Question about Nokia 6288 Cellular Phone
Runners on a slider
I need to know how to get my mobile back on its runners its a slider, i ah threw it at the floor as some people do and its now come off the runners i can get one side to click back down but not the other
  • Anonymous Feb 11, 2008
    The sliding up and down doesn't work properly, as if there are some grains stuck in the sliding bit of it.
  • dnbreaker Feb 13, 2008
    can somebody help me....i don't know my security code for a 6288
    355547 / 01 / 257107/ 2 .......code.....plz help me...thx
  • 16 Answers
Okey take it to the nearest mobile vendor.. who repairs.. it just need to place properly. you can try it by reversing the slider mechanism. but be careful. better take it to any mobile repairing shop and get it repair in 5-10 min.
or wash it with petrol by switchhing it offf
best of luck
Posted on Feb 21, 2008
Can I put higher Ah batteries in my Shoprider Streamer?
Absolutely. Let me explain what "Ah" means. "Ah" stands for Amp Hours. A 32ah battery will run a 1 amp motor for 32 hours...or a 32 amp motor for one hour...a 16 amp motor for two hours etc.. As long as the battery voltage is the same it's absolutely fine. As long as your chargers are the correct voltage, they'll be fine as well. So basically, the higher the "Ah", the longer the battery will last. This is why higher "Ah" batteries are more expensive. Hope this helps : )
Jun 09, 2014 | Shoprider Streamer Sport Power Chair
Can you add 2-12 v 18 ah batteries in parallel to back up 2-12 volts 32 ah batteries?
hi, you mustn't do that ,,, you can get excessive current flow and that will damage the battery in question
Regards
Rob
www.gewizrepairs.co.uk
Mar 01, 2014 | Electric Mobility Health & Beauty
H08882ROTX sei lattice
The drawer was very hard to place in the slider runners, took 20 mins to get it in without it locking and getting stuck. Please note the small grayish tabs in side both slider runners, very hard to press theses tabs and see them but these tabs do release the drawer from being locked when you only have it half way in the slot it goes in.
Mar 08, 2013 | Southern Enterprises Lattice 48 in....
Gilera runner sp50 on a 2003 nospark to the plug
put a new plug in it 1st...see if thats helps....if not check wiring to coil ..it maybe coil or cdi box that as gone..just have to work threw it....but start with new plug 1st
Feb 28, 2010 | 2005 Gilera Runner VX 125
Stuck front passenger seat - wont slide back or forwards due to small screw lodged in floor runner
Be there done that, but with a penny. All you can do is either get real aggressive with a hammer and long metal object as a punch or pull the seat. The seat should have 4 bolts. One at each end of each track. Ising a 1/4 in drive rachet and either a 1/2 or 9/16 socket should work. 1/4 in drive is low profile.. good luck
Jun 02, 2009 | 2006 Renault R18
Top rack slider
All I can think of is that the runners on the rack are not in the runner slide on the machine properly or there is an obstuction (EG:loose screw)in the runner on the machine side
Jan 22, 2009 | GE Adora GHDA656LSS Stainless Steel...
98 Cavalier 2.4L engine stumbles at 2000-2500 rpm
Could be a short in the wiring for the O2 sensor.   I currently have the same issue only my car finally threw a code after two days of it acting up.  Code 106.  Changed the MAP sensor and it now throws 108, MAP sensor high voltage circuit.  Ah the joys of cold weather and broke down vehicles.  But I know that you wont always get a code with a short.  Let me know if you fixed the problem.
Oct 31, 2008 | 1998 Chevrolet Cavalier
My back button does not work
****! I got the same problem!!!
Oct 24, 2007 | Kyocera Slider Cellular Phone
Slider Prob
Dang, what a weird design. The lens needs to go threw a cycle before it can reach the idle position where it waits for a comand from the user. If its in the closed position and you turn it on it extends to its full range then stops at the idle position. It sounds like it is stuck in some spot between close and idle. Since it cant reach the closed position or idle its shutting down. The only way to get it to work is to try and free the lens so it can cycle threw. There must be a lip on the slider and the lens is stuck on this lip so you cant slide it. Remove the batteries then try and slide the door open try and slide somthing between the lens and the door to free it up. This is the only way to get it threw the cycle. It may need to be serviced It sounds like the switch for the slider door is warn or has broken. It may work again if you can free the lens.
Aug 31, 2005 | Canon PowerShot S30 Digital Camera
Nokia 6288 Cellular Phone Logo
Top Nokia Cell Phones Experts
270rexton
270rexton
