Question about Vizio P2 42 in. HD-Ready Plasma Television
Cable connection on 42'' VIZIO
How do I fix a broke off cable male connector 42 vizio. While taking the connector off the male part broke off. Now I can not even hook up an inntena. help
  • 2 more comments
  • willard1962 Feb 08, 2008
    Thanks That what I was looking for, Did not mean to be dis respecful last time.
  • Anonymous Mar 13, 2014
    dtv/tv cable antenna male connector broke off . Can I solder a new one on ?
  • Anonymous Mar 23, 2014
    cant hook csable to tv bc cable connector broke off
  • Anonymous Mar 24, 2014
    cable connector male is broken off. model no. 24SL410U
Bring it to a repair shop are us the yellow red and white cable
Posted on Feb 08, 2008
    Master:
    Sergeant:
  • 440 Answers
Use neddle nose or dental tools ok thx nick
  • 1 more comment
  • nick helpap
    nick helpap Feb 08, 2008
    thx for trying thats all i get if u do it right it would a be a fix ya ok
  • nick helpap
    Unless you know how to open a TV; set find where the connector used to attach; and can solder, EITHER
    a) bring it to a repair shop,
    b) get a new TV,
    c) or if it has RCA jacks (red,white,yellow) you can use a vcr tuner to bring in the channels without the cable jack.
  • nick helpap
    it so ok thx nick
Female coax connector broke on vizio smart t.v.can i buy an adapter or reroute out of cable box to t.v.
If the cable box has an HDMI or video output, use one of them to connect to the TV instead. The female coax connector is not easily repaired and you can't reroute or adapt anything to fix it. You will need to replace the TV main board if the HDMI/video connection is not an option.
May 05, 2017 | Vizio Televison & Video
Cable connection broke
Need to know where it broke. If it is the F connector that is attached to the tv then you need to take it apart to fix this. It will be soldered in so you will have to know how to do that or get someone that can. Once you have it out it is a very easy fix.
Mar 12, 2016 | Vizio Televison & Video
Have vizio tv trying to hook audio out puts of tv/dish network for component usei nto my stereo receiver what do i do
The easiest way to connect this is to find the cable going from the receiver to the TV and disconnect it from the TV.
Connect this cable to the back of the stereo receiver where it says "in" or "input".
Next take another cable and connect it from the stereo receiver output to the TV.
Daniel Busa
DISH Network Customer Service
Feb 06, 2011 | Vizio E470VA 47 in. HD-Ready LCD TV
How to connect headphones
  1. This TV doesn't have a standard 1/8" stereo jack, so you must use the RCA connectors on the back of the TV.
  2. Purchase a 2xRCA Male / 1x3.5mm Stereo Female Y-cable, such as the one available here.
  3. You will also need a set of headphones, preferably a powered set.
Jan 20, 2011 | Vizio E420VL 42 in. HD-Ready LCD TV
I pulled the TV/Cable TV/HDTV input connector out of my VIZIO TV. How is it fixed.
Hello; You will need to replace the PCB with the tuner on it. The RF connector that you broke off is almost always a part of the tuner and replacing the connector is NOT recommended. John
Jan 09, 2011 | Vizio Televison & Video
Our 42" Vizio will not display/play sounds when
Hello
One board takes in the HDMI as well as the other signals. Sometimes part of the board breaks and that is what sounds like has happend in your case. This is a fairly common problem and most people tend to just live with it. Others sell thier tv and a few find the number of thier board to see if one is available on ebay or shopjimmy. If you are comfortable with electronics the board is not hard to replace.
Im sorry your HDMI broke....
I hope this helps
Nov 28, 2010 | Vizio VL420M 42 in. HDTV
Can you connect a 2 yr old 42 in vizio to your computer to watch shows ????????// what type of cord is used and who sells them?/ Best buy , hh gregg, sam waltons house line opps wall mart / sams ???
Easiest will be the VGA cable (15 pins on each end), you will also have to set the PC to the native resolution of your TV otherwise you will get the message on the screen saying "format not supported".
You will also need an audio cable, it has male mini stereo phone plug at each end, one end will go into the green audio out athe PC sound card, the other end will go into TV PC audio line input (green jack).
Best Buy should have them.
You should down load the user manual and read all about your TV.
http://vizio.com/documents/downloads/hdtv/GV42LF/Manual.pdf
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Aug 06, 2010 | Vizio GV42L 42 in. LCD Television
Vizio 42 lcd connected to cable sound is ok but
is the cable in all of the way? sounds like something is interrupting the transmission. i know the tv is large but try using it somewhere else. this will distinguish weather the problem is the tv or the cable
Jul 23, 2009 | Vizio VO42L 42 in. LCD TV
HDMI Cable?
Hi CrysR,
Although you may not be able to locate a cable with one HDMI male end and one USB male end, it is possible you may find a solution with an adapter.
I recommend looking for an adapter that will accept USB input and output to either HDMI or DVI. If you only locate DVI, you can then add a DVI to HDMI adapter at the end.
Be aware with these extra pieces and signal transfers included, it may degrade the quality of your picture.
Thank you,
Jason,
Go Ahead. Use Us.
Jul 05, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Tv coax f connecter is broke off cannot hook cable cord on it. or antenna
I looked up the manual for this TV and it has composite (RED, WHITE, YELLOW) and component (RED, GREEN, BLUE) connectors as well.
Are you using a cable or Dish box? If so, those boxes usually have output in Coax, Composite, and Component formats. You could just run that type of cable. If you use Component you will also need another cable set (RED, WHITE) for audio.
If, on the other hand, you do not have a cable box and you are using your TV's tuner you only have two options. You can repair the broken connector or you can route the Coax through an inexpensive VCR which will allow you to convert it to Composite cables. In this case, however, you'll have to use the tuner in the VCR, not the tuner in the TV to change the channel. Sorry it's not the best of news.
I want you to know that I'm not paid for this. It's a strange hobby I know, but I like to help when I can. While I cannot physically repair you TV, I hope you've found this information at least helpful and will rate it positively. If you have more questions please don't hesitate to ask. Thanks, and good luck.
Jan 03, 2008 | Vizio GV42L 42 in. LCD Television
Vizio P2 42 in. HD-Ready Plasma Television Logo
637 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
