Question about Zenith E44W48LCD 44" Rear Projection HDTV
Yellow Spot I have a yellow spot in the center of my screen. I have changed the filter in the back but the spot is still there. Is there another filter I need to change?
  • Kram4 Feb 09, 2008
    Thank you for taking the time to answer my question. It has been helpful.
  • Mulerider May 11, 2008
    Area in center of screen has a yellow tint. I have not tried replacing any parts but if the figure of $1200 is right I will not be buying another Zenith.
  • 113 Answers
Sorry that I have to be the one to let you know this but the light engine in your set has a spot that has developed on your lens. It is not possibile to clean this without making your picture worse. The light engine would need to be replaced in your set to fix this and the cost will not be cost effective. Part number is 3141VSN916C and I cant find it at any dealer for less than 1200 dollars.
Josh
Posted on Feb 08, 2008
Contact Tristate Modules www.Tristaemodule.com. Buy remanufactured light engine or send your light engine in for repair.
Posted on Oct 07, 2008
Panasonic PT-AE2000U yellow spot
I believe your referring to a lens flare...if so, you must smoothly sand the lens with the finest sand paper and then buff it to perfection
Jan 04, 2012 | Panasonic PT-AE2000U Projector
Spot in center of screen, if the color pictureis black the spot is blue, if the picture is white the spot is yellow.
Spots in screen is commonly caused by defective LCD on the optical assembly. LCD replacement is very difficult. I suggest to contact the nearest service center at your area.
Oct 09, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Hitachi 55vs69a yellow blob in center
you most likely have a bad light engine.
Aug 20, 2009 | Televison & Video
Big yellow spot in the middle of the screen
the lcd panel for the blue is bad normally you would have to replace the engine but i know a place where you can get it rebuilted for a price cheaper than the engine go to
N-home tvservice.com for some answers
Mar 02, 2009 | Hitachi 55VS69 55" Projection HDTV
InFocus LP 850 Projector, yellow spot on screen
Unfortunately the discoloration is caused by the extreme heat generated by the Lamp has burned the LCD optical polarization filter/elements.
The only solution for this is to replace the entire LCD optical assembly.
Sorry for the bad news, :(
Jan 29, 2009 | InFocus LP 850 Multimedia Projector
Have yellow spot in center of screeen
it is actually a light engine problem, i have replaced probabily 50 of thease for that exact problem, it is a prity hard part to change yourself, and it costs about 400 dollars
Jan 09, 2009 | Hitachi 42V710 42" Rear Projection HDTV
Hitachi projector model CP X260 projects yellow spot on screen
This is probably the polarizing filter. It will need to be replaced. It should not cost very much to fix.
Jan 07, 2009 | Office Equipment & Supplies
Yellow Spot dead center on screen
Any color spot is never the lamp with this type of set.
the yellow spot is caused by the optic block (Engine). Very expensive to buy.
Little over $1000 plus labour with a qualified technician.
Sometimes technician may try to clean or repair inside but most likely won't succed.
good luck.
Sep 20, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
Green or Yellow Spot on screen
It could be a dirty filter or dust in the intake holes. Vacuum (preferably) or blow out the vent holes. The projector may be overheating because of this.
Oct 24, 2007 | Sharp Notevision XG-NV6XU Multimedia...
most likely the yellow dot is due to a burn in the picture on the "green" lens. It's not removable because it's burned it, but you can try cleaning it because sometimes, dots are caused by dirt. The worst that can occur is that if the dot is permanant.
Feb 14, 2006 | RCA MM61110 61" Rear Projection Television
Zenith E44W48LCD 44" Rear Projection HDTV Logo
232 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
