Question about Lexmark P6250 All-In-One InkJet Photo Printer
Carrier Jam with Dell All-In-One 942 Printer
I get error message: Clear carrier jam. Preceding this, the carrier slams
violently back and forth. I clearned out any debris. The plastic strip on the
carrier is attached correctly. I cleaned it. Is there a sensor within the
carrier itself that may be the problem. Please help.
  • 1 more comment
  • art art Feb 08, 2008
    The response I received is in regard to a paper jam, not a carrier jam message. Additional suggestions from your Experts will be welcomed. Thank you.
  • art art Feb 10, 2008
    Having a response that "you will have to get
    this unit serviced fully one, that can only
    solve the problem" does not sound like expertise but only a logicaly default.
    Therefore, I cannot find this as acceptable.
    Thank you.
    For clarification, this is a DELL All-In-One 942 Printer. Thank you.
    Guru:
  • 1,894 Answers
You will have to get this unit serviced fully once. that only can slve this problem
Posted on Feb 08, 2008
    Genius:
  • 3,587 Answers
Whoa..is this a Dell or a Lexmark unit? Here's a chat option at Lexmark, if that's what this is....
http://support.lexmark.com/static/229-1-0-462.html
Got backup?
  • 1 more comment
  • Patrick Michaels
    Patrick Michaels Feb 10, 2008
    still awaiting a clarification on which printer you have. The one in your title, and the one that's listed, are from different manufacturers.
  • Patrick Michaels
    Hope this works out well for you, amigo.
  • Patrick Michaels
    Great,..as a Certified Dell dude, then I can be more helpful, if you need any more help. The Carrier Jam, is in fact, a function of three interlocking mechanisms. I have a repair manual, that I can upload to the site, or work with you directly to resolve this, if it's still a current issue.
    Genius:
  • 3,422 Answers
Try all these steps one by one to fix ur problem:
1)lift up the scanner to reveal the cartridge compartment; under the chrome rod on which the cartridges run there are two small gaps about 8cm apart. In the right one should sit the paper sensor which is a small black rod that hooks downwards; the problem I had was my sensor had bent up and out of the gap so all I had to do was bend it gently back into position using a small screwdriver and now everything works fine!
2)clean the chrome rod with a moist napkin.
3)under the chrome that the carts are running on there are two small tips just push them in.
Goodluck,
Please don't forget to rate me as fxya..
  • 1 more comment
  • Priya darshan Feb 08, 2008
    If you have shaken your printer and found nothing inside I have the
    solution for you. I took the printer apart and I noticed that there is
    a plastic lever that detects when there is paper in the printer. This
    lever can be bent in such a way that it does not return to its "no
    paper" position and so you get a paper jam condition.
    I hope ur problem gets solved soon..
    Goodluck once again
    And please don't forget to rate me as fixya for my efforts to solve your problem..
  • Priya darshan Feb 10, 2008
    The solution which i have given you is 100% working solution please give it a try again.
    Most of the people have reported success with this solution..
    Yes even i agree you have to get it serviced but i gave you my best possible solution..
    Hope your problem gets solved soon..
    Master:
    Sergeant:
  • 440 Answers
Ya usally that sensor will be the issue take it to local small repiar shop see if t hey can order sensor but i think you best bet will to be to get new one ok i have dell 920 lasted wile also now i own lexmark 50 bucks wallmart very nice ok thx nick thx for using fix ya
  • 1 more comment
  • nick helpap
    nick helpap Feb 08, 2008
    also ruber bands that move that can get loose over yrs
  • nick helpap
    please dont forget to rate me ask fix i was 1st to respond thx nick
  • nick helpap
    ok cool guy thats a good tip give u that try that 1st if it dont work for u tho ist bad sensor like i 1st said thx nick
Clear carrier jam
>> Remove the print cartridges.
>> Gently move the carriage from Right to Lift, Left to Right twice.
>> Re-insert the print cartridges
>> Try printing.
It may help.
Dec 28, 2013 | Lexmark International Lexmark 5300 Series
Dell 942 carrier jam loud banging
you going to have to replace the carriage ASSY. That sound means the carriage is offline and it needs repair or you got something blocking or jammed in the printer so good that its doing this.
Diag : bad carriage or severe carriage jam
prog: Repair/clear jame if any or new printer
Thanks please do click the accept button for my efforts.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 07, 2010 | Dell 924 All-in-One InkJet Printer
The ink carrier has a clear carrier jam message...
If the printer carrier is slamming into the side of the printer, please try the following:
  1. Disconnect the power supply from the back of the printer.
  2. Open the front cover of the printer where the cartridges are located.
  3. Look for two black bands that span from left to right (they should have one serrated side and one smooth side). Just above the black bands there is a transparent strip; this strip is called the Encoder strip.
  4. Flick this strip lightly with your finger to make sure that it is running smoothly from left to right. You may need to do this two or three times. CAUTION: Do not pull the strip!
  5. Close the front cover of the printer and reconnect the power supply.
  6. If the problem persists, then its a hardware issue and you should contact Lexmark for replacement of the printer.
Apr 08, 2009 | Lexmark X5470 All-In-One InkJet Printer
Carrier jam
From what you are saying you are getting 'clear carrier jam' because of a misalignment. The jam error message is a generic message that applies to a multitude of things. The carrier while is in right, might not be sitting right. A piece of plastic that holds the carrier might be broken or the printhead might be messed up. Anything that causes it to not sit the way it wants will cause that error message.
Feb 10, 2009 | Lexmark X4270 All-In-One InkJet Printer
Clear carrier jam
hi,
Follow the wizard on the following website , to help you to pinpoint the problem
http://tinyurl.com/3nh59x
Thanks
Proton
Oct 02, 2008 | Dell 924 All-in-One InkJet Printer
Carrier jam
Hi , check the belt may loose , the tensioner not working or belt not in pulley alignment.
Mar 04, 2008 | Dell 942 All-In-One InkJet Printer
This morning I replaced the cartridges in the Dell 942 printer, they jammed to the left which made a loud grinding noise and the cartridge jam error came on.
I solved the problem by turning the printer on with the top up which moved the cartridges to the right a little so I could reach back, push one down a little manually which freed them to move over to the middle.
Feb 28, 2008 | Dell 942 All-In-One InkJet Printer
Carrier Jam
This happens, when printer is old one or it has either dried ink on carrier stall bar or some obstructions. Move the carrier stall manually 3-4 times from left to right and then take a damp cloth and clean the metal bar on which carrier stall moves. If you have kleenex and WD-40 nothing like that. Lubricate the bar, with that or some other lubrication agent. Do it once in a month, if printer is too old and/or u use a refilled cartridge. Dell is great!
Jan 03, 2008 | Dell 942 All-In-One InkJet Printer
Carrier jam on dell 924 printer??
I was able to fix this issue on my all-in-one 944 printer. What happened was that one of the ink cartridge lids had popped open. The hard part was that the carrier was stuck on the far left side, and I wasn't able to pull it over for easer access. However, I was able to fit a finger in and push the cartridge back down. Then when I turned the printer back on the error went away.
Hope this helps
Dec 13, 2007 | Dell 924 All-in-One InkJet Printer
I have had the clear carrier jam problem the past 3months, spoke to over ten technicians but no one seems to have been able to resolve it, let alone clearly explain the cause. But just to say buy another printer.
How many Dell 942 printer am I going to buy!!!!!?????
Sep 09, 2007 | Dell 942 All-In-One InkJet Printer
Lexmark P6250 All-In-One InkJet Photo Printer Logo
74 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
