Question about Protron PD-DVR100 DVD Recorder
Flashes "hello" in display and will not operate at all
Is this thing garbage?
  • 1 more comment
  • livewire9 Feb 11, 2008
    It's only 2 years old, I got it on QVC and they no longer handle any of Protron's line... I now know why... I called Protron too... Very rude CSR's,,, no help at all. I'm not gonna give up with QVC just yet though... This wheel needs some greasing!!
  • jerryjazz Feb 18, 2008
    I have 80 dvds that need to be finalized but the unit does not work anymore
  • Anonymous Sep 04, 2008
    flashes "hello", can"t turn off power, will not eject disc, and disc drives runs continously as long as power is plugged in.
Yes I agree with your analogy , its junk , so are the operating instructions
Posted on Feb 10, 2008
Boots; but screen display is garbage w erroneous flashes.
have you tryed resetting your display settings?
its in your control panel.
Apr 08, 2015 | Computers & Internet
Why my unit keep shutting off after few seconds and then turbo light keep on flashing?
Operation =
Flashing Display Timer = Yes
Turbo =
LED Display = E1
Explanation and Checking points = Indoor unit room thermistor error - Open or Closed Circuit - Check and replace if required
Operation = Yes
Turbo =
LED Display = E2
Explanation and Checking points = Indoor unit pipe thermistor error - - Open or Closed Circuit - Check and replace if required
Operation =
Turbo = Yes
LED Display = E3
Explanation and Checking points = Indoor unit fan motor malfunction - Check and replace if required
Operation =
Turbo = Yes
LED Display = E6
Explanation and Checking points = EPROM error - Check and replace PCB if required
Operation = Yes
Turbo = Yes
LED Display = Flashing
Explanation and Checking points = Option code error - Check and input new option code if required via wireless remote controller
Operation = Yes
Turbo = Yes
LED Display =
Explanation and Checking points = Outdoor unit temperature sensor - Open or Closed Circuit - Check and replace if required
Jun 18, 2014 | Samsung AQV36JA Classic 36000 BTU Single...
Samsung DMT - 400 delicate light blinking
please follow this steps and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 09, 2013 | Dishwashers
Hello i have a problem with my Citizen Cyber Aqualand NX. He is flashing FILE. I have tried to do the garbage collection, but he said Fail. Also the Formatting of the Flash memory dos not work, and said...
I got last year same problem, easy to resolve :) I was doigng GC and i got my watch in failur exactly like yours. Solution? Buy 4 fresh, alkaline, good brand batteries. Put it in charger unit. Let the watch to charge for 12hours. After do garbage collection again or formatting if you cant do GC. If you got again fail, charge again it for 12 hours. I did it for 3 times and...the third days, I got "Done!" and solved :) It happens when battery is not full charged, so do GC just when is very charged. I love my Cyber, but sicne seems that GC collecting drink a lot of energy seems that low level battery doesnt let the inside flash memory to work well when try to format/GC datas.
Jun 01, 2011 | Citizen Promaster Cyber Aqualand Nx Dive...
It keeps flashing file! And it's not logging anymore dives.
When the amount of available memory in flash memorybecomes low, "FILE" flashes in the lower left corner ofthe display in all of the submodes of the standard mode as well as in the dive mode. Thewatch automatically switches to the flash memory statusdisplay of the system monitor mode when the water sensor gets wet while thiswarning function is activated. Please note that although it is possibleto use the watch for diving in this state, log data may not be recorded inflash memory during diving. The file error warning function is also activated andadditional log data is not recorded if the duration of a single dive exceeds 2 hours or if morethan 15 dives are made in a single day. The file error warning function may also be activated whenthe water temperature during diving is low. It may not be possible to receive watchsettings by data communication while the file error warning When the watch has switched to the file error warningdisplay, perform the garbage collection procedure in the system monitor mode of the standardmode. Thedisplay returns to normal following completion of garbagecollection. Garbage collection begins when button (C) is pressedfor at least 2 seconds during the flash memory status display. • During the garbage collection operation, an alarmsounds and "G.C." is displayed on the display. When garbage collection is completed,"Done" is displayed on the display. • Garbage collection cannot be performed when"G.C." has changed to "NG" on the battery charge indicator or when the water sensor hasbeen activated. "Fail" is displayed on the disPress button (B) in the system monitor modeof the standard mode to switch the watch to the Flash Memory Status Display. Formatting Flash Memory Formatting of flash memory begins when button (B) is pressed while pressing button (C) simultaneously forat least 2 seconds.play at this time. theoxrysa@freemail.gr
Oct 11, 2010 | Citizen Promaster Cyber Aqualand Nx Dive...
Hello, I havent been able to unlock this phone.
your phone is locked by nokia and the operating company so your phone will operate only with the sim and the number that defined with the operator but there is a solution called a smart sim card
6103b -- b mean it locked and special edition for the company by nokia
May 06, 2009 | Nokia 6103 Cellular Phone
When I turn on my pc, it boots showing only garbage on the screen.
hi
After booting, the Operating system will only have Recylebin(garbage) as default icon. we need to put the other icons like my computer, my documents, mynetwork and others to desktop. you can do this by following steps.
Go to Run type "desk.cpl". Now you will get Display property window, there click on "Desktop " icon. After doing that you can see a "Customize desktop" button there. click on it. now you would able to see "My documents, My computer, my Network Places, Internet Explorer" beside all this icon will be able to see small square box. you need to click on the boxes. By clicking those boxes, you would get them on your desktop.
Apr 18, 2009 | Compaq Computers & Internet
Meade LX200GPS 8" won't initialize on power up.
Try doing either a garbage collect or a safe load-- and then reinstall the hand controller firmware--
Instructions-- depending on the type of controller
Autostar 495 or 497: You enter Safe Mode by holding the [enter] and
[scroll down] keys pressed when you power up the telescope. The
Autostar will say "Flash Load Ready"... now go start the ASU.
Autostar II: if you need to use Safe Mode to recover from a disaster,
turn on the telescope, and key 999 before it says "Initializing"
The Autostar will say "Flash Load Ready"... now go start the ASU.
LX200gps: BEFORE proceeding further, click on the OPTIONS item on the Top Bar.
Now click on "Garbage Collect Hbx" ... this will perform data cleanup
within the Autostar which will avoid potential mess-ups.
Feb 27, 2009 | Meade LX200GPS Telescope
Notebook not displaying a single thing
Can you get into the BIOS?
Restart ,. When the first screen appears, press F10 to enter the BIOS Setup.If you can set to default
Jan 06, 2008 | HP Pavilion dv4000 Notebook
Protron PD-DVR100 DVD Recorder Logo
52 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
