Question about HP Pavillion ZV6000 Notebook
Ac cord I'm trying to purchase a ac adapter for a hp pavillion zv6000
  • Anonymous Nov 27, 2008
    none of the universals have the right connector for the computer
    Scholar:
  • 181 Answers
And the problem is??
If nothing else, go to ebay. cheap prices, plenty to choose from.
If money doesn't matter and you're in a hurry, purchase a high quality "universal" power adapter, such as ICE. Make sure it carries 90 watts and can handle the appropriate amperage.
Good luck
Posted on Feb 08, 2008
Zv6000 will not charge will not run off of cord
Try another Cord/Charger with the EXACT same power specs. Has the AC jack been damaged due to pulling on the cord while plugged in?
Apr 13, 2013 | HP Pavillion ZV6000 Notebook
I have a gateway laptop & it wont turn on. its charge & everything.
Hi! Welcome to www.fixya.com.
Its definitely a hardware issue. You can remove the battery and ac adapter and drain the power for 10 seconds. then use only the ac adapter. Press the power button and if it did'nt turn on. You have to call your manufacturer for motherboard replacement.
Hope this resolution fix the problem on your computer. Thanks for contacting Fixya. Bye for now.
Jul 19, 2011 | HP Pavillion ZV6000 Notebook
Power suppy ok but computer won't turn on
Try doing a power reset. Remove battery and power adapter, wait for 10-20 seconds then put the battery and adapter back in then turn the computer on. You can also try to remove the battery and just plug it in on the power outlet.
Jun 24, 2010 | HP Pavillion ZV6000 Notebook
How many volts does a HP Pavillion TX1410 adaptor has?
Please look carefully at the unit, the ratings are on the outside of it.
Oct 21, 2009 | HP Pavillion ZV6000 Notebook
Hp zv6000 batt ran down now will not charge or power up on ac power
This can be caused by a few problems, but I think yours is caused by a faulty power jack on laptop or your power adapter is no good.
Power Adapter: Plug it into the wall and notice if the light on adapter lights up or not. If it does light up, test it with a multimeter for proper voltage output. The output is labeled on the adapter sticker, an example would be "19 volts". If the adapter checks out okay then you need to look at where the adapter plugs into the laptop (power jack). If the power adapter did not check out okay, replace it.
Power jacks are known to come loose from the motherboard by the power cord being moved around from normal daily use. What happens is the jack breaks the solder joint and loses the connection. You most of the time see this problem getting worse by having to move your power cord around to get your charging light to come on.
If the computer is under warranty still, this is an issue you would turn it in for work. If it is not under warranty you are either going to need a replacement motherboard or replace/re-solder the jack (cheaper). If you are familiar with soldering circuit boards you can fix this yourself, if you are not experienced, you will have to take it into a electronics repair shop.
The jack and solder are very cheap, it is the labor that will cost you.
Hope this helps give you some direction as to where to look. Good luck.
Oct 04, 2009 | HP Pavillion ZV6000 Notebook
My laptop HP Pavillion ZV6000, battery started decreasing and wouldn't charge when the ac adapter was connected. I purchased another ac adapter thinking that was my problem. It didn't work. Now I have...
As others have said, the most common fault with the ZV series is the power socket. However, you mentioned the Lightning Bolt. This indicates that the battery is being charged and it should go out as soon as the battery is fully charged.
If the Lightning Bolt flashes on and off regularly, especially when the power cable is moved, then the socket is at fault and needs replacing.
You can check to see if the battery is receiving a charge by doing the following
1. Right Click the Desktop
2. Click Properties
3. Click the Screen Saver tab
4. Click the Power button
5. Click the Power Meter tab
This will tell you the computer's current power source and whether the battery is charging.
I have replaced several of these sockets on ZV5000s and I'm sure the 6000 will be similar. I would not recommend this job for anyone without technical knowledge, despite some of the websites that say you can do it yourself. You will need to strip the entire laptop down and all but remove the motherboard before the socket can be replaced.
Hope this helps
May 21, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
HP Pavillion zv6000/ USB Problem
Go to the HP support for this PC at http://welcome.hp.com/country/us/en/support.html and search for your laptop.  Here you can download the USB drivers or any updated drivers that you may need.  If still no dice, then uninstall the USB driver, restart and try loading it again from the download.
Oct 29, 2008 | HP Pavillion ZV6000 Notebook
Charging issues
if you can get a hold of a 12 volt cigarrette lighter car power cord, try and see if the lapper starts then,
if it does, then the power adapter maybe bad
Feb 02, 2008 | HP Pavillion ZV6000 Notebook
Hp pavillion zv6000 white screen on startup
bad video maby bad ram bad screen one of them or bad power chips on mobo worse case
Jan 29, 2008 | HP Pavillion ZV6000 Notebook
HP Pavillion ZV6000 AC Adapter
there is battery problem dear so replace your battery u will get result..
Jan 15, 2008 | HP Pavillion ZV6000 Notebook
HP Pavillion ZV6000 Notebook Logo
55 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
