Question about 3Com NBX® V3000 (3C10600BUS)
Nbx v3000 After the system is turned on, the power light keeps blinking, I am unable to connect to it thru the browser. I went in with a terminal emulation and saw that the IP address is 192.168.1.190, but I am assuming that the blinking power light is a problem?
  • 1 more comment
  • BILLVAS May 06, 2008
    I HAVE THE SAME EXACT PROBLEM BUT I AM SURE THE POWER SUPPLY IS NOT THE PROBLEM.THE NBX (3COM V3000) CAN NOT LOAD THE CONFIGURATION FILE . VIA SERIAL CONNECTION WITH HYPER TERMINAL I SEE THAT DURING THE BOOT PROCESS THE DEVICE CAN NOT LOAD THE CONFIGURATION.IS THERE A WAY TO IDENTIFY THE CONF FILE? CAN I RESTORE? WHAT SHOULD I DO? THE POWER LED STILL BLINKS.ANY IDEAS? THANKS ANYWAY.
    This is just a part from the boot process of my 3COM NBX V3000 via Hyper terminal session.Maybe this output will help some experts to figure out the problem,maybe not! First, Bootloader version,OK, then SuperIO Initilization...OK,then Host PCI Initilization...DDRAM size:112 MBytes ,OK and then ERROR:Loading environment variables failed-storing and using defaults...Companion board found (0x6)...initializing...The power led is blinking always and the web interface is down.The problem took place after a faulty UPS power supply.(UPS is replaced by a new one but the NBX is still out of order) Is there a memory problem? a hard disk ? Any ideas?
  • BILLVAS May 30, 2008
    The problem is in the Hard Disk Drive file system (a
    corrupted file or more)
    The disk in NBX is divided in two partitions , one DOS
    FAT16 and one HTFS .
    The problem appears in the HTFS partition.Here is the
    error message during the boot.
    " i18n system initializing
    assertion failed: ga->ia_nblocks == 0, file:
    indx_iops.c, line: 562 "
    There is an error in the HTFS during the boot , finally
    the NBX prompts : v3000->
    At this point I have typed some basic commands
    (version,ll,pwd,devs) to see which is the working directory , what kind of
    devices the NBX has,the version it runs and a list of files and directories in
    the HTFS partition.
    I also typed the command diskInit "\htfs 0", to check the disk
    file system, but no luck.
    The DOS (FAT 16) partition seems to be ok , no errors.(I
    can see the files and I can copy them )
    I did not try to mount the HTFS drive in a Unix PC
    .(without knowing what to do exactly-dangerous!)
    The task list contains the FTP & Telnet server(are running) but the WEB interface no.(off)
    So,is there a chance to fix
    the corrupted file (or the whole HTFS partition)?
    Unfortunately i think that i have to forget the NBX and try
    to find a different VOIP/SIP solution for my company communication.Because i had a real hard time trying to find in forums a solution about recovering htfs file system.
    In any case , thank you for your time and interest
    Problem Solver:
  • 7 Answers
Check with the power supply, do you have a constant power supply
Posted on Feb 08, 2008
Theft light blinks rapidly. can't start engine. 2002 merecury sable gs
Reset the alarm system. It won't start unless you do. If you can't reset thru your system controls, disconnect the battery ground terminal for 24 hours the re-connect. This will reset the computer and alarm should be cancelled.
Jul 15, 2017 | Cars & Trucks
I bought a Bose V35 2 weeks back. I played my system yesterday and switched off. Since this morning I am unable to switch on the system. Green light keeps blinking and I keep getting the message "iPod...
With this system being so recent from purchase you should return it to the store as it is faulty. DO Not Attempt to do any "Mr Fix It" type repairs as it will invalidate any warranty (standard is 12months from new in UK)
Jan 07, 2011 | Bose V35 Theater System
How to reset to factory default a Cisco Aironet 340 (AIR-BRI342)
  1. Use a straight-through cable with 9-pin male to 9-pin female connectors to connect the COM 1 or COM 2 port on your computer to the RS232 port on the bridge or AP. You can select the Reset option only through the console port.
