I would think there would have to be a solution to this problem. Has anyone else found the fix for the "flashing Hello"???
Same Problem
Mar 22, 2009
-   can anyone tell me how to get the disk out of the DVD. It is not responding. Just flashes HELLO and won't come on. I have tried everything short of taking the thing apart. That may be next. -   sollie60
Mar 01, 2009
-   hooked up all cables as instruted. comes on flashing hello, when the flashing quits I press setup but it has no on screen display.just a horizontal sink pattern ,so I can't configure the setup.-   Guest
Jan 30, 2009
-   i started out loving my protron which i bought from qvc as well december of 2005. i made dvds of all my vhs tapes and dvc tapes but just this past christmas i couldnt do it. at first it took several tries to get the disk out then it would say it recorded but would not finalize and nothing would be on the disc yet i couldnt use it anymore. then we would have to cut it off by the plug. then the hello went to a couple of line but no interaction with the remote or front panel. now nothing shows up on the display of the unit yet protron still goes across the screen. i am on hold with qvc now.
-   Guest
Jan 19, 2009
-   My Protron keeps flashing hello. Can not use remote, can not turn off/on at machine. What can I do? I bought it from QVC a couple of years ago and did not use it until now. Not able to return it to QVC because they only allow 30 days after purchase to return.-   grannyof14
Nov 20, 2008
-   We have the same problem. HELLO flashes and we unpluged and no help.
I think QVC should take all of the units back and trade for one that works. I understand that the company is out of business but QVC has a reputation to uphold so it would be in their interest to replace the units and make the consumer happy. We have never been able to use the unit and we keep trying. It wasn't cheap !-   pncsell2
What happened to me was the recorder flashed "hello" and I changed the tv source to video and nothing showed up. I unplugged it and went to a different tv. Hooked it all up, turn the tv source to video and walla I got the setup screen. Once I went through the setup everything seemed to work except my issue with the time setup in 24hr mode instead of 12hr mode. Anyway, hope this worked for you.
Fixed mine by opening up and replacing ide cable to the DVD burner. Was flashing hello. When opened up and touched the ide cable it would spin up the drive for a second. Its possible it was loose connection to the power plug in the drive but replaced ide cable just in case. Has been working perfect since. Very roomy inside and easy to do.
Was this helpful?
Yes
No
Popular Solutions for Protron PD-DVR100 DVD Recorder
I do not hear the dialogue voices with my Protron DVD recorder. All background noises can be heard...
(More)
I do not hear the dialogue voices with my Protron DVD recorder. All background noises can be heard but not dialogues.
I have a protron pd-dvr100, dvd recorder - how can I get the set up mode to appear on an old tv set,...
(More)
I have a protron pd-dvr100, dvd recorder - how can I get the set up mode to appear on an old tv set, in order to get the proper setting and thus us it, your help would be much appreciated, thank you. At this time I am using a coaxial cable set up to rf in and rf out ports to a charter cable source.. the tv picks up a few channels, yet appears not to notice the dvd player.
