S-10 Pickup
I need a 1987 chevy S10 vacuum hose routing diagram
Go to Autozone.com, become member, will give you repair manual,location of parts,diagrams.
Mar 28, 2009 | 1987 Chevrolet S-10 Pickup
How do i surf the internet
u need a internet service
Feb 08, 2008 | Car Audio & Video
Car Audio & Video Logo
76 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
