Question about Hitachi 53SWX12B 53" Rear Projection Television
Picture problem I have a Hitachi 53 in Ultravision HDTV rear projection The picture now has a double image and the screen colors are more blue and yellow towards the ends of the screen. Does anybody have any suggestions for this problem or should I just buy a new one. This one is only about 4 years old. Thanks
  • meatball99 Mar 01, 2008
    I have blue and yellow "half-moon" bands of color across the screen, at the top. Magic focus does not correct it. I have all colors and a good picture. I haven't done anything yet but research - set is about 6 years old.
  • Pat S Mar 05, 2008
    I replaced the 3 resistors and the convergance amps on the Hitchi 53 in ultravision. But I noticed a problem when I soldered the amps in place that I bridged one of the solder joints, I plugged the tv and nothing happened so I rechecked and desoldered the bridge joint and still no picture. Are there fuses that go when this happens or is the amps no good again. ANY HELP Thanks
I have check with some local techs about these repairs and they are saying that the cost would be a minimum of $600 and that the convergence alone would be $95/hour for about 5 to 8 hours.  This sounds extreme.  Should it cost less?  Is this something that I could do myself for less?  Thanks for any advice that any of you could offer.
Posted on May 03, 2008
    Sergeant:
  • 395 Answers
The problem is convergance the amplifiers (two of them) have failed. posibly some resistors or pico fuses are bad along with them. they need to be replaced then realiegn the convegance. the cost of repair may be $200.00 to $350.00 depending on the tech you get.
Posted on Feb 08, 2008
Images on screen are doubled. Everything
u have bad convergence ic stk392-110 or stk392-150
Apr 13, 2010 | Hitachi 53UWX10B 53" Rear Projection...
Double images red blue green lines
My picture screen has double images red,blue,green. The screen looks 3D
Dec 28, 2009 | Sony KP-53HS30 53" Rear Projection...
Broken screens on 53'' Hitachi rear-projection TV
I think it would likely work if you trimmed it evenly around the sides in order to maintain the central position. Focus may have to be adjusted but thats all.
Oct 25, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Hdtv that has double vision
There are two common problems with these sets.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 23, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Poss. convergence problem with Hitachi 53UDX10B Ultravision
You have convergence problem. Either bad connections on ics, ics are bad or voltages to convergence circuit are missing. There are no bulbs in this set. 3 picture tubes,red,green and blue produce a picture than when alighned(converged) correctly on top of each other gives you a color picture.When not you get the effect you are describing. Frst you can try the magic focus in the menu.
Apr 20, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Can`t get clear picture anymore
Hello dhack56,
Can you post a picture of the screen as the TV is playing, this way I can see if the picture is fuzzy, or if the images are split, all of which classify as not a clear picture. A picture of the screen will help with the diagnosis.
Thank you,
Shuttle83
Oct 02, 2008 | Hitachi 53UDX10B 53" Rear Projection...
My Hitachi television covers the image by blue color how i can solve this problem thank you
is the red color over the picture like coming out of the picture
or there is a color all over the screen?
thank you
Jose
Aug 13, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi projection 53" screen color off
Since this is a CRT based projection set, there is no "lamp" involved. Does the picture look like 3-D? If so, the problem is likely to be a convergence problem. There should be 1 or 2 convergence ICs marked STK392-110 inside attached to a heatsink. If you can solder, try resoldering the pins on those ICs. If that fails to resolve the problem, replace them.
Keep us posted.
Dan
Jul 14, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Problem in Hitachi 53UWX10BA
The convergence ic's, and related components that could'be affected need to be replaced cost to repair 250.00 2hrs job max with alignment this depending on the tech. If you need more help let me know
Jun 14, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Picture is yellow and green
Your missing the red drive on the set. Its most likly the picture tube. Its a possibility that the red drive circuit could be not working so the best thing to do is take off the gree picture tube socket and put the green board on the red tube. Of course do all this when the set is unplugged. if you have no tv experience. its not a good idea to be messing around inside of these sets.
Sep 02, 2006 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 53SWX12B 53" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
