Question about Mitsubishi WS-65819 TV
Arched or bowtie effect
Our tv has a curved picture. I hae seen several people have the same problem but don;t seem to have found a solution.
  • OC family Feb 08, 2008
    I unplugged the Tv for about 20 minutes & it seems to be fixed. I printed the solution above though just in case it cmes back..........Thank you for yor help!
  • 113 Answers
You have bad convergence Ics they are mitsubishi part # 267P150010 Generic part is STK 392-570 and they are at locations Ic8c01 and Ic8co2 on the deflection board. If you can solder you can take these out replace them and fix your problem for about 100 dollars. Best of luck
Josh
Posted on Feb 08, 2008
That means there are bad solder connections on the ics it will be back and sooner or later it will not just "pop" back into place. The sooner you fix the problem the better off you are. Hope this helps.
Josh
Rca projection tv mod:P52937SG
It seems like a convergence fault. Either the convergece cirlcuit, or the convergence settings have the fault To make it sure, try to adjust convergence adjustment. You have to enter its service mode option to do this. http://electronicshelponline.blogspot.com/ Check this link and pull up older posts. One among them have details about how to adjust convergence for projection television. If no effect can be seen during convergence adjust, make sure that the convergence board have the fault. You have to check further more into.
May 27, 2013 | Televison & Video
I'm getting a bowtie effect with the picture and the colors are sepperating
Ur tv have a problems,known as Convergence problems.This problems very common on all DLP tvs.Ur tv convergence board must have be replaced 2 STK convergence ICS,some or all it resistors.U know basic soldering,have tools,soldering iron,solders?Tries Websites like TvrepairWord.com,TvrepairKits.com to buy a covergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Jun 01, 2010 | RCA P52937 52" Rear Projection Television
Rear Projection - Color convergence/bowtie effect
Hi
Thanks for using FixYa. From what you have described it seems that you have to replace the convergence IC and also check the power resistor, if values are not exact you have to replace them. These ICs are located behind the black heat sink; you can see once you open the back off the TV. Also, the convergence board should be checked for cracked solder joints and please make sure to check the resistors as if they are shot the ICs might blow again. All this is only recommended if you have electrical expertise and know how to solder/re-solder components, if not then you should get this done by a professional. The typical cost to get this fixed by a pro is around $250-$300. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Apr 04, 2010 | RCA HD56W66 56" HDTV
RCA HD52W69D with a slight convergence & bowtie problem
Ur convergence it dead.If can't auto adjust must replaced.Tries Tv repair World.com,Tv repair kits.
Nov 04, 2009 | RCA HD52W59 HDTV Projection Television
Oversized picture problem
Several possibilities, if you use a set top box to get your signal like a cable box or satellite receiver they will have settings that effect picture size. It could be a high voltage problem inside the TV causing an effect called blooming, if that is it you can usually change brightness and or contrast and see the picture get smaller and larger. I don't recall that set having any customer settings that could give that symptom.
Sep 11, 2009 | Mitsubishi CS-40503 TV
Television picture does not work when first turned on
It seems that there are capacitors in the power supply which have dried or leaked, It is vurtually impossible to diagnose sight unseen however, the fact that it effected the three colours I envisage that problem to be associated with the supply, also the curving effect makes me look there, it seems that there is a ripple in the AC. I am assuming that it would take around 1.5hrs and cost of caps. This is working on the assumption that the fault is what I have listed without looking at it. Cost may be around the $150-$250 but don't quote me, I can't see the fault so it is an educated guess only...Phil
May 18, 2009 | RCA R52WM24 52" HDTV Projection Television
Color distortion and arched picture
It is problem of failure of convergence ICs or related circuit. Please confirm model number of your TV that is Sony KP-57WS500 to help you out.
It would be nice if you could past TV snap shot here for easy understanding.
Thank you.
Oct 02, 2008 | Sony KP-57WS500 57" Rear Projection...
Arched picture on Sony KV-34XBR800
Your TV has problem in Pin-Out area. I know its technical term but I have no other words to explain it. TV needs qualified technician to fix it.
Jun 11, 2008 | Sony FD Trinitron WEGA KV-34XBR800 34" TV
Arched picture at bottom seperating the green and red
Your tv has a convergance failure. the convergance ic's need to be replaced. Upgraded part # STK392-150 or STK392-160. Both ic's should be replaced to prevent future failure of other colors.
May 20, 2007 | Toshiba 43H70 43" Rear Projection...
Mitsubishi WS-65819 TV Logo
124 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
