Question about Fuji FinePix A600 Digital Camera
No power with new batteries
I put some new batteries in the camera and tried to power up. No date and empty battery logo. Camera then powers off. Tried a few sets of new batteries and still the same problem.
Any solutions?
  • AnahMc Feb 19, 2008
    i have this exact problem. new batteries still arent working. flashes no date/time then shuts off. sometimes will take one picture then shuts down.
  • lauraebeth Feb 20, 2008
    I keep buying new batteries for the camera and they die within taking 2 or 3 pictures...I don't use rechargable batteries, just energizers, what should I do?? I've had the camera for almost a year and just started having this problem a few months ago...I'm pissed!
Same problem here, pluged camera in to charge battery and doesnt charge nor turn on. have had camera for year and have only been able to take three pictures. did not spend 169.00 to have no camera to take pictues with. am mad.
Posted on Jun 23, 2012
Im having the same prob with mine. I live in Jamaica and theres no Fiji services here so what would be the next step?
Posted on Oct 01, 2008
  • 28 Answers
Needs reload battery settings into the camera, contact fuji services
Posted on Apr 04, 2008
Why does battery go flat quickly even when not in use
If the camera is not in use, remove the batteries.
May 21, 2016 | Fuji FinePix A850 Digital Camera
Tip
DATE RESET PROBLEM ON DIGITAL CAMERA
Have you encounter on your camera that the TIME and DATE are always cleared once you turning ON? Menu of the date setting appears everytime inserting the battery and turing the power ON?
Dont worry the problem of your camera is only a minor. For your technical information, all cameras have a capacitor together with board that provide power to save your date setting or its work as a battery.
Once you open you camera and you found out color green stain can be seen in the part of the said capacitor. You need to clean first by brush and make it sure be gently while brushing the capacitor just to remove the stain.Then try to turn On your camera and set the date and time, after this turn off and remove the battery for a second. Once again put the battery on your camera and turn On. Once you need to set the date again it means the capacitor was damage and need to replce new.
if you have knowledge about repairing electronics what you need to do is remove the damage capacitor and replace it new with the same specifiction and size.
I hope my tips will help you
Good luck and thank you
on Jul 21, 2010 | Cameras
My wife is complaining that every time she turns off/on the camera she has to reset the data/time. I understand that when the batteries are changed the settings may be lost, but not simply when the camera...
Sounds to me that there may be another battery inside the camera that is going bad.
Issue: Everytime I power on the camera the Date / Time needs to be set.
Solution: Replacing the Date Battery for the PowerShot A480.
Replacing the Date Battery. If the Date/Time menu appears when the camera power is turned on, the date battery charge is low and the date and time settings have been lost. Please purchase a lithium coin battery (CR1220) and replace it as follows.
Please note that the first date battery may appear to expire relatively quickly after you purchase the camera. This is because it is installed in the camera at the point of manufacture, not when you make the purchase. caution.gifBe particularly careful to keep the date batteries out of the reach of children. Seek medical assistance immediately if a child swallows a battery since corrosive battery fluids can damage the stomach or intestinal walls. 1. Confirm that the camera power is turned off.
2. Open up the battery door / cover and remove the AA Batteries.
3. Remove the date/time battery holder.
4. Grasp the battery and slide it in the direction of the arrow.
a480backupbatt.jpg 5. Insert a new battery with the (+) side facing up.
6. Replace the battery holder and battery cover.
7. When the Date/Time menu appears set the date and time.
note.gif After purchasing the camera and turning on the power for the first time, although the Date/Time menu will appear, you do not need to replace the date battery. If you ever dispose of your camera, first remove the date battery for recycling according to the recycling system of your area.
Dec 31, 2010 | Canon PowerShot A480 Digital Camera
Hello. My v1233 powers on, I am prompted to put
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery
c. Without the memory card, turn your camera on.
4. Please test with the a different battery
If you do not have access to another battery Try these steps instead:
  1. Please take the battery out of the camera.
    b. Insert the charger into the unit from the main socket and turn the camera on.
If the camera works you will need to replace the battery.
Steps for uploading new firmware:
Connect the camera with the computer.
Turn the camera on.
Click onto the link and follow the instructions.
http://wwwuk.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=11647/11660&product=EKN033563
If successful please give me the feedback as a rating or recommendation. Thank You
Dec 08, 2009 | Kodak Easyshare V1233 12.1MP Digital...
Camera won't work even with new batteries
Just had that same thing happen.
Try lithium batteries...Should solve it.
Jun 14, 2009 | Olympus FE-210 Digital Camera
Battires keep dying after first shot
Digital cameras require vast amounts of battery power. First check to see if the camera settings are on the simplest or default settings. If you are using batteries from some of the big warehouse stores check the expiration dates. The next thing you can try are the batteries labeled specifically for digital camera use. They have stronger holding power for the abuse the digital cameras can put on a battery. they are more expensive, so watch your overall cost. Another way you could go is to use rechargeable batteries and keep rotating fresh, charged batteries in thed camera.
Dec 22, 2008 | Canon PowerShot A720 IS Digital Camera
Battery empty message
Put brand new batteries in. The battery empty message means there is no "juice" or power left in the batteries. If they are recharagable batteries, "re-juice" them (charge them).
Nov 24, 2008 | Olympus FE-230 Digital Camera
Camera power problems?
It's not the battery. It turned out to be a memory card problem.
I took out my old memory card and put in a new one. It started working properly after that.
Sep 17, 2008 | Fuji FinePix J10 Digital Camera
Clock always reset to default upon power up
Either the replacement battery was dead or the camera needs to be serviced. If the date/time needs to be reset every time the camera powers up, the camera is not receiving the power it needs from the date battery.
May 04, 2008 | Canon PowerShot S5 IS Digital Camera
Battery Empty
the little icon battery looks empty on the lcd screen? I would not worry about especially if your camera is taking flash pictures and lasting a good while....for my battery indicator on my two different cameras looks half charged and they high amp 2700ma. maybe its going over the mark. try putting in common batteries like duracell and see if it dont return to full indication charge.
Aug 31, 2007 | Olympus Camedia C-725 Digital Camera
Fuji FinePix A600 Digital Camera Logo
196 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
