Question about Tomtom GO 510 GPS Receiver
File error messege keeps comeing up
I keep getting a file error mess and my blue tooth phone will no longer pair up
  • 2 more comments
  • zerepekim Feb 09, 2008
    i have tom tom go 510, cant pair my razor v3,unable to access file, file access error
  • jonnyballbag Mar 21, 2008
    after upgrading to tomtom 2.2 i can no longer pair my samsung e900 phone and my safety camera warnings no longer work keep getting red box top right corner saying unable to store setting file access error, can anybody help?, i have a tomtom 510.
  • saleslink Apr 15, 2008
    Pairing
  • Anonymous May 18, 2008
    Same problem can no longer pair phone or save the setup information
I am also getting the same problem from the device.
Posted on Apr 14, 2008
  • 515 Answers
My Bluetooth and speaker connect but it wont stay on after one or two songs it keeps shuting down kicking my Bluetooth off on my phone
Teri,
I can't explain why this might work
but try this.
Disconnect the speaker from the phone's blue tooth by unpairing it
then reconnect the speaker by pairing it to the phone again for a fresh reconnection via blue tooth..
Had this issue with a Jabra blue tooth speaker on my wife's mobile phone was doing the exact same symptoms !
It was very very annoying but doing the pairing again fixed it .
Hasn't cut out since pairing it again !
Feb 03, 2017 | Cell Phones
How do I pair this bluetooth device to a phone
First step is to turn the blue tooth power to on in your phone menu,then you must put your blue tooth device into discovery mode,Now most blue tooth manufactures use the power button for thiws feature,when turning your device on keep holding the power button sown for 6 to 10 seconds a solid light usually stays on,this means you are in discovery mode,then you can add new or search for device from your phone menu,once it finds it it will ask for a pin pairing code.Most manufactures use a factory 4 digit pin pairing code they are as follows 0000,1234,1111,or 9999. enter one of these codes starting with the first one ,when it recognizes the pin it will pair and you are ready to use your blue tooth device,glad to be of assistance
Feb 26, 2011 | Motorola Mobility Motopure H12 Bluetooth...
Can not transfer songs from my old phone to my new phone via blue tooth the both phone have connected but when i try to send information it comes up not connected
Hi, you will need pair both phones together before you can be able to send .
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Aug 20, 2010 | HTC Wildfire Cell Phone
I go to the bluetooth menu and turn it on. it says "Bluetooth turned on" But the icon fails to appear and file transfer fails.
HOW TOCONNECT BLUETOOTH
Take care.
Aug 16, 2010 | Sony Ericsson K550i Cellular Phone
Plsits just that my phone's bluetooth refuse to work. It says 'unable to perform bluetooth operation'. Wat can i do to get this prob solved?
first reset the phone and try to connect again.
If it connects,you can use this step to,But if it doesn't connect that means the blue tooth is corrupted and will need to be flash to restore back blue tooth.
(You will have to flash the phone to restore the memory of the phone.
You can use this link to see how to flash your phone.
(hubpages.com/hub/How-to-Flash-your-cell-phone)
and
(unlocktotalk.com/UnlockCodeInstructions.htm.)
HOW TO CONNECT BLUE TOOTH,
Take care.
Jun 28, 2010 | Nokia N73 Cellular Phone
Problem in transfering file via bluetooth
Take care.
Jun 17, 2010 | Sony Ericsson K750
Blue tooth will not pair with my new phone. keeps asking for a pin. i dont recall setting one up and dont have the manual anymore to remember the basic one it came with.
blue tooth will not pair with my new blackberry 8320. keeps asking for a pin. i dont recall setting one up and dont have the manual anymore to remember the basic one it came with.
Mar 21, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Logitech problem
Resell It on EBAY
Sell it to me,
Third, to pair to your phone
1) Make sure the earset is charged fully overnite.
2) Turn on your bluetooth function in Phone.
3) Turn on your earset and keep pressed for about 10 or longer seconds until it becomes solid blue and not any blinking versions. This is the pairing mode.
4) Go to the blue tooth menu in phone and try to discover this ear piece.
5) Enter 0000 as passscode and the phone should get paired up.
6) If it says successfully paired , then go ahead to configure how to turn on blue tooth and automatically configure // trust // and connect to the Logitech bluetooth earset.
7) Now enjoy this ..
Beware ; When the ear peice in your pocket or hangbag, if the buttons get pressed in a way it dials out the last number called , then un-intentionally all you conversation you thought might be private or sensitive in nature will be heard by the the person answering your phone , or worse even it goes to their voice mail,, all your scoop is recorded by the modern phone voice mails...
So Be care full and save some embrassment or OOPS , got me with pants down moment...
Mar 17, 2009 | Logitech Traveller (980399-0403) Wireless...
Blue tooth synch
error 523 reset means a "System process died" You'll need I would reload the entire handheld OS again. If you have the cd it isnt that hard to do. go to crackberry.com and type that error message 523 and their are a lot of full detail restore posts there good luck.
Jan 07, 2009 | Cell Phones
I have an audi S4 2007 what is my blue tooth pairing code???
When u want to pair your bluetooth phone the first time, you must do this in the first 30 seconds after ingnition. This is the only period your audi bluetooth carkit is in search mode. Follow these steps to make it work:
Put your bluetooth phone in search mode, then start your car. Your phone will now detect something like AUDI UHV-1 or similar. Connect to this device, and enter either code 1234 or else code 0000. Your phone will then connect. Command your phone to keep the Audi device listed as a save connection, which can automatically connect. The next time you enter your car it will connect by itself (after ignition that is).
Dec 21, 2008 | 2007 Audi S4 Convertible
GPS Logo
260 people viewed this question
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
