Question about Canon MX300 Office All-In-One Printer
Scanner display shows. RECOMMEND NEW C-CRT
  • tallkris Feb 18, 2008
    I have the same problem, does anyone have any suggestions?
  • Anonymous Mar 01, 2008
    have same... maybe c-crt means colour-cartridge ?
    but i cant believe, just printed a few pages and already gone ?
  • 4 Answers
Solution: Replace ink cartridge(s) MX310.
Replacing An Ink Cartridge Use the following procedure to replace empty ink cartridges or when an ink cartridge error appears.
  1. Confirm that the printer is powered on
  2. Lift the Scanning Unit (Printer Cover) with both hands, and pull the Scanning Unit Support down into place (A).
    Note: After confirming that the scanning unit support is fixed into position, release your hands.
  3. Press down on the semi-circular tab located on the top of the cartridge to release the cartridge and then remove it.
    Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.
    *Optional cartridges PG-40 and CL-41 shown in examples
  4. Remove and replace each cartridge individually. Or, remove the second cartridge after the first has been removed.
  5. Take out a new cartridge from its casing and gently remove the orange protective tape in the direction of the arrow.
    Note: - Do not attempt to reattach the protective tape once you have removed it.
    - Do not touch the gold electrical contacts or the print head nozzles after removing the protective tape.
  6. Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot*
    *One black cartridge and one color cartridge must be installed in the machine in order for the printer to operate. It does not matter if the capacities (Standard or High) do not match.
  7. Push up on the front of the cartridge until it locks into place. (A click sound will be heard when the cartridge is locked in place.)
  8. Confirm that the ink cartridges are installed properly.
    <1> The ink cartridge is not installed properly.
    <2> The ink cartridge is installed properly.
  9. Fold the scanning unit support and close the scanning unit (printer cover).
  10. Wait until the preparatory operation is complete; it takes about one to two minutes.
Posted on Mar 31, 2008
Initalising scanner wait a moment
i would strongly recommend to delete your printer driver and re installed a new one online.
Apr 17, 2016 | HP Color LaserJet CM6040f MFP Q3939A...
Problem with Samsung SCX4623F Mono Laser All in One Copier Scanner and Fax AllInOne Printer showing prepare new cartidge
Dear This means The printer toner cartridge is empty more than 90% [ Less than ten percent toner is remaining].
That is the reason its displaying error. Before it stops We recommend to to bring a new toner. ( do not refill/ or do not use from another printer of the same model.)
All the Best
Rafique
Jun 01, 2012 | Samsung SCX4623F Laser All-in-One Printer
Canon printer
Should be just a cyan ink cartridge.
Jun 18, 2009 | Canon MX310 Office All-In-One Printer
My A940 All-in-One shows a Cartridge error 50C and also shows that the colour cartridge is missing when it is not can you please help tried looking through manual but cannot find what a 50C error is please...
Hi there Error 50c
All the best of luck
Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
You may have to buy a new cartrige.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Jun 17, 2009 | Dell A940 All-In-One InkJet Printer
Color
I would not recommend changing tube usually 10,000 volts on a crt so very dangerous better to buy a new tv typically around the same in price
Apr 14, 2009 | Toshiba 27A33 27" TV
I have the canon mx310. cannot print out what is in the memory. it reads new B-CRT AND C-CRT
the message - recommend new: C-CRT means it needs a new colour toner cartridge and recommend new: B-CRT means it needs a new Black Cartridge.
Oct 01, 2008 | Office Equipment & Supplies
New crt
Hi there. This message on a Canon fax means that the ink is low. CRT stands for cartridge. Replace the FINE cartridge, as ink is low.
If you need further assistance, please post back. Otherwise, thank you for using and rating FixYa!
Jul 02, 2008 | Canon FAX-JX200
New crt?
CRT means cartridge on a Canon fax. The FINE cartridge needs to be replaced.
Display notification
Brjeman:
This error indicates thast one of your ink tanks are empty.
Feb 18, 2008 | Canon PIXMA MX310 All-In-One Printer
Canon MX300 Office All-In-One Printer Logo
313 people viewed this question
old marine
old marine