  2. Open a terminal-emulation program on your computer.
    Note: These instructions describe HyperTeminal; other programs are similar.
  3. In the Connection Description window, enter a name and select an icon for the connection and click OK.
  4. In the Connect To window, select the port to which the cable is connected and click OK.
    1. In the Port Settings window, enter the following settings:
    2. 9600 baud
    • 8 data bits
    • No parity
    • 1 stop bit, and
    • Xon/Xoff flow control
    1. Click OK and press Enter.
    2. When the Main Menu screen appears, reboot the bridge or AP by turning the unit off and then turning it back on.
    3. When the bridge or AP reboots and the Main Menu screen reappears, typ
    4. Use a straight-through cable with 9-pin male to 9-pin female connectors to connect the COM 1 or COM 2 port on your computer to the RS232 port on the bridge or AP. You can select the Reset option only through the console port.
    5. Open a terminal-emulation program on your computer.
    6. In the Connection Description window, enter a name and select an icon for the connection and click OK.
    7. In the Connect To window, select the port to which the cable is connected and click OK.
    8. In the Port Settings window, enter the following settings:
      • 9600 baud
      • 8 data bits
      • No parity
      • 1 stop bit, and
    9. Click OK and press Enter.
    10. When the Main Menu screen appears, reboot the bridge or AP by turning the unit off and then turning it back on.
    11. When the bridge or AP reboots and the Main Menu screen reappears, type 2 to select Reset and press Enter.
    12. Type yes and press Enter to confirm the command.
      Note: The Reset command is valid for only two minutes immediately after the bridge or AP reboots. If you do not enter and confirm the Reset command during that two minutes, reboot the bridge or AP again.
    13. After the bridge or AP reboots, reconfigure it by using the terminal emulator or an Internet browser.e 2 to select Reset and press Enter.
    14. Type yes and press Enter to confirm the command.
    15. After the bridge or AP reboots, reconfigure it by using the terminal emulator or an Internet browser.
    Apr 17, 2009 | Aironet BR500
    Trouble starting....
    check battery connection. make sure terminals are clean. and make sure the terminals are not loose when connected
    Aug 14, 2008 | 1996 Toyota Camry
    Router orange button
    on the back of the unit is a reset button
    Hold that down for 30 sec
    that will completely reset the router back to factory defaults
    turn the unit off for 15 min while the ISP's connection resets.
    Then power back up.
    you should be able to reach 192.168.1.1 via the browser thru the wired connection.
    Then setup the system again.
    the only problem is if your MAC was cloned by the ISP and that is the only connection they will let back on.
    If that is the issue, please respond back
    Jan 01, 2008 | Linksys Wireless-G WRT54GS Router...
    Tv cuts off and green light flashes
    the tv will try to reboot a few times. just let i try and eventually it will start blinking red. if you could count the red blinks then i can further assist you.
    Sep 23, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
    Broadband 2nd Light keeps blinking yellow and then a solid red Light
    Ask your Paents to ring the company they connect with it seems to be emulating a disconnection for some reason?
    Sep 05, 2007 | 2wire (1000-000057-000) Modem
    Tv will not turn on but it constantly blinks and will not stop
    You need to change the seven capacitors on the DM power supply board (inside the metal case on the left where your DTV tuner connects)They are 1000 MFD 16 VOLT capacitors and the tops are probably bulging outward because they are leaky- this is a common problem.When you lost power,the TV had to reboot itself but because of the leaky caps it never will and the green light keeps blinking.As long as you never lost power or unplugged the set the TV would of still worked.Once you change the parts and plug the set in the light will blink normaly for about a minute and when it stops blinking you can then turn on the TV.
    Aug 30, 2007 | Mitsubishi WS-55859 55" Rear Projection...
    3Com NBX® V3000 (3C10600BUS) Logo
    1,424 people viewed this question
    Top 3Com Computers & Internet Experts
    micky dee
    didi2005
    john smith
    Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
