Question about Radio Shack VGA PC Camera Webcam
Will not connect
Camera will not connect with other cameras
THE WEBCAM IS LOGITECH
Posted on Feb 11, 2008
What can I try if my Coolpix AW120 won't connect to my smartphone, even if I've followed all steps correctly?
The Smartphone connects to the camera NOT the camera connects to smartphone. You have to have the APP on the camera. You first have to turn on WIFI ON the camera. It is like a server. Then you turn on WIFI on the Phone and connect to the Camera WIFI.
Jul 10, 2014 | Nikon COOLPIX AW120 Waterproof Digital...
How to import picture from Samsung camera PL120?
Transferring files by connecting the camera
as a removable disk
Connect the camera to your computer as a removable disk.
1 In Shooting or Playback mode, press [m].
2 Select Settings - PC Software - Off.
3 Turn off the camera.
4 Connect the camera to your computer with the USB
cable.
Transferring files with Intelli-studio
Intelli-studio will start automatically when you connect the camera
to your computer with the USB cable.
The battery will charge while the camera is connected to a computer with the
USB cable.
2 Select Settings - PC Software - On.
cable.
5 Turn on the camera.
• The computer recognizes the camera automatically and
Intelli-studio launches automatically.
6 Select a destination folder on your computer, and then
select Yes.
• New files stored on the camera will automatically transfer to
the selected folder.
• If your camera has no new files, the pop-up window for saving
new files will not appear.
Rate my answer if this helped you.
Sep 13, 2011 | Cameras
Computer not recognizing my camera when connected
Most of the issues can be solved by either reinstalling the software or by disconnecting and reconnecting the device.
In this case we can close in on three solutions
1) The USB drive in the system is not functioning. Try connecting any other USB devices to the same USB port and check whether it works or not. If the other device works well then it could be a problem with the data cable or with the port in the camera (usually firewire)
2) The data cable used to transfer data might have become faulty.Try using another data cable if possible and still the same issue continues then try connecting another camera to the system and if the other camera gets detected then the problem must be with the camera.
3) Try connecting the same camera to another system and see whether the camera gets detected. If no, then the port in the camera is defective.
After this we can close in on which could be faulty. data cable / Computer / Camera.
Feb 25, 2009 | Canon PowerShot SD1000 Digital Camera
Pc camera dose not work properly even if software is installed.
there is a web cam mode in the camera settings put it on webcam mode check the settings in camera , and then connect it to ur computer actually u are connecting in usb mass storage mode it will only allow u to copy pics to ur PC for webcam if ur camera supports it u should have this mode in ur camera menu check and then connect it thru usb see if it works ok
pls vote fixya if i fixed ur problem
regards
zohail
Feb 02, 2009 | Vivitar ViviCam 5355 Digital Camera
"No camera is connected" -- USB connection
The "No camera is connected" error message indicates a communications problem in the USB connection between the camera and the computer. Simply put, the computer cannot find the camera it is being asked to connect with. There is usually no single "most likely" reason for the conflict -- it could be a hardware issue as easily as it could be a software issue.
Sep 21, 2005 | Polaroid PhotoMax Fun Flash 640 SE Digital...
"Camera not connected." -- Serial connection
The "Camera not connected" error message indicates a communications problem in the serial port connection between the camera and the computer. Simply put, the computer cannot find the camera it is being asked to connect with. Whenever an external device (digital camera, scanner, Palm Pilot, etc.) is connected to a computer through its serial port, a communications error is possible. There is usually no single "most likely" reason for the conflict -- it could be a hardware issue as easily as it could be a software issue.
Sep 21, 2005 | Polaroid PhotoMax Fun Flash 820 Digital...
"Failed to Connect to Camera." -- Serial connection
Sep 21, 2005 | Polaroid PhotoMax PDC 640CF Digital Camera
Fun! Digital 320: "Camera not connected." -- Serial connection
The "Camera not connected" error message indicates a communications problem in the serial port connection between the camera and the computer. Simply put, the computer cannot find the camera it is being asked to connect with. Whenever an external device (digital camera, scanner, Palm Pilot, etc.) is connected to a computer through its serial port, a communications error is possible. There is usually no single "most likely" reason for the conflict -- it could be a hardware issue as easily as it could be a software issue. Fortunately, the most common causes of this error message are also the most easily rectified: 1.Make sure that the camera power is on. 2.Make sure that the camera cable has not been damaged. 3.Make sure that the camera cable is properly connected to both the camera and the computer. 4.Clean out the computer's Temp file.
Sep 14, 2005 | Polaroid PhotoMax Fun 320 Digital Camera
Radio Shack VGA PC Camera Webcam Logo
21 people viewed this question
Top Radio Shack Computers & Internet Experts
Mark Gough
micky dee
Mike
Are you a Radio Shack Computer and Internet Expert? Answer questions, earn points and help others
