Question about SanDisk Sansa e250 MP3 Player
Sandisk sansa its a sandisk sansanot sure the number it has 2.0gb on the back of it. anyways, it freezes up, it wont charge i take the battery out trying to reset it and that dont work nomore. I connect it and it dont say connected or battery charging, now it has a blue screen on it with lines threw it. I thought it was the battery but was told they should last a t least a couple of yrs. Daughter got it for christmas with no receit, it was brand new in the box not sure where it came from. I was wondering if anyone knows how i can get it working again, it just stop all of a sudden and taking out the battery and waiten a few minutes dont work nomore, used to but not now. Please help..
  • 3 more comments
  • pammy38 Feb 08, 2008
    oh yea forgot to say it wont turn off even after i unplug it from its power cord that connects to the computer. just a blank blue screen, wont reset nothing only wayt it will if i take the battery out and then it does the same thing and it is a sandisk sansa e250 same one the picture shows lol please helppppp
    i got it to go back to its normal menu but the battery icon doesnt show up at the bottom of the mp3 player screen and it wont connect when i try to reformat it back to the original way or go to settings it freezes up again,
  • pammy38 Feb 09, 2008
    it turns on now but when i connect it to my computer it wont connect and it does not show the battery icon at the bottom so therefore it wont charge??? please help me
  • Babatundea May 31, 2008
    i broke a piece of the wire in the sansa mp3 player port and i cant charge it any more. is there a way to charge only the battery inside if u take it out. or is there a deskport charger for the battery in the sansa e260 mp3 player
  • johan jollens
    johan jollens May 11, 2010
    well .. can you come into recovery mode?
    try : hold (on) push rec button while starting the sansa
    p.s you got a sansa e250 it´s called that when it got 2 gb..
  • 8,596 Answers
Go ahead and do this, in case the DB is corrupted:
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
Posted on Apr 08, 2008
My sandisk sansa clip 1gb wont turn on
Make sure the player is fully charged. 1. Connect the player to the PC. 2. Make sure the computer detects the player.
NOTE: If needed, switch the player to MSC mode, 1. Turn device OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the device to the PC.then connect it to the PC. Next Be sure the battery is charged 1. Leave the player connected for approximately 2 hours to charge. 2. Disconnect the player from the PC. 3. Verify if you can turn on the player. 4. Reset the player if necessary.
To reset the player: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player.
If that does not do it, re-seat the battery: Here is how to get to the battery, 1. Press the battery compartment in while sliding to the right. 2. Remove old battery. 3. Insert new battery or reset the old battery. 4. Close the battery compartment. Then try and see if it will come on with out the battery hooked to your computer. 1. Remove the battery. 2. Connect the player to the PC to verify if it turns on. 3. Re-seat the battery to ensure proper connection. 4. Verify if the player turns on.
Jan 29, 2010 | SanDisk Sansa Clip MP3 Player
Sansa c150
Wait till it runs out of power then charge it. It should charge up normally.
Jul 07, 2009 | SanDisk Sansa c150 MP3 Player
MY SANSA HAS BEEN STUCK IN THE REFRESH DATABASE MODE AND WILL NOT TURN ON NOR OFF . IT WONT EVEN CHARGE EVEN THOUGH IT IS SHOWING A FULL BATTERY HELPPPPPPPPPPPPPP THANK YOU MRS.C.L.C.
This is from the Sansa Website at http://www.sansa.com/support/sansa_e200/faqs
My e200 freezes on the “Refreshing Database” screen
STEP 1 – Reset the device
  1. Press the Power button and hold it for approximately 10 seconds.
  2. Release the Power button once the device is powered down.
  3. Turn the device back on.
STEP 2 – Download and Install the Sansa Firmware Updater
I this helps please dont forget to rate my answer.
Mar 07, 2009 | SanDisk Sansa e250 MP3 Player
Song screwups Sansa c250
You can try to reset the device by pressing the power button for about 15 to 20 seconds..if that doesnt work I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Nov 11, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa e280 wont turn on
What i do is drop it not hard but a light drop and it should turn on than
Aug 25, 2008 | SanDisk Sansa E280 MP3 Player
Sansa C240 freeze, wont turn on
Try a hard reset. Press and hold vol + and select for 20 seconds. If that doesnt work, you can try holding the power button for 30 seconds. Try to restart after either trial. If that doesnt work, you can call support and they can troubleshoot it for you. SanDisk Technical Support 1-866-726-3475 Best of Luck.
Oct 09, 2007 | SanDisk Sansa c240 MP3 Player
Sandisk sansa mp3
k, so now the SanDisk sansa m240 1GB mp3 player, when you turn it on, it freezes. I have tried to change the battery and everything and it still wont work. What is happening here? others that have had the same problem. I researched this online and found out that there was a rather large bad batch of these mp3 players shipped in December. they suggest calling sandisk tech support at 1-866-726-3475 for a replacement and getting a RMA number or going back to where you bought it and exchanging it.
Jul 09, 2007 | SanDisk Sansa m240 MP3 Player
My sansa M240 WonT turn on all the way
Jan 21, 07 I called and spoke with a Sandisk rep on Jan 16 about the "Sansa m240 startup screen" freeze-up problem that so many are experiencing. He said a bad batch was sent out in early December and on those m240's there is "NO POSSIBLE FIX" for that problem, but no plans for a recall. He said he could not discuss what the problem was, but I guess it would be a hardware issue, since a firmware issue could easily be resolved. He said anyone with this problem is requested to call Sandisk and get a MRA number, then return the m240 to Sandisk for a replacement. If you have one that's frozen on the Sansa m240 startup screen (all other freeze-ups can probably be corrected) take it back to your place of purchase or call Sandisk immediately.
Dec 27, 2006 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
81 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
