Sanyo 42 inch flat screen tv numbers on screen
Bought a 42 inc. flat screen tv. We connected it to our regular dish tuner. Numbers will appear on the screen..... during a show. This is the main tv in the house and receiver. These number did not show up on the old tv nor do they show up on any other tv in our house.
    Sergeant:
  • 395 Answers
Contact the manufacturer there may be a software fix for the unit. or you may be in service mode which they may be able to help you get out of with a series of button pushes.
Posted on Feb 08, 2008
Please tell Sanyo flat screen TV model #dp42d23
If it is less then 1 year old Sanyo may fix it free . other wise get a quote as it may cost the price of a new one.
Oct 29, 2014 | Televison & Video
On a Sanyo Vizon HD TV where is the headphone jack?
Panasonic handle Sanyo TV Support now, Here are their contact numbers: Repair:-0871 3321711
Product Help:-
0844 335 2230
Apr 04, 2013 | Sanyo VIZON Multisystem 42" LCD TV 110-220...
Sanyo 2008 flat screen 42 inch no picture have sound
If the problem is same with different input devices and you have ensured there are no loose contacts in power outlet, RC jack, cable and sockets, the TV needs servicing.
Aug 26, 2012 | Sanyo 42K40 42 inch Multi-System LCD TV
We have 42" Sanyo tv
Check first the menu setting.If the setting is in VIdeo or in Tuner.
Sep 04, 2011 | Sanyo Televison & Video
My Sanyo 42" flat screen
There is a problem with the board of your television.That problem is in vertical section, theres a leak capacitor at the vertical section of the board.Its better to replace all the leak capacitor to make the picture back to normal appearance.If you can't do the repair or replacement of of capacitor try,Call a repair technician to do the repair or troubleshooting..Thanks..
Aug 25, 2011 | Sanyo 42 in. LCD TV
Sanyo lcd-32k40 features
  • Model: Sanyo 32K40 Multi System LCD TV
  • World-Wide NTSC/PAL/SECAM Color System - Watch any video signal on this TV!!
  • World-Wide NTSC M, PAL BG, PAL I, Secam BG, DK/ PAL DK TV tuners
  • 32 inch LCD TV with 3 HDMI inputs and PC input
  • USB input for direct media playback
  • 45,000:1 Dynamic Contrast: While viewing either very bright or very dark scenes, it can be difficult to distinguish main images which blend into the background.
  • Dynamic Contrast dramatically mitigates this problem by adjusting the backlight intensity, providing up to a 4X improvement in contrast.
  • 6.5ms Response Time
  • Widescreen 16 X 9 Format
  • World-wide Dual Voltage 110-240 volts 50-60 hertz
  • HDTV monitor (HDTV tuner required for HD reception)
  • This is a multisystem TV. All Multi System TVs in the market do not have a digital TV tuner: What does this mean?
  • To watch digital channels (ATSC Broadcasting in US and DVBT broadcasting overseas) you need a digital source/tuner like a cable box, digital tuner, satellite service, etc.
  • To get the best quality video on this TV you need a source that has a digital connection like HDMI or component.
  • Wide Screen Mode allows you to watch conventional 4:3 aspect ratio broadcasts in wide screen (16:9) mode.
  • Steady Sound® equalizes volume levels so there is consistent output between programs and commercials.
  • Built-in hidden speakers includes 2 (5W x 2) speakers to deliver dynamic sound.
  • Component Video Input offers the best video quality for DVD (480p and 480i), and digital set-top box (1080p, 1080i, 720p, 480p and 480i) connections.
  • PC Input allows you to connect your PC and display the PC screen on your TV.
  • Surround Sound Audio Effect
Mar 04, 2011 | Sanyo 42 in. LCD TV
My sanyo 42 inch plasma has a blue screen, i can hear the sound on the tv but screen remains blue. can u help please
Be sure your channel settings are correct and that you have proper orientation of the hook up cables. See if your remote has a video-mute if so turn it off...a video-mute will produce a blue or black screen. To be sure its not the tuner that's enter the menu screen if you can see the menu then the tuner is ok this means the down-stream video is functioning. Be sure to have all your input devices set to the correct output ports. If all check good and still blue screen then the logic section is not processing video codecs and needs servicing.
Oct 18, 2010 | Sanyo 42 in. LCD TV
42 inch ilo has blue screen.
sounds like tuner control board
Apr 02, 2009 | Televison & Video
Sanyo DS27880 27" TV, Dish signal lost after tv turned off, doesn't return
checks should on your tv tuner it could be bad.IF circuit should also be check and the video section call in the tech to make checks on your tv.and to do repairs on your tv.
Jan 19, 2007 | Sanyo DS27820 27" TV
Televison & Video Logo
178 people viewed this question
Top Televison & Video Experts
