Question about GE JVM1630 Microwave Oven
Microwave JVM1630 The microwave is in mute and doesn't beep when stop warming food, it use to do it and doesn't do it anymore, only when I unplug it and plug it back does it for a while and then it stop.
    Problem Solver:
  • 4 Answers
Ours was doing the same, no beep and the "mute" on the display despite having no mute button. Also, the surface light and fan had recently stopped working even though the buttons worked. Unplugging it did the trick! Maybe it's running Windows?!
Posted on Sep 09, 2009
  • 2,130 Answers
From what you have described, it appears that the microwave oven works fine, except that the beeper doesn't work like it used to.
This could be caused by a couple of things.
First, there is typically a piezo electric speaker that creates the "beeping" sound. It's possible that this part has failed. It's a mechanical device and can break. This part is relatively inexpensive.
The piezo speaker is controlled by the microprocessor board. It's possible that there is a problem with one of the output lines from the microprocessor that is tied to the speaker.
One way to determine which part is defective, is to try connecting another speaker in parallel across the original speaker, or remove the original and try the replacement (least expensive method).
If there still is no sound, then I would suspect the problem is on the microprocessor board. (most expensive method).
If I can be of further assistance to you, please let me know.
Good Luck!
- Jim
Posted on Feb 08, 2008
If you try to heat something for a minute , the microwave will turn on for about 15 seconds then shut off . It doesn't even seem to warm the food.
It may need a reset. You can do that by unplugging the power for a minute or two, then plugging it back in and setting the clock.
If it still fails, you may have a failing cooling fan or a problem on the control circuit board.
Apr 14, 2013 | Thermador MCES Stainless Steel 1000 Watts...
Just stopped like i unpluged the power, i checked the outlet that it is plugged to and have 120 volts on my meter, are there any fuses if so where are they
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jan 03, 2011 | GE JVM1630 Microwave Oven
The oven is not heating the food. All the controls is working, but it is not heating up the items. I tried to warm up a beverge and it didn't warm up. This just happened all of a sudden. Last night it...
Basic
Microwave Oven Troubleshooting Tips
heatman101
Nov 11, 2010 | GE JVM1630 Microwave Oven
Runs but does not heat
The magnetron (the part that heats the food) may be bad or the circuitry to the magnetron may have burned out. Basically my advice is that if you have no electrical expertise, it isn't worth fixing. The magnetron if bad, costs almost as much as a new microwave. If you open it up (make sure it has been unplugged for a few hours and don't seen any obvious burnt parts (including a fuse and the diodes), then most likely the magnetron is done and a new microwave is the way to go.
Let me know how this works out for you.
Benjamin
Aug 15, 2010 | GE JVM1630 Microwave Oven
Our microwave is no longer heating food. Is there any way to fix this problem or is it time for a new microwave?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
heatman101
jkf
Jun 22, 2010 | GE JVM1630 Microwave Oven
Microwave heating for 20-30 minutes with no food. Does not work.
heatman101
hgj
Jun 02, 2010 | GE JVM1630 Microwave Oven
The microwave is making a humming noise as it runs and the food does not get hot.
your high voltage capacitor or diode in the high voltage doubler circuit is open and can't help double the high voltage to operate the magnetron tube to make food heat
May 16, 2010 | GE JVM1630 Microwave Oven
GE JVM1660 1000 Watts Microwave Oven beeps every minute
Maybe u should contact ur retailer or the manufacture helpline and tell them your problem they might be able to tell what's wrong.
Feb 28, 2007 | GE JVM1660 Microwave Oven
GE JVM1630 Microwave Oven Logo
345 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
